Question about Yamaha EQ-70 Home Equalizer
Yamaha display bulb
Hi,my display bulb on my yamaha cdx-750e has blown,does anyone know the voltage-wattage of this bulb?its only a small bulb with a orange rubber holder and a red and white wire,i think this cd player is 10 years old.thanks shane
14VAC, 80mA, d=4.12mm
Posted on Apr 28, 2011
  • 120 Answers
I'll have to see a manual but I think its around 6 volts.
Posted on Apr 16, 2010
Left indicator light on dash
it could just be the bulb has blown and needs replacing. or even just fell out. you will need to take the dash out and find out.
Feb 19, 2014 | Cars & Trucks
Can wattage of a led light be converted to voltge
I think it can't. For what I know, mostly the wattage means the brightness of the bulb, not related with the voltage.
Not very farmilar with the technology of LED bulbs, but find a lot knowledge of LED bulbs on a blog here,hope it can be helpful.
Led Basics
Jan 12, 2014 | HKF HS 1004 3W LED Flash Lighting High...
How much fork oil for a yamaha xs 750e 1980. the 750e seems to be differant to the 750. Any help would be a great help Terry
G'day. When I'm in trouble with a fork oil quantity spec.I use the oil level method of setting up my forks. The spec. is an oil level of 105mm from the top of the leg with the fork fully compressed(spring removed of course).Works every time.
Hope this is helpfull
Regards Andrew Porrelli
May 04, 2011 | Yamaha XS 650 E Motorcycles
I have an Akai AT 580 Tuner and the light bulb is blown
Check audiokarma.org first. Then audioasylum.com.
A wonderful wealth of knowledge.
Oct 24, 2009 | Audio Players & Recorders
It doesnt work after battery when dead in car.. i have no remote....i got it with the car and it worked great, now it just open up and nothing....
What has most likely happened is the when the car died it was probably jumped off. Anytime a vehicle is jumped off, especially off a much larger vehicle, a "jump" of voltage is sent throughout the vehicle also known as a surge. The surge travels through the vehicle's electrical system and sometimes blows bulbs, fuses and relays. The back of your radio should have a fuse check it because It's probably blown. If the fuse is good refer to your vehicle manual to locate the fuse panel and find the radio fuse it might be blown. Hope this helps
Aug 03, 2009 | Sony CDX-M630 CD Player
Indicators flash too fast
Hi and welcome to FixYa, Based on your description, possibilities are: 1 of the signal bulb pair has burned out; bulbs used are smaller or of lower wattage; LED type indicator lights are used. Replace flasher with electronic version. Good luck and thank you for using FixYa.
Jun 10, 2009 | 1985 Moto Guzzi Le mans III
Reciever shut off AND WILL NOT TURN BACK ON
Sounds like it could be a major problem. But...It could be as simple as a fuse.
Do you know how to use an Ohm Meter or a Multi Meter??
If not, there is still something you can check, if you feel comfortable taking the thing apart.
1. Power it down.
2. Open it up, and look for blown fuses.
3. You can't always tell by looking...especially if the are "Slow-Blow" fuses.
4. If you know how to use a multi meter, you can check the fuses in place.
4a. You have to turn it on.
4b. Put your multi meter on VAC. Put the probes on both sides of a fuse. If you measure no voltage the fuse is good. If it measures voltage, the fuse is bad. (I know it sounds backwards, but a meter only measures the difference between voltages, and a good fuse will have the same voltage on both sides, hence no voltage)
4c. Replace bad fuses.
5. If you are uncomfortable with the powered on method, you can remove the fuses, ONE AT A TIME, (so you don't get confused...no pun intended), with POWER OFF. A fuse puller is a useful tool. If you don't have one, BE CAREFUL!
5a. Put your multi meter on Ohms. Measure resistance across the fuses. If resistance is real low (like less than 4 ohms), the fuses are good. If the resistance is high (like 1k to infinity), the fuse is bad.
I hope this helps.
Good Luck!
Apr 08, 2009 | Yamaha HTR-6030 Receiver
My low voltage landscape lights are constantly going on and off once the timer activates them initially. I suspect there is a short somewhere, but is there a good way to locate the short besides pulling up...
Your transformer must have output greater of the total wattage required of the entire system. Example: Putting lights that draw a total of 250 watts with only a 180 watt transformer will result some lights not working, or dimming and flickering, or intermittent power outtages. I learned this from experience. Always go with a transformer that has more wattage available than what is needed. Also, using the incorrect gauge of wire can cause the same issue. Wire creates resistance. Distance the power must travel through the wire creates more resistance at the end of your run than the beginning.
Mar 29, 2009 | Garden
I just purchased a yahama rx- v850 av reciever
if you dont mind a lettle customization, just go to radioshack and set your favorite color l.e.d. and wire it in, if you can find a specs diagram for your reciever, you might look up voltage and wattage of the bulb so you can get appropriate resistors for the led, and install that. itll last forever, cost virtually nothing, and its easy to do.
Jan 11, 2009 | Yamaha RX-V461 AV Receiver
Yamaha Receiver RX-V670
Parts list and exploded diagram of yamaha rx-v850 found free here:
https://www.vancebaldwin.com/shop/research_new/YAM/RXV850.pdf
Enjoy. They can get the bulbs for $1.40...
Bsmt Dweller
Sep 07, 2007 | Audio Players & Recorders
Yamaha EQ-70 Home Equalizer Logo
197 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
