Question about Microsoft Windows XP Professional
I want to delete the annoying files...
I have 25 files that each are 50MB. Those are "File" type files. And every time I want to delete them, I receive the following message: "Cannot delete. Cannot read from the source file or disk." I tried to use all deleting software, and nothing happened. And I don't want to reinstall the operating systems because if I do, then I have to reactivate it, and I don't want to reactivate it. When I looked for the Google MoveOnBoot software, it was unavailable, and I'm sure that that software can delete those files.
I am running Windows XP Service Pack 2. Can anyone help me delete those files?
Thank you.
  • 477 Answers
Hello, where do you find this files? maybe its a permission issue.
first go on the map ->tools->folder options and view
and unmark "user simple file sharing" ->ok
then rightclick on the file and "properties" ->security tab
check the permissions. click edit ->add everyone and set full rights. try then delete the file.
I want to delete the annoying files... - moz-screenshot.pngmoz-screenshot-1.png
Posted on Mar 10, 2009
When I wanted to delete a file It gives an error message "Cannot delete nul: The parameter is incorrect"
Right click the file, Security, advanced, owner. Change the ower to the user you are using to delete the file. Apply and OK, to complete the taking owership of the file.
Delete the file.
Mar 11, 2011 | Computers & Internet
Tip
Solution to cannot delete file / folder error
Many times you need to delete some annoying file, but you cannot, as it is being used by some unknown application in your PC or some access permissions are set on the file, which prevent you to delete it. The easiest solution for these was to restart the PC & then try to delete it. But with Unlocker in your hand, you won't need to restart anymore in such situations. For the situations like these, Unlocker is the solution. It not only tells which process is using the file / folder, but also unlock the handles locked by the process, which actually are preventing the actions on the file. The result of this is you can do whatever operations you want on those files. You must have seen these Windows error messages many times. Now you can take care of these error in seconds. * Cannot delete folder: It is being used by another person or program * Cannot delete file: Access is denied * There has been a sharing violation. * The source or destination file may be in use. * The file is in use by another program or user. * Make sure the disk is not full or write-protected and that the file is not currently in use. No more of these annoying errors. Simply right-click the folder or file and select Unlocker. If the folder or file is locked, a window listing of lockers will appear. Simply click Unlock All and you are done. You can download Unlocker from here LINK Have a look at this video to know how to use Unlocker Note : Some antivirus protections may detect some contents of installer as adware. But i assure you that Unlocker is clean & a must have tool for every computer.
on Jun 16, 2010 | Computers & Internet
Tip
Delete an undeletable file...
Delete an "undeletable" File.
Open a Command Prompt window and leave it open.
Close all open programs.
Click Start, Run and enter TASKMGR.EXE
Go to the Processes tab and End Process on Explorer.exe.
Leave Task Manager open.
Go back to the Command Prompt window and change to the directory the AVI (or other undeletable file) is located in.
At the command prompt type DEL <filename> where <filename> is the file you wish to delete.
Go back to Task Manager, click File, New Task and enter EXPLORER.EXE to restart the GUI shell.
Close Task Manager.
Or you can try this:
Open Notepad.exe
Click File>Save As..> locate the folder where your undeletable file is Choose 'All files' from the type box
Click once on the file you wanna delete so it's name appears in the 'filename' box.
put a "at the start and end of the filename (the filename should have the extension of the undeletable file to is will overwrite it)
click save,
It should as you to overwrite the existing file, choose yes and you can delete it as normal.
Here's a manual way of doing it. I'll take this off once you put into your first post zain.
1. Start
2. Run
3. Type: command
4. To move into a directory type: cd c:\*** (The stars stand for your folder)
5. If you cannot access the folder because it has spaces for example Program Files or Kazaa Lite folder you have to do the following. instead of typing in the full folder name only take the first 6 letters then put a ~ and then 1 without spaces. Example: cd c:\progra~1\kazaal~1
6. Once your in the folder the non-deletable file it in type in dir - a list will come up with everything inside.
7. Now to delete the file type in del ***.bmp, txt, jpg, avi, etc... And if the file name has spaces you would use the special 1st 6 letters followed by a ~ and a 1 rule. Example: if your file name was bad file.bmp you would type once in the specific folder thorugh command, del badfil~1.bmp and your file should be gone. Make sure to type in the correct extension.
on Feb 11, 2010 | Computers & Internet
My cd rom some time working, other time is not working! so what i do?
It happens if the upper and lower filters are corrupted. By removing both or anyone of the files will resolve the issue. To do so, please follow the below steps (Note: Please delete the excat entry in the steps below. If you do not find the entries ignore it. Do not delete any other files that will screwup your computer):
1. From the Windows Vista default Start menu, point to All Programs, Accessories, and then click Run.
2. In the Run dialog box, type: Regedit and Click OK.
3. In the User Account Control dialog box, click Continue.
4. In the Registry Editor window, locate and then click to select the following registry subkey: HKEY_LOCAL_MACHINE/System/CurrentControlSet/Control/Class/{4d36e965-e325-11ce-bfc1-08002be10318}
5. From the File menu, click Export.
6. In the File name dialog box, type: Savedkey, and then click Save.
7. Click the REG_MULTI_SZ data type UpperFilters file, and then from the Edit menu, click Delete. When you are prompted to confirm the deletion, click Yes.
8. Click the REG_MULTI_SZ data type LowerFilters file, and then from the Edit menu, click Delete. When you are prompted to confirm the deletion, click Yes.
9. In the Registry Editor window, from the File menu, click Exit.
10. Shut down Windows® and restart the computer
thanks and regards
Anil.B.R
Sep 26, 2010 | Computers & Internet
Computer question When trying to get to websites I have always gone to a page pops up that says:http://ad.yieldmanager.com/st%3F_PVID%3DNU8xqWKIgrk4fT3QSvqSzwFMQ9EQf0s3.EwACIXL I delete it and it often...
You should check or use new hosting services, Check experience reviews and consumer opinions to get unbiased recommendations on web hosts. http://poweruphosting.com
Dec 28, 2009 | Dell Inspiron 531s Desktop Computer
Cannot delete my bad files...
Could be a process issue stopping you deleting the files. Try downloading unlocker (http://ccollomb.free.fr/unlocker/) and see if this helps.
If not it might be an 8.3 naming convention issue. Go to DOS prompt to a "dir /x /a". Rename the file to less than 8 characters using the SHORT name only. Then try deleting the file.
Apr 01, 2009 | Microsoft Windows XP Professional
My bad files cannot be deleted!!!
I would Boot into "DOS" or to the C:> prompt WITHOUT loading windows, (from the same window that you enter safe mode from), and find the suspect files and delete them.  del <filename.ext>
Mar 29, 2009 | Microsoft Windows XP Professional
Cannot delete annoying files...
you have done so many things and i can understand how annoying it is. why dont you try to install avast antivirus, update it and it try it hope it will work
Mar 26, 2009 | Microsoft Windows XP Professional
Annoying files cannot be deleted...
First I recommend you try deleting the files from the Windows safe mode... it might work, or you an use the deleting software Unlocker
http://www.softpedia.com/get/System/System-Miscellaneous/Unlocker.shtml
Mar 20, 2009 | Microsoft Windows XP Professional
I cannot delete my unwanted files
If you are sure about those file to delete them then you can use this easy tool from malwarebytes
http://www.malwarebytes.org/fa-setup.exe
Feb 12, 2009 | Microsoft Windows XP Professional
Microsoft Windows XP Professional Logo
66 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
