Question about NexxTech Transparent LCD World Time Clock (631-1463)
Can't adjust month/date etc....
Can't set the month date and day on the dam thing...buttons on back areMODE, SET. ADJUST. RECEIVE, AND SNOOZEIt is a Radio controlled clock meaning it is receiving radio signals from somewhere???Can you find the instructions on how to set the things as I am now very frustrated.The numbers on the back are: 6311447 and it is made by Nexxtech.
1)Press "SET" button for more than 3 seconds until digits of certain area blinks.
2)Press " ADJUST " button to increase digit reading value of year, month, hour, minutes...etc. of the blinking area ( Note: all adjustments are towards increasing increments only. Just cycle if accidentally past the required setting )
3)Press "SET" button once to jump from one area of adjustment to the next...example from calendar to month to hour to minutes to seconds....etc.
4)Press "mode" button to confirm all settings
5)Finished
Posted on Jun 29, 2014
3 Suggested Answers
chrisy3000
  • 63 Answers
SOURCE: How can I adjust the time? The clock is quicker
yes you can adjust the time. usally you hold down the mode button and then press the seconds button, do that until you get the right time.
Posted on Dec 12, 2009
SOURCE: Radio controlled clock model 6302000 - cannot
I have the same clock and had the same problem. My clock was a demo and had no instructions with it. Here is the solution:
1. Pull out the battery and wait 10 seconds then replace the battery. The satellite symbol should start flashing after a few seconds.
2. Put the clock outside or in a window sill till it updates. This could take a couple of minutes.
3. Press the Mode button once to enter programming mode.
4. Press the Adjust button as many times as needed to toggle through the time zones.
5. Press the Mode button once to exit programming mode.
Posted on Oct 08, 2010
How to reset time/date
25592762-obkoyhm2j4njygclebv1o4cu-2-0.pngTwist the wheel on the top of the camera to Settings icon 25592762-obkoyhm2j4njygclebv1o4cu-2-5.png Then follow these steps:
1. Touch [General]
2. Touch [Date/Time Set]
3. Touch the Up and Down on [Year] tab or press the Up and Down button to adjust. Touch or press [OK] to set the [Year].
4. Touch the Up and Down on [Month] tab or press the Up and Down button to adjust. Touch or press [OK] to set the [Month].
5. Touch the Up and Down on [Day] tab or press the Up and Down button to adjust. Touch or press [OK] to set the [Day].
6. Touch the Up and Down on [Hour] tab or press the Up and Down button to adjust. Touch or press [OK] to set the [Hour].
7. Touch the Up and Down on [Min] tab or press the Up and Down button to adjust. Touch or press [OK] to set the [Min].
8. Touch the Up and Down on [AM,PM] tab or press the Up and Down button to adjust. Touch or press [OK] to set the [AM,PM].
9. Touch the Up and Down on [DST] tab or press the Up and Down button to adjust. Touch or press [OK] to set the [DST].
For a simulator view and instructions, follow this link:
http://samsungsimulator.com/output/service/simulator/c5ed71e7-d3c7-47ce-9c7c-a9b632320ee9/#!topic/settings/date_time_set
The manual for the Samsung WB350Fcan be downloaded here:
Global Download Center
Mar 19, 2015 | Samsung WB350F Smart Digital Camera,...
