Kenmore top load washer model number 92574100 will not spin--only the motor runs.
  • mslebodnik63 Mar 10, 2009
    how do I fix?
    Thanks man--that was it--piece of cake
  • 163 Answers
Your drive coupler is bad.located between motor and transmission
Posted on Mar 10, 2009
  • 1 more comment
  • mike cooksey Mar 10, 2009
    first unplug machine.you will need to start by taking 2 screws out of the face of the machine.flip face back and unplug the lidswitch from cabinet.you will see 2 gold clmps you will need to pop them off and then your cabinet should pull forward and cabinet will come off.at front bottom you will see your pump,take 2 clamps off pump and move to the side and then take wire harness loose from the motor.the motor has 2 clamps holding it in place also pop those eff,sometimes their will be a screw you need to take ou before the clamp comes off but you will see.soon as motor is off you will see the drive coupler.it has 2 sides to it and a rubber like center.either it has broke teeth on it or the rubber part will be destroyed or wher the shaft goes into coupler will be stripped.
    sounds harder than what it is.just pay attention how it came apart so you will remember how it goes back together
    glad i could help.
My kenmore 80 series washer wont drain or spin.
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Sep 16, 2010 | Kenmore 22422 Top Load Washer
Kenmore top load hqavy duty 80 series model 82980120 - how does one get to the drive belt. Washer motor hums but no action any cycle.
Your complete model number including the first 3 numbers , is needed to help you get to the coupling . The coupling , is the piece ( pt # 285753 ) which connects the motor to the transmission . When this piece breaks , the motor will run , but no machine action , except for water drain . Even spin , will not work , yet , you will hear the motor running .
Oct 11, 2009 | Kenmore 24032\24036 Top Load Washer
Doesn't agitate or spin. Motor runs
model number not found. If it is a direst drive model you need to see www.youtube.com/watch?v=WLPGs2UMUJc
Jul 05, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore washer not spinning ans washing
Does it sound like the motor is running at all ?( if motor is running u need a coupler) (with machine off turn cycle switch around 3x roughly, then try machine) With the machine off do you hear a clicking noise if you open and close the lid?
Mar 25, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore 90 washing machine does not spin or agitate
make sure your pump is not clogged or jammed..that will stop the motor,,quick test,,pull pump off and start unit in wash,,or spin if unit is empty..onthejob
Jan 31, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore 90 plus series: heavy duty super capacity won't agitate
this is the site to find out how to fix your washer.
you have a broken drive coupling.
it probably wont agitate or spin, but will fill and drain.
you need to remove 2 screws from the control panel, hinge it back and then remove the 2 brass colored clips that hold the cabinet to the base. once you do then pull the entire cabinet forwards to a 45 degree angle and pull it off the base.
then pull the 2 clips off pump and then 2 more on the motor. that will allow you to get to the drive coupling. you will find it to be broken.
replace it with part number 285753a for about 15-20 bucks.
Jan 31, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Kenmore portable compact topload washer model 110 49722992--won't spin!!
sounds like a broken motor coupling( this machines equivelent to a belt. part number 285753a . mounts directly to the motor shaft and connects to the transmission, order a new one it installs between the motor and transmission,assy
Apr 03, 2008 | Kenmore 2.1 cu. ft. Portable Top Load...
Washing Machines Logo
103 people viewed this question
Top Washing Machines Experts
