Question about Fisher Refrigerators
My fridge is on the coldest setting..not cold at all..Also freezer is the same..what do i need to do?
    Sergeant:
    Champion:
  • 289 Answers
Hi..It's possible that the compressor is dead or not
working properly,try to dust off the coils in the back.
check it out..
thank u..
rate me..
Posted on Mar 10, 2009
Freezer is working fine but the Fridge part is not
i take it the unit is frost free you need to replace the defrost element in the freezer whats happening is your freezer sends cold air through small holes to the fridge compartment but when the freezer cant self defrost those holes freeze over thus no cold air into the fridge compartment get a tech in to check the element shoulnt cost more than $ 80.00
Apr 21, 2010 | Refrigerators
Freezer is fine but the lower compartment is just cool not cold temp setting is turned to coldest
Firstly turn you temperature setting to the MIDDLE in between cold and coldest. This will allow cold air coming from your freezer to go into your fridge. if this does not seem to change your problem, check to see if the air vent at the back, top of the fridge is allowing air to flow from the freezer to the fridge. if there is no air flowing there may be a clogged ice drain or pan. usually if this is clogged you can unplug your fridge for 24 hours with the doors open. and it will manually melt the ice buid up.hope this helps
Thanks
Oct 12, 2009 | Magic Chef Refrigerators
Refrigerator top rack is warm. Temperature shows 65 degrees
if your freezer can make ice and the ice is dry, the problem is simply air flow into the refig section. A very common cause for a service call that wasnt needed for reefers is the settings. One setting OFF 1-10 usually, operates the compressor. The remaining setting will say , for colder freezer or similar, It opens a little flapper door between the freezer and the fridge section. If you set that one to max or coldest freezer it will actually starve out the fridge section for air ,and you get a cold freezer and warmer box! It happens everytime someone has the problem , its too warm! they peg both controls to coldest! The compressor will coll the freezer sufficiently even if set to 1 and the fridge should be cool too if the setting isnt pegged to coldest setting thus closing down fridge air and making the freezer colder which isnt ever required!
Aug 25, 2009 | Jenn-Air JSD2695KES Side by Side...
Freezer cold, not fridge
24 hours It should be good Do check temp settings.
Aug 05, 2009 | Candy CPCA240FFK Bottom Freezer...
Freezer fine refrigerator is not as cold as it should be. dial is set to coldest position. butter is soft and milk is on verge of spoiling
do you notice ice built up on freezer section back wall if so you have a defrost problem if not you have a freon problem also make sure the freezer setting is not on its coldest setting this actually controls the air flow to the fridge section both freezer and fridge need to be set about half way
Jul 12, 2009 | Refrigerators
Whirlpool intgrated fridge/freezer is not keeping
7 is coldest. but how cold is the freezer? all cold is made in freezer. ma be developing a frose problem
Jul 06, 2009 | Whirlpool ED2GHEXN Side by Side...
My fridge isn't cold.
so get the gas filled in ur compressor
Jun 25, 2009 | Refrigerators
GE TFX26KRDA WW 2001 side by side refrig/freezer w warm fridge
Cleaned the condenser coils which were dusty but not severely so. Checked the evaporator coils which were NOT iced. Reset the fridge to coldest setting and freezer to #5 (mid range of temperature) and waited a full 36 hours. Fridge temp is 40 F and freezer is about 0F. Not sure what is different except coldest setting on fridge. Warm weather is here but not warm enough to require AC. Temps in late afternoon in house about 77-80F. Any thoughts are appreciated because I suspect this problem is not completely resolved.
Jun 20, 2009 | GE Hotpoint Top-Freezer Refrigerator
Freezer -5 Fridge 50
You have a defrost problem. Refrigerator gets cold via freezer. If blocked with frost, will restrict cold air into refrigerator.
Apr 26, 2009 | Refrigerators
Refrigerators Logo
79 people viewed this question
Top Fisher Refrigerators Experts
Charles T Nevin
Charles T Nevin
Joseph Hoffmann
John Tripp
John Tripp
Are you a Fisher Refrigerator Expert? Answer questions, earn points and help others
