Question about Pioneer AVH-P6500DVD Car DVD Player
IPOD, M-CD not working after CNDV-80MT install
I installed the updated CNDV-80MT disc and now I cannot access the Multi CD or the Ipod. They do not show up as an option on the menu anymore.
Also another problem not related to the upgrade I have is the background will not stay set to picture I choose.
AND the night time display on the navi map will not turn on and off when I flip my headlights on and off.
Please help.
I have a used iPod shuffle that works but iTunes does not respond
Here are the instructions for how to setup and register your IPod
· Insert the CD that came with your iPod into your computer.
· Open My Computer, then double-click the iPod CD to start the installation.
· In the resulting dialog, choose your preferred language from the menu choices, then click OK.
· The iPod for Windows Install.
Wizard starts up. Follow the instructions to install ipod software onto your computer, connecting your iPod to your computer (if asked) as follows:
  • To connect iPod shuffle: Remove the USB cap and plug the USB connector into a high-powered USB port on your computer.
Note: High-powered USB ports are generally the ones that reside on your computer or on a powered USB hub. If you want your iPod battery to charge while connected, avoid using the USB port on your keyboard or non-powered USB hub.
· When your computer recognizes iPod, it may update software on your iPod if needed (click Update if you get a dialog that says your iPod needs to be reformatted or restored). When finished, your iPod software will be installed at the default location, C:Program FilesiPod (unless you choose another folder).
· The installer will then install iTunes if it isn't already installed on your computer, or if you have an older version installed than the one that came on your iPod CD.
· When the installation is complete, follow the instructions to restart your computer.
· Once your computer is back up, you should be greeted by the iPod Setup Assistant (if your iPod is still connected). Type a name for your iPod in the top field.
· Choose the "Automatically update songs on my iPod" checkbox if you want to sync your entire itunes music library and playlists to your iPod each time you plug it in. If you want control of what goes onto your iPod, deselect this checkbox.
· If you have an iPod with a color display, you can have iTunes automatically copy your photos to your iPod (using your settings in iTunes preferences) to fill any remaining space by choosing the "Automatically copy photos to my iPod" checkbox. Then choose a folder from the Synchronize photos from menu. If you prefer to copy photos manually, deselect this checkbox.
· Click Next to go to the next screen. If you'd like to register your iPod at this time, click Register My iPod. Click Finish to end the setup process and open iTunes (you should see your iPod hanging out in the iTunes Source pane.
Hope this helps,
Thanks,
Prince
Aug 06, 2009 | Apple iPod shuffle MP3 Player
Ipod wont install
Dear customer,              We recommend you to following the below given instructions to install ipod on your computer.
  1. Visit the Apple Web site to download the latest version of iTunesmag-glass_10x10.gif . All iPods use iTunes as part of their software package.
  2. Determine what generation iPodmag-glass_10x10.gif you have. Depending on how new the iPod you are using is, it will be a slightly different procedure for installing the software.
  3. Plug in your generation five iPod directly to your PC. The newest generations of iPods do not require additional software other than iTunes and do not come with a CD.
  4. Follow the instructions of the “Setup Assistant” provided by Windowsmag-glass_10x10.gif OS. It should pop up when you plug in your iPod using its USB cable.
  5. Use a software installation CD which is included with older iPods. Insert the CD into the disc drive and installation will begin.
Plz rate this solution.. thank you..
Apr 08, 2009 | Apple iPod classic MP3 Player
AUX isn't working when I plug my IPOD into it
Only certain Bose work with the iPod. Check the web or ebay for the correct adapeer.
pita3obn
Dec 14, 2008 | Bose Wave music system Multi-CD Changer...
Ipod nano
Apple iPod is Locked
There is only one way - and it will erase all your songs (applies to most models, not just Nano):
If you lock your iPod nano screen and can’t unlock it
Normally, if you can connect your iPod nano to the computer it is authorized to work with, your iPod nano automatically unlocks. If the computer authorized to work with your iPod nano is unavailable, you can connect iPod nano to another computer and use iPod Updater to restore your iPod software. See the next section for more information.
If you want to change the screen lock combination and you can’t remember the current combination, you must restore the iPod software, and then set a new combination.
Updating and Restoring iPod Software
You can use iPod Updater to update or restore your iPod software. Apple periodically
updates iPod software to improve performance or add features. It is recommended that
you update your iPod nano to use the latest software. You can also restore the software,
which puts iPod nano back in its original state.
- If you choose to update, the software is updated, but your settings and songs are not
affected.
- If you choose to restore, all data is erased from your iPod nano, including songs, files,
contacts, photos, calendar information, and any other data. All iPod nano settings are
restored to their original state.
To update or restore iPod nano with the latest software:
1 Go to www.apple.com/support/ipod and download the latest iPod Update. The update
has the latest software for all models of iPod.
2 Double-click the software installation file and follow the onscreen instructions to install
the iPod update.
3 Connect iPod nano to your computer and open iTunes. The iPod Updater application
opens.
If you’re using a Windows PC and the iPod Updater application doesn’t open
automatically, you can find the updater by choosing Start > All Programs > iPod.
4 Follow the onscreen instructions to update or restore iPod software.
If you use the iPod Updater application and it doesn’t recognize that iPod nano is
connected to your computer, reset iPod nano (see page 45).
If you want to restore iPod software and you don’t have an Internet connection, you
can use the iPod Updater application that was installed on your computer when you
installed the software from the iPod CD.
-Tha Mp3 Doctor
Nov 10, 2008 | Apple iPod nano
Update dvd
type this on ebay, is way cheaper than pioneer websitePIONEER AVIC CNDV-80MT 2008 GPS MAP DVD
Aug 16, 2008 | Pioneer AVIC-D2 DVD Nav/6.5"...
Unlocking my ipod nano
There is only one way - and it will erase all your songs:
information.
combination.
â If you choose to update, the software is updated, but your settings and songs are not
affected.
â If you choose to restore, all data is erased from your iPod nano, including songs, files,
the iPod update.
opens.
-Tha Mp3 Doctor
May 28, 2008 | Apple iPod nano
Ipod security code
information.
combination.
affected.
the iPod update.
opens.
-Tha Mp3 Doctor
May 26, 2008 | Apple iPod nano
Nano i pod has locked silver ipod nano
i forgot my ipod code
help me
Ipod
First I would suggest you make sure the iPod is connected correctly, and that you wait until the iPod has finished updating.
If you are sure of that, you can always restore the iPod to it's original settings.
(I would also suggest that you are using the most updated version of iTunes)
But before you restore your iPod, there are a few steps you can take to try and fix this problem.
If you can’t download a song or other item to iPod nano
The song might have been encoded in a format that iPod nano doesn’t support. The
following audio file formats are supported by iPod nano. These include formats for
audiobooks and podcasting:
 AAC (M4A, M4B, M4P) (up to 320 Kbps)
 Apple Lossless (a high-quality compressed format)
 MP3 (up to 320 Kbps)
 MP3 Variable Bit Rate (VBR)
 WAV
The most common is to reset the iPod. To do this:
  •  toggle the Hold switch on and off ( Set it to hold then turn it off again)
  • Then press and hold the Center and Menu buttons for at least 6 seconds untill the Apple logo appears.
If this does not work I would consider restoring. This means you will loose all your music,pictures, videos..ect. But from it sounds, you don't have anything on your iPod to loose.
the iPod update.
opens.
Apr 09, 2008 | Apple iPod nano
Pioneer AVH-P6500DVD Car DVD Player Logo
203 people viewed this question
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
