Question about Sony Grand WEGA KF50WE610 50" Rear Projection HDTV-Ready Television
My sony kds50a2000 failed lastnight. Bulb only?
My sony kds50a2000 failed lastnight. I turned the set on and the green power light blinked for a while. I then unplugged the power, waited a few minutes and powered it back on. Eventually the red lamp indicator light blinked. After removing the bulb I noticed a conductor attached to the filament is broken. The set has 6-8k hours on it. I ordered a replacement bulb but am wondering if there may be anyhting else that could cause the bulb to blow out this way. I definitly heard arching when the set is powered on. Obvously its because the bulbs circuit is not complete but could somethign else have caused the bulb to blow? Is it normal for a bulb well withing its life expectancy to blow ot this way?
  • 139 Answers
There could be something else that caused the lamp to fail but if it has 6 to 8 thousand hours on it that is the expected life and it is not uncommon for a lamp to fail this way.
Posted on Mar 17, 2009
I have a sony kds50a2000 and it wont turn on at all. When i do try to turn on the green light blinks many times then its followed by the red lamp light blinking continuously and wont stop blinking unless i...
You should Google the model number with "problems" as there are several sites with good information on this set.
I would suspect this model does not have a color wheel but if it does it would be suspect number one.
Sets that use a wheel that turns at 12,000 rpm will fail. I would (if I was working on the set ) take rear cover off and try to localize where the sound is coming from) Likely: the ballast that powers the lamp will buzz sometimes when bad or lamp is bad.
Remove lamp and inspect to see it is not shattered.
A fan (one on the lamp) could cause this but rarely.
Look, listen, and do some research with Google.
last resort Call Sony with model number (expect them to tell you take it to shop--usual response)
Apr 09, 2012 | Sony KDS-50A2000 50" HDTV
Blink on standby green after awhile then blink red
The blinking green light signals that the inverter board is charging the bulb. If the blinking goes to red it means that this process has failed because either the inverter board is not full operational or the bulb itself has failed.
Most likely you will have to replace the bulb - here it is
http://www.partstore.com/Part/Sony/Sony/KDSR60XBR1/Royal+Philips+Electronics/Philips+Lighting/F93087600RL/New.aspx
If this doesn't fix it then you will have to check the inverter and power boards and replace the failing one.
Here is the ballast/inverter
http://www.partstore.com/Part/Sony/Sony/KDSR60XBR1/Sony/Sony/146893613/New.aspx
Here is the power board
http://cgi.ebay.com/SONY-KDS-R60XBR1-G-POWER-SUPPLY-1-867-733-11-Free-S-H-/120703310513
Mar 27, 2011 | Sony KDS-R60XBR1 60" Projection HDTV
I have a sony tv model kdf-50e2000,and it has a problem with the picture going blank,the only light that on or flashes is the green (POWER) light. when turning the set on the green light blinks as it...
You tv used lamp XL-2400 or also known as F93087500. It is very common for this bulb to fail and have the exact symptom you are experiencing. I cant count how many times I have seen it.. Replace the lamp with either the exact Sony or an OEM and you will be back in business..
Good Luck!!
Dec 28, 2010 | Sony KDF-50E2000 50" HDTV
KDS50A2000 Green light comes on briefly followed by red blinking light. 4 on then pause, etc. etc. Problem???
I tried this solution last night. had a similar issue. opened up the back panel and cleaned the fan. just for the fun of it, i tried to turn the tv on and presto. it works fine now and i probably saved a bundle. thanks!!!
Jan 25, 2010 | Sony KDS-50A2000 50" HDTV
Sony KDS50A2000 power LED flashes green, then clicks off and flashes red four times over and over.
4 blink is a fan error. This is caused by one of the three fans not spinning fast enough or has stopped completely. The fan that usually causes this error is the one over the bulb and toward the back of the set. The repair is not expensive, but to do the service correctly you must get all the dust out of the tv or the fan will clog up very fast again. Getting the dust out is kida tricky because you have to get the dust out without contaminating the light engine, if it gets contaminated you will get colored splotches on your picture. I recommend getting a pro to fix it, the repair should be fairly reasonable around $150 to do the repair. The fans are not that expensive.
Oct 08, 2009 | Sony KDS-50A2000 50" HDTV
SONY KDF-E55A20 5 red blinking lights on power button
Symptom shows Lamp is weak in result and causing restart of TV again and again. Your TV requires new lamp as per following part number...
A1085447A* LAMP BLOCK ASSY XL-2200U
It is available in Sony Accessories Store for $200 and replacement procedure is written in instruction manual of TV.
Always buy Sony original lamp for TV and avoid aftermarket / cheap lamp for TV safety.
May 18, 2009 | Sony KV-36FV26 TV
I turn on the 4805,green led blinks & bulb does not come on?
After a few minuets does the green blinking light turn to a red blinking light?
If so the problem is the lamp did not strike.Either the lamp has failed (most likely) or there is a problem with the power supply (less likely)
Feb 12, 2009 | InFocus ScreenPlay 4805 Multimedia...
Sony LCD television will not power on.
I get 5 blinking red lights for about a minute or so before it powers back down. The Sony TV has a specific light that i presume is supposed to light up when the bulb is out. I'm unsure if this is what it is.
no picture, no sound. tries to boot with green light blinking a few times. then goes to red blinking light, six in all, then waits a few moments, then another 6 blinking red light.
Bulb was already replaced several months ago but we do have the TV on for long periods of time.
Jan 15, 2008 | Sony Grand WEGA KF50WE610 50" Rear...
Sony Grand WEGA KF50WE610 50" Rear Projection HDTV-Ready Television Logo
252 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
