Question about Kenmore Dryers
I have a grinding sound (like metal on metal) when I turn my Kenmore 70 Series dryer on. So right now we are not using the dryer. Any solutions. I was going to open the top up but cannot figure out how to do it.
  • Kenmore Master
  • 3,361 Answers
Your drum seals may need replacing.
Unplug the dryer.
Remove 2 screws under the lint filter flap.
Raise the hood by prying under the front top corner.
remove 2 screws from the top right and left front inside corners.
Remove the door panel by lifting up.
unplug the door switch wires.
remove the belt from the motor pulley.
remove the drum
also check the drum rollers attached to the inside rear cabinet.
Posted on Mar 10, 2009
Where can i find the door switch on the kenmore 70 series dryer
the door switch is located inside the door on top left or top right of the dryer, if it is one of the newer 70 series dryer it will be on the inside bottom towards the middle
Apr 13, 2014 | Kenmore 63942 Dryer
Kenmore dryer 70 series drum not turning
http://www.youtube.com/watch?feature=player_embedded&v=bJ5TNlzHKhA
Jun 06, 2012 | Kenmore Dryers
I have a kenmore 70 series dryer and it has been making a metal on metal sound as it turns for the past couple of days. Do I change bearings or rollers or what? It is heating up fine and was working...
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Apr 05, 2011 | Dryers
I have a Maytag Heavy Duty Quiet Series 200 Dryer, and when I turn the dryer on is makes a horrible screeching sound. Like metal grinding against metal. What do I do?
That's easy, first of all you must have the Dryer on flat floor I mean verticly right. And try not to put too many clothes to get dried.
Sep 12, 2010 | Maytag Dryers
Have a Kenmore 70 series. It"s squeaking while running. Lubricant? Bearing?
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
heatman101
Asker's Testimonial "That answer was very informative - thank you for taking the time to educate me. " - teresa241964
Aug 30, 2010 | Kenmore Dryers
How do you turn off the dryer signal on kenmore 70 series dryer
On a 70 series dryer, the knob on the far right of the panel controls the signal. You can turn it left or right to set the signal to "On" or "Off."
If you've set it to Off and the signal still comes on, that switch that sits behind the knob is bad. It's the same switch that controls when the dryer starts. You can either try to repair it (by bending the contacts back into their original alignment) or replace it. A new switch is less than $10, and you can get one many places online, including from PartSelect.com:
http://www.partselect.com/PartDetail.aspx?inventory=345390&SourceCode=3
May 20, 2010 | Kenmore 63942 Dryer
63942 Dryer: how do you turn off the dryer signal on kenmore 70...
Hi, you can turn the signal off by using the start button on the dryer (located on the right side of the panel under the words "Push to start dryer"). Turn the knob to the left to turn the signal off, or to the right to turn it on. Each side should be labeled, but the lettering may have worn off over time.
If you've turned the knob to the left and it still signals at the end of a cycle, the switch that controls the signal may be broken.
May 18, 2010 | Kenmore 63942 Dryer
Kenmore 80 series electric dryer. metalic sound/burning smell
When i put clothers in my dryer it does not move and it make a sound when i push the start buttom
Feb 24, 2010 | Kenmore Dryers
Kenmore 70 series dryer shuts off and won't restart
IT SOUNDS AS THOUGH THE MOTOR IS OVERHEATING AND SHUTTING ITSELF OFF. THAT IS ABOUT THE ONLY THING ON THE DRYER THAT WOULD SHUT IT OFF AND NOT ALLOW IT TO START AGAIN RIGHT AWAY, BUT LET IT START AFTER A WHILE. MAKE SURE THE MOTOR TURNS FREELY. IT SHOULD NOT DRAG OR HUMM WHEN TRYING TO START.
Jan 28, 2009 | Kenmore 73952 Gas Dryer
Kenmore 70 series model # 96573220
Sounds like the push to start switch has gone bad. Not to expensive to fix, and pretty easy to do as well. You can remove the rear of the console, remove the push to start switch (lift the tab, then turn to unlock) and replace. Be sure to mark your wires so they go back in the right order. Jim
Nov 18, 2007 | Kenmore 60172 Electric Commercial Dryer
Dryers Logo
118 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