Tip
HOW TO SET DAY / DATE ON AN ANALOG (STEM) WATCH
mcdevito75 here, Over Forty (40) years ago, watch manufactures added, to some of their ANALOG (wind up) and almost all of their DIGITAL (button display) watches the FEATURE of the, MONTH or DAY of the WEEK and the DATE, not only was the time of day available but also the DATE which you no longer had to go searching for, it was readily available on your wrist. The PROBLEM came with SETTING the CORRECT MONTH or DAY of the week and the DATE as some MONTHS HAD 31 DAYS rather than 30 DAYS, this meant you had to CYCLE your watch at least 62 times to get to the CORRECT DATE and mant times, when you finally did reach the CORRECT DATE, the day of the week was off, meaning more CYCLES thru the 24 hours.-------- HERE is the EASY way to SET the MONTH or DAY / DATE on your QUARTZ / MECHANICAL (STEM) watch without haveing to go thru the 24 hour cycle so many, many times. Not only is this, WEAR on your fingers, you can also damage your watch with some many cycles of the 24 hours to SET the correct MONTH or DAY / DATE. ------ HERE ARE THE BASICS,---------- Your ANALOG or STEM watch either QUARTZ or MECHANICAL should have a TWO (2) position STEM we are only familiar with the ONE (1) position we use to set the TIME, there should be TWO (2) positions to the STEM. First pull out the STEM to adjust the MONTH or DAY depending on your watches display, if your watch DISPLAYs the DAY of the week, set the DAY to one (1) DAY before the DAY you want, don"t worry about the DATE (number) yet. Once you have the MONTH or DAY set, push the STEM back into the watch, NOW with a finger nail just under the STEM (usually from the back of the stem as there is more room) gently lift the STEM to it"s first position, It may take some practice so be patient, once the STEM is in it"s first position you should be able to turn the STEM to adjust the DATE (number), if so Adust the DATE (number) to ONE (1) DATE before the DATE you want, This way your watch will be adjusted to change the DAY / DATE at the correct time. Once you have the DATE (number) adjusted to ONE (1) DATE before the DATE you want, push the STEM back into the watch, NOW pull the STEM out to adjust the time, go thru the 24 hour cycle to adjust to the correct DAY DATE (number) and time of day.------------ Your QUARTZ or MECHANICAL (stem) watch is now adjusted to the correct DAY / DATE and will change at the correct hour which is generally 12--1 AM.
on Jul 20, 2010 | Watches
Tip
on Jul 09, 2010 | Watches
How do you set the alarm clock for a model:38229-1 clock
Press mode key at any time to exit.
Press mode, then press adjust to change time zones.
TO SET TIME AND DATE:
Press and hold alarm on/off for about 5 seconds until hour flashes.
Press adjust to change hour.
Press alarm on/off to move to minutes. Press adjust to change minutes
Press alarm on/off to move to seconds. Press adjust to change seconds
Press alarm on/off to move to month. Press adjust to change month
Press alarm on/off to move to date. Press adjust to change date
Press alarm on/off to move to day of week. Press adjust to change day of week
Press mode key to save to exit.
TO SET ALARM:
Press mode to go to alarm screen (AL shows above temp)
Hold the alarm on/off button for about 5 seconds and the hour will flash.
Press the adjust button to change the hour.
Press the alarm on/off button again to move to minute
Press the adjust button to change the minutes
Press the mode key to save and exit
Aug 22, 2011 | Audio Players & Recorders
I can't set the time on the Timex 1440
To set the time on your Timex 1440 Watch, please follow these directions:
1. Press and hold MODE (Upper left button)
(HOURS will flash and you'll be in Alarm Mode).
2. Press MODE again to enter TIME mode.
(SECONDS digits will flash.)
3. Press ADJUST (bottom right button) to set SECONDS to zero.
4. Press START/STOP (upper right button) to select MINUTES
5. Press ADJUST to change
6. Repeat to set Hours, Date, Month, and Day of the week.
(Go through 12 hours to set AM or PM)
7. Press MODE when finished
8. To display DATE from TIME display, press START/STOP
9. With DATE displayed, press and hold START/STOP, then press ADJUST to change display between DATE-MONTH
10. With TIME displayed, press and hold ADJUST, then press MODE to switch between 12 and 24 hour format.
I hope you are now able to set the time on your watch! If you appreciate these instructions, please remember to rate this post.
--Sandy
Apr 18, 2011 | Timex Watches
How to set dates, etc.
mcdevito75 here, The stem should be 2 position, first pull the stem out to adjust the DAY ot Month, push the stem back in, now slip a fingernail just under the stem anf lift to the stems first position, this should allow you to change the DATE, adjust to 1 day before the DATE you need, now lift the stem to adjust the time, go thru the complete 24 hour cycle to adjust the DATE and time of day. You should have the DAY or Month and correct date and your watch will change the DAY, DATE at the proper time also.
