Question about Kenmore Oasis HE 27082 Top Load Washer
Kenmore Oasis HE 110.2708 shuts off in wash - no code displayed
This is happening consistently now. No code is displayed so that doesn't help. It just stops. But it always seems to stop during the agitation phase. I took the top console off and checked the connections to the interface board and nothing looked wrong. I reassembled it and it exhibits the same problems. The fact that it only stops in the agitation phase suggests it's a mechanical problem and that replacing the interface board won't help. Any suggestions? Thanks in advance.
  • Anonymous Mar 15, 2009
    I have the same problem my washer is about 2 years some time have number flashing then shut off some time just finish wash then I want to start again but no power
  • 15,935 Answers
It appears your timer/main controller/CCU has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 16, 2010
Mid wash cycle shuts down and ol appears....laundry still soaking wet and washer shut off
follow this thread: http://appliantology.org/topic/37774-kenmore-elite-oasis-he-ol-error-code/
Mar 22, 2015 | Kenmore Oasis HE 27087
Washer is displaying an LF code, shut offs were just changed. Is there a way to reset?
need to make sure the new water valves are open and the hose screens are not blocked with rust or build up.
Dec 17, 2010 | Kenmore Oasis HE 27062 Top Load Washer
Why is my kenmore elite (top loader) oasis washer HE is displaying a code of HC
The water inlet hoses are probably removed and reconnected in reverse, and then trigger the HC error code to flash indicating the hot and cold water inlet hoses are reversed. Reconnect the water inlet hoses properly and start a cycle then let us know what happens next.
Apr 18, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Machine stops several times shows F1 code
this is a main control board failure and needs to be replaced
Sep 16, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
I have a kenmore oasis, and it powers up, althouh when I push start, nothing happens? is there some trick to make this thing work?
check contact points on the break pad modules,sensor either worn out ,check error alarm in the monitor display.
May 10, 2009 | Kenmore Oasis 27042 Top Load Washer
Lid Display lit when starting wash cycle
LID code could mean that the door lid switch is not pressed. try to shut the door completely or the lid switch could have been broken. or the plastic that should press the lid switch could have been broken also. it is attached to the door i hope i was able to help.
Jun 21, 2008 | Kenmore Oasis HE 27082 Top Load Washer
Kenmore Oasis has LF code on and won't reset
The LF code indicates "Long Fill" which means it is taking too long for the water to fill the washer (times out). From the owner's manual:
"LF" (Washer is taking too long to fill)
Check the following:
Are the water inlet hoses kinked or clogged?
Are the water inlet valve screens clear?
Press STOP to clear display.
Here's a suggestion I found that worked for me:
Check your drain hose to see it it's stuffed too far down the standpipe. Another poster had this problem and it gave her LF errors. If the drain hose hangs down too far it can siphon water out of the washer, and then the washer thinks it's taking too long too fill. There's supposed to be a U-shaped plastic bracket that sets the length of the drain hose where it goes into the standpipe. Your installer may have tossed it.
Apr 07, 2008 | Kenmore Oasis HE 27082 Top Load Washer
No display on Kenmore Oasis
there should be a repair manual inside the machine. If you use a screw driver in the front to open the top of the machine the manual should be on the inside of the front panel.
Oct 13, 2007 | Kenmore Oasis HE 27082 Top Load Washer
Kenmore Oasis HE 27082 Top Load Washer Logo
71 people viewed this question
Ron Lankford
Archaeology
Archaeology
reliableservice
