Question about Kenmore 46462 Front Load Washer
Water leaks out front door
I emptied the trap and it worked for one or two washes but now trap in empty and it still overflows. Where is pump located and how does that get cleaned out?
  • lizkorecky1 Mar 12, 2009
    Duh, it's not the front seal since as stated, it worked without leaking for loads in between. I think it's something with the pump and was asking for assistance for removing or opening pump, I think something may be caught in impellor, causing water not to empty completely and therefore accumulate and then overflow.
    Genius:
  • 1,066 Answers
Replace the front seal....duh
Posted on Mar 12, 2009
Asko 6762 does not complete filling with water. It also wont complete spin cycles. The drain pump sometimes runs continually after the tub is empty. Have cleared the coin trap and the hose between the tub...
Sound like it could be some "dirt" in the "air-trap-tube", so the machine dont get the signals that says it's empty. This also can also make problems for filling. This "air-trap" is the plastic tube, mounted upwards on the bellow hose, between drum and pump.
Could also be a pressure switch, or pressure sensor problem, but this is not very common:)
Oct 04, 2013 | Asko W6221 Front Load Washer
Will not empty of water
If it's a front load washer the coin trap may be clogged up with a sock I have found dollar bills, baby socks,bra wires, you name it in them.It could also be a door switch.If it does not drain or spin then I would check the door switch.Coin trap is usually the problem with a front load washer.
If a top load then either drain pump or clogged line I have found garments in the drain pump but it is rare.Check to make sure the pump is getting electricity if not a direct drive pump.
Aug 31, 2012 | Washing Machines
Pump is working but no water being ejected
This is almost certainly a simple problem with your empty pump filter being clogged. The empty cycle is timed and if it can't get all the water out in time because the filter is blocked and slowing the empty down, then it will fail safe and won't step on to the final spin cycle with excess water in the drum. While it's trying to get the water evacuated, you will probably see the machine doing a slow tumble for up to 8 minutes and you may also hear the empty pump running too.
You need to locate and clean the filter. Depending on the model (not familiar which with the model you mention) there is probably a round filter cap on the front of the machine at the bottom (It may be behind a small door or hidden behind a clip on panel on the bottom) Many models of this design also have a small hose to the right of the filter cap that you can pull out, remove a plug from and drain off any water in the filter before you remove the filter and get your floor wet, so take a look for this before you remove the filter and get soaked.
OR
You will need to access the debris trap from the back of the machine. If there is no filter at the front, pull the machine out and you will see a roughly oval panel at the bottom of the rear of the machine. Unscrew the 3 or 4 screws and unclip. Directly below the drum, you will now see a rubber "Cup" like bulge in the black pipe, with a plastic tube connected to a plastic pipe. The cup is held in place by a large jubilee clip. Unscrew the clip, pull off the rubber boot to expose the debris trap (A conical plastic cage with a ping pong ball in it) Take out the ball and the plastic trap, clean out the debris and replace the trap and the ball (Note that the cage may have a slot in it that locates in the rubber boot, make sure it lines up, or it won't reassemble correctly). Now push the boot back onto the fitting at the bottom of the drum where it came from and tighten up the jubilee clip, making sure that it is fitted correctly (it too may have a small slot out of it that fits around a protrusion on the bottom of the housing).
Jul 20, 2011 | Hoover AAA160 Front Load Washer
Indesit wixe127 washing machine will not empty or spin door will not open
This is simply a problem with your empty pump filter being clogged. The empty cycle is timed and if it can't get all the water out in time because the filter is blocked and slowing the empty down, then it will fail safe and won't step on to the final spin cycle with excess water in the drum. Your repeat of the rinse/spin cycle is giving it extra empty time and then the spin works OK.
You need to locate and clean the filter. Depending on the model (not sure which with the model you mention) there is either a round filter cap on the front of the machine at the bottom (It may be behind a small door or hidden behind a clip on panel on the bottom) or, you will need to access the debris trap from the back of the machine.
Jul 05, 2011 | Indesit Washing Machines
When turn to spind ry it just dont do the work
Your empty pump filter is probably blocked. Not enough water getting evacuated when it empties so the spin cycle wont run. The filter is probably on the front of the machine at the bottom (probably behind a little door).
Locate, clean, reassemble, job probably done
Jun 23, 2011 | Speed Queen CTSA0AWN Front Load Washer
GE WBVH6240 Front load washer. Pump running while empty
you would need to go into the fault codes and read them. the tech sheet should be under the lid or in the kick panel
Feb 07, 2010 | GE WBVH6240F Front Load Washer
Water doesn't drain
you could have a bad drain pump.
have you checked the hoses that come from the bottom of the tub to the drain pump for anything that might be stuck in there,also check the hose that comes off the drain pump to the wall and look for an obstruction.
Jan 31, 2010 | Asko W6021 Front Load Washer
Leak from lower door section and from powder door thing.
This could be a partially or completely seized/failed pump.
Before a machine goes in to a spin cycle, it runs the pump to empty all the water out. It used to be quite common that the machine does not check all the water has gone before spinning, it just runs the pump for a set time which if the pump is okay, is long enough to empty it.
If a spin is then started with quite a lot of water left in the drum, it gets thrown everywhere including back out of the powder/conditioner draw. Also the sheer strain of spinning a large amount of water can force water through an otherwise okay door seal.
Unless you are comfortable working on the machine yourself, call an engineer.
Sep 07, 2009 | Hotpoint WF430 Front Load Washer
Dishwasher just emptying
I am at the end of my tether. I have bought a new door latch for my Bosch SGS 43E02 GB45, so door now closes properly and have managed to stop the leak under the front left hand side of the machine. Howver it sounds as if it is constantly emptying. It does not go onto the new wash cycle just keeps pumping out the water. It did run a quick rinse yestreday but now is back to the constant emptying problem. Even when I open the door it still keeps running and staying on a emptying cycle despite there being no visible water left inside the machine. Please help!!
Sep 12, 2008 | Dishwashers
Bosch WFMC 3200 possible leak?
It is normal that there is water in the trap, which is your filter. You clean this not after every wash, it depends on your usage. I have my machine trap looked into once in 2 months; i use it once a week. Of course i clear all pockets of clothes before i put them in machine.
Jun 05, 2008 | Bosch WFMC 3200 Front Load Washer
Kenmore 46462 Front Load Washer Logo
69 people viewed this question
Ron Lankford
Archaeology
Archaeology
2mikecurtis