Jul 08, 2010 | Bulova Watch
Armitron Watches
From the time telling mode press the set button the seconds will flash.
Press the mode button the hours will flash
Press the adjust button to change the hours
Press the mode button the minutes will flash
Press the mode button the month will flash
Press the adjust button to change the month
Press the mode button the date flashes
Press the adjust button to change the date
Press the mode button the day flashes
Press the adjust button to change the day
Press the set button when done.
Mar 11, 2008 | Watches
Setting date and time on a Mitsubishi VCR
My Solution for Mitsubishi HS-U500 VCR setting the date for 2008 and beyond:
I had same problem with this old unit as everyone else has.  Since the year really doesn't matter (except maybe when you're setting to tape near a new year), here's how to get the day and dates correct:
On the remote, push Menu button, then select "First time setup", then select "Set the Clock", then select the month.  Now, start adjusting the YEAR and watch how the "days" change with the years.  Adjust the years so that the "Day" (Monday, Tuesday, etc.) matches the date (1,2, 22, 23, 28, etc.) in the month.  Then cycle thru the rest of the items and get out by hitting menu button again.
That's it!  That's my quicky solution.  Caveat: This may not be permanent with leap years and the like, so you may need to check it from time to time to make sure the days match up with the dates.  But you can do this when you go to set up for timed taping.  Hope that "FIXes" it for "Ya"!
Jan 22, 2008 | Mitsubishi HS-U595 VHS VCR
How do I change time on timex watch?
These are settings for the Timex SPORTS 1440 Magnetism (5b841 -W163US)
These are for the 4 button SPORTS 1440 (not 6 button) - they will also work for the 1440 SPORTS "Informer" model wrist watch - you will NOT find these instructions on the Timex website - only the 6 button which will not work on these watches is on that site!
TIME AND DATE
  1. Press and hold MODE until HOURS digits flash (you'll be in Alarm Mode) Press MODE again to enter TIME mode, SECONDS digits will flash.
  2. Press ADJUST to set SECONDS to zero.
  3. Press START/STOP to select MINUTES.
  4. Press ADJUST to change.
  5. Repeat to set HOURS, MONTH, DAYS, and DAY of WEEK. Go through 12 hours to set AM or PM.
  6. Press MODE when done.
  7. To display DATE from Time display , press START/STOP.
  8. With DATE displayed press and hold START/STOP, then press ADJUST to change display between DATE-MONTH and MONTH-DATE.
  9. With TIME displayed, press and hold ADJUST, then press MODE to switch between 12-and 24-hour format.
ALARM AND HOURLY CHIME
  1. Press and hold MODE until HOURS digits, DAY, and A or P (for AM or PM) flash.
  2. Press ADJUST to change HOURS digits. Go through 12 hours for AM or PM.
  4. Press ADJUST to change.. Press MODE when done.
  5. Press and hold ADJUST, then press START/STOP to turn chime on/off. Press START/STOP again to turn alarm on /off. Release START/STOP when done.
CHRONOGRAPH
  1. Chronograph will count up to 24 hours. Lap times are not stored. After 40 minutes chrono display changes from seconds to minutes.
  2. With time displayed, press MODE to select Chrono Mode.
  3. Press START/STOP to start.
  4. Press ADJUST to view lap time. Press again to sesume lap timing.
  5. Press START/STOP to stop timing . Press ADJUST to reset chrono to zero.
  6. Repeat for successive laps.
Have fun! - Not a bad watch for the money! - - Silver Bullet
Mar 16, 2007 | Timex 5B841 Wristwatch
NexxTech Transparent LCD World Time Clock (631-1463) Logo
322 people viewed this question
Top NexxTech Audio Players & Recorders Experts
Josh Whitehead
Josh Whitehead
Pieter Vleeshouwers
Pieter Vleeshouwers
Willem.
Willem.
Are you a NexxTech Audio Player and Recorder Expert? Answer questions, earn points and help others
