Question about Stoves 720EF Electric Double Oven
I have a stove 720EF in blue and would love to get replacement flame spreader and the disc that sits on top of it, does anyone know where i could find them would need to replace all four.
  • 250 Answers
Try espares. If the parts are not shown online send a query in and they may be able to help.
Posted on Mar 25, 2009
My stoves 720ef oven keeps cutting out after 20 minutes and will not turn back on, the grill continues to work ok. I know the timer is set to manual so I guess it must be a thermal trip. As I do not have a...
There are seperate thermal (overheat) cutout devices for both the top and bottom ovens. First check to see if the lower oven fan is running ok and is not restricted by grease or fat (there are 4 self tapping screws that hold the fan cover on) and the thermostat is switching off and on as it should. You should also check that the main background cooling fan is running and switches off a few mins after the ovens have turned off. If these check out ok, then it is possibly the lower oven thermal cutout.
Aug 04, 2010 | Stoves 720EF Electric Double Oven
Grill trips my electrics on Stoves 720EF
I had problems with tripping and it was a faulty RCB on the consumer unit. But it wasn't just one appliance causing the problem.
Have you isolated it to the top or bottom oven. If it is the main oven, then it could be anything associated with the operation of that component, i.e. the oven control knob,the oven thermostat, the element, the element fan, the overheat thermostat all could have insulation that is breaking down that could cause this problem.
Before you go and buy anything and if you have the time and patience and confident enough and know what you are doing, I would remove the oven from the cupboard, take off the top and back covers, note the wiring for the element, take the leads off the element and run the oven with the element disconnected and see what happens. That should prove whether it is the element or anything else.
BE CAREFUL.
Jun 06, 2010 | Stoves 720EF Electric Double Oven
My stoves oven is burning my kitchen cupboards
If you could provide some more information, then I may be able to help. What part of the oven is causing the problem, i.e. top or bottom door. If the doors don't shut properly then this may cause the hot air to escape. If it is one of the doors, is it sitting square in the frame?
Feb 20, 2010 | Stoves 720EF Electric Double Oven
I need an instruction manual for a stoves heritage 720EF oven
I have just uploaded a scanned copy of the stoves 720- EF manual to the link below.
Requires the free Adobe Acrobat Reader or similar software to view the manual which most computers already have. The stoves ef720 manual file below is full and free of charge
http://wl.filegenie.com/~simun/Stoves720EF.pdf
Jun 02, 2009 | Stoves 720EF Electric Double Oven
I need an instruction manual for 720EF
Supply me an email address and I will give it the access to my BT Digital Vault so that you can down load the copy I scanned in.
Feb 07, 2009 | Stoves 720EF Electric Double Oven
Oven burner flame is low
0000000.jpgOn top of that safety valve is a nut. Get a good fitting wrench. Turn on the oven and use that good fitting wrench on that nut. Turn it counterclockwise till the flame comes up about midways of the flame spreader. Don't get the flames too high. Midways of the spreader now. LOL
Jan 02, 2009 | Ovens
Instruction manuel required for stoves 720ef
I have a user guide and as I said on another post I will try and scan it so that anyone can have a copy. In the meantime, is there anything you need to know?
Jan 01, 2009 | Stoves 720EF Electric Double Oven
Stoves 720EF Top Oven Failed
there is a safety stat/fuse on top of the oven exterior i think you will find that it also has blown. Make sure you have isolated the appliance at the fuse board first though, Good Luck
Dec 22, 2008 | Stoves 720EF Electric Double Oven
Stoves 720EF Electric Double Oven Logo
51 people viewed this question
Top Stoves Ovens Experts
ashburton
Dan Webster
Dan Webster
Are you a Stoves Oven Expert? Answer questions, earn points and help others
