Question about MySpace Social Network
Blockage! eh.. Seymour High School has a really good blockage! it sucks. HOw can i get pass it?
  • 72 Answers
Yea. sure. use the following address to view the blocked sites.
CLICK HERE TO VIEW
if you go to this site, you can find a long box in side this address.
just type blocked site name in side that box
press go or hit enter
Posted on Mar 11, 2009
1998 GMC Suburban. When turn key to start there is a clicking sound from below dash near floor on passenger side. When vehicle is running can hear the sound like it is cycling on and off. What is this?
Check your heater/AC intake...the are easily clogged b leaves or debris..Open glove box,remove contents,there should be a latch that drops the whole compartment,and exposes the motor..it has a rubber L-shaped tube on the side..This requires a bit of gymnastics,as in lying upside down on pass.seat...a small flashlght will reveal any blockage,,or poke up in it with a straw until the blockage falls out..Mine had sucked a baggie up in it once..Replace paarts in reverse order. If it stll clicks.look down in defroster vents..a dime got in mne and did the same too..Good luck
Nov 01, 2013 | 2000 GMC Jimmy
Suction stopped. Roller and belt working-in fine order. Checked hoses have not found any blockage. Blowing out air or sucking so little can't feel it with hand on hose end. Help!
Either a blockage or the main air filter is blocked , some it can be washed and others it must be replaced
I would check the owner manual and look at the filter, foam ones can and usually have instructions where they install to wash them.
Dec 11, 2012 | Hoover Tempo Widepath Upright Vacuum -...
Ryobi Whipper Snipper starts, runs but doesn't like to rev, as if it's either flooding or sucking too much air
you've answered your question i would be inclined to be looking at adjusting the high low idle mixture settings and checking for a good spark also check the exhaust is free of obstruction may have a blockage
Jul 18, 2012 | Ryobi Garden
Is there a wiring guide for the Pass and Seymour LSDC163PWV? Which colors are for the Fan control and which for the Light?
Go to the website below for diagram. Under specifications.
https://www.legrand.us/passandseymour/fan-controls/de-hummer/ls-series/lsdc163pwv.aspx
Jul 03, 2010 | Pass & Seymour Pass and Seymour Decorator...
Red light comes on saying bag full or clogged. Bag has only recently been changed so what do I look at next?
You look for a blockage - almost certainly in the flexible hose. Remove the hose from the machine completely (both ends, that is), then switch the machine on and the red light should not come on unless you block the hole on the top of the bag compartment with your hand. Then you need to investigate the hose, to find and remove any blockage. This is not always easy. You can try sucking a blockage out, back the way it came in, either with a second vacuum or simply by reversing it on your Sebo as best you can. This will often pull the blockage to the point where you can get hold of it with pliers or a bent wire or the like. Unless all else fails, and you get desperate, don't try pushing a blockage out with a broom handle or anything like that as you will probably only consolidate the blockage. You should also check in the little trap-door on the underside of the base to make sure all is clear there.
If you need further guidance, just post a reply here and I'll answer as soon as I can. Good luck!
Mar 26, 2010 | Sebo X4 Bagged Upright Vacuum
I am getting the pressure switch blockage and the three red light code. Replaced the pressure switch and still does not work
Hi, the pressure switch won't close error isn't always caused by a defective switch. Occasionally, there really is a blockage in the vent system and that is why there is a pressure switch. You should check for such a blockage, usually caused by a smashed vent cap or spider webs in the vent pipe. Good luck.
Jan 11, 2010 | Goodman Heating & Cooling
I have a egomaxx 1800 vacuum cleaner which is not 'sucking' up at all well. There is no obvious blockage.
Sometimes the blockage is within the hose itself and not easy to spot. The only thing that can keep a vacuum from sucking is somekind of blockage. It is rare that a motor have lost power because of a short thats why it is not sucking, and it would be very obvious because you would smell something burning.
Jun 27, 2009 | Vacuums
Hesitates and cuts out when I accelerates, shakes and sputters!
Fuel filters are cheap and simple to change, so try that first. If that is not your problem it may be your catalytic converter. Before having that replaced, check your fuel return line. You should be able to blow thru the line with your mouth. If you can't, or it's really hard to do. . . then you have blockage. The blockage could be flooding your engine with fuel. Checking the fuel pressure with a gauge from an auto parts store may help you out. If the pressure is really high, then that may be your problem.
Apr 20, 2009 | Jeep Cherokee Cars & Trucks
VACCUM KEEPS SWITCHING OFF /NOT SUCKING
First thing would be to check the bag as it may be full. If the bag is full the machine will overheat quickly. Also check the internal filter in the bag cavity to make sure that isn't dirty.
Next, check there's no blockage in your floor tool or in your telescopic rods.
As for the hose: grab a marble and see if that will go all of the way through the hose. Marble goes through = no (big) blockage. Marble won't go through = blockage.
There possibly could be a blockage in the bend/handle. Grab a bendy coat hanger and undo it, make a small hook on the end, and use it to stick up into the handle to check for a blockage.
To check from the other end get a broom handle and stick that in at the machine end of the hose. If you find a blockage, get the coat hanger, stick it in, and rotate it gently around and hopefully hook whatever the blockage is with the hook on the end.
Mar 29, 2009 | Vacuums
Strong sucking in hose
Sounds like either the stiffeners within the hose have failed, or there is a blockage as you mentioned.
See if the hose feels weak at the point where it collapses. If not, look for a blockage in the vacuum head, or remove the hose at the vacuum head end and look for a restriction in the hose or the vacuum head port.
Jan 23, 2009 | Dyson DC17 Animal Bagless Upright Cyclonic...
MySpace Social Network Logo
55 people viewed this question
Top MySpace Computers & Internet Experts
Nicholas Bannister
Zachary Reed
Tom Del
Level 1 Expert
Are you a MySpace Computer and Internet Expert? Answer questions, earn points and help others
