1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not, press the Power button once more.
8. Your printer should respond as normal.
NOTE: There are a couple of things that might affect this. If the print head is clogged or needs replacing this will not work. Also, I've read elsewhere that it's a problem if the waste ink resevoir is full (shouldn't be the case, but who knows?), and replacing the resevoir is a 3 hour PITA that only few regular joes will find worth the time.
A great reference for the printer 'do-it-yourselfer':
http://www.fixyourownprinter.com
Be sure to check their forums for other end user's solutions.
http://www.usa.canon.com/consumer/contro...
