Question about Canon MultiPASS MP390 All-In-One InkJet Printer
Waste ink near full
How do i change or empty the waste ink resevoir?
    President:
  • 2,692 Answers
Basically you open the printer .Remove the ink jets and soak up as much ink for the try as you can.
Posted on Mar 12, 2009
Waste ink nearly full
Hi and welcome to FixYa!
If the waste ink pad is nearly full you will need to have it replaced or reset the purge counter to get rid of the message. Please be informed that even the message is resetted theres a tendency that the inkpad will overflow and you may find spill at the bottom of the printer.
Hope this helps and thank you for using FixYa!
Nov 29, 2010 | Canon Office Equipment & Supplies
My Canon MP390 Printer has come up ''Waste Inn Tank nearly full'' What should I do
CANON printers "compute" the "fullness" of the waste-ink container, based on the number of pages printed, and the "density" of the ink on each page. So, this calculation has produced a "nearly full" prediction. Take the printer to a qualified technician.
They will empty the waste-ink container, and "reset" the electronics in the printer, back to "zero-per-cent-full".
Aug 05, 2010 | Canon SmartBase MP390 All-In-One InkJet...
Waste ink near full. How do I empty this?
the waste ink is the pads in the printer where the printer cleans the carts (ink). When they fill up they need to be replaced i would suggest taking this printer to a printer shop for replacement. The reason is because the printer has a waste counter on it and it needs to be reset before the error will go away. I would call around your area and see if they can do it and how much. If you reset the counter and continue printing the ink will adventually over flow and can cause serious damage to the printer. I would also call up canon and see what they recommend.
Steven.
hope this helps :)
Apr 21, 2010 | Canon PIXMA MP780 All-In-One InkJet...
Waste ink near full - how do I empty it?
Hi
This works on the F30, F60, and F80.
Resetting the Waste Ink Volume Counter
1) Enter SERVICE MODE.---
By pressing Menu-Copy-#
2) Select TEST MODE.
3) Select [8] PRINTER TEST in TEST MODE.
4) Select 3. [EEPROM CLEAR].
5) Select 0. [INK COUNT].
6) Press the [OK] key.
7) Press the [Stop/Reset] key (returning to the state of 3)), and then press the [ON/OFF] key.
Skip step (6) since there is no [OK] key on F30 printers.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Jan 23, 2010 | Canon MultiPASS F60 All-In-One InkJet...
What does Waste Ink nearly full mean? Canon MP370
If you peel enough apples, and throw the "waste" apple-peel into the basket, eventually the basket gets nearly full, and must be emptied.
Similarly, if you print enough pages, some of the ink becomes "waste",
and that "waste-ink" goes into a small sponge-and-bucket apparatus.
So, take the printer to a qualified technician, and get the printer serviced.
Nov 23, 2009 | Canon MultiPASS MP370 All-In-One InkJet...
Tank absorber full and lights blinking
The POWER Lamp Flashes Orange Eight flashes: Waste ink tank almost full
The printer has a built-in waste ink tank for the ink used during print head cleaning. Eight flashes indicates that the waste ink tank is nearly full. Press the RESUME/CANCEL button to cancel the error so you can continue printing. Before the waste ink tank becomes completely full, contact a Canon service representative.
Note
Canon recommends that you call for service as soon as this error occurs. Once the waste ink tank becomes completely full, printing will no longer be possible.
Sep 14, 2009 | Canon i350 InkJet Printer
How do you find the waste ink collector on a printer/scanner ?
Inkjet printers have a fibrous pad inside them that collects the waste ink from cleaning the print head. Over time, this pad fills up with ink and can no longer hold any more. When this occurs, the printer indicates a "waste ink tank full" error.
The waste ink absorption pads are inside the printer, in the very bottom. They are usually soaked with ink when full and are very messy.
Replacing the waste ink absorption pads is something an authorized canon service facility can take care of for you.
May 18, 2009 | Canon PIXMA MP170 All-In-One InkJet...
Where is a waste ink i have error message says WASTE INK NEAR FULL help me on that, thanks
I have had this problem. There is a counter in your printer that must be reset to move on. The ink tank may not be full, but the counter estimates it is full (and maybe it is an instruction to you to buy a new Canon printer), and to actually empty the ink tank would be an uneconomical task. How do you do it, there are a number of helpers here so Google: MP730 waste ink near full.
Apr 27, 2009 | Canon MultiPASS MP730 All-In-One InkJet...
The printer is indicating "waste ink near full"
Hey,
The waste ink pads should generally be around the cartridge carrier, or below, possibly at the bottom of the printer.
have a look at this page for instructions on how to reset the counter after the waste ink pads have been cleaned or replaced.
http://www.allthefaqs.net/forum/viewtopic.php?t=3770
Let me know if you need anything else.
Thanks,
Ekse
Mar 06, 2009 | Canon PIXMA MP780 All-In-One InkJet...
WASTE INK TANK NEAR FULL.
see solution to INK TANK NEAR FULL SMART BASE 360
Oct 21, 2008 | Canon SmartBase MP360 All-In-One InkJet...
Canon MultiPASS MP390 All-In-One InkJet Printer Logo
123 people viewed this question
old marine
old marine
