Question about Apple iPod nano
My iPod has moisture inside. It turns on but
My iPod has moisture inside. It turns on but doesn't hold a charge. Water got spilled on my iHome without my knowledge. When I atttached my iPod it drew the moisture inside. What can I do to solve the problem?
Not sure if this will help, however when a cell phone gets moisture in it, you stick it in rice and the rice will draw the moisture out. Leave it in the rice for 24 hours and see if this helps. It's worth a shot. Good luck!
Posted on Apr 18, 2009
Iphone4 will not playing music through docking station Sony XDR-DS12IP... Iphone was working with system perfectly until sunday? still manages to charge iphone ? Iphone message iphone not configured...
first return sony and get ihome because sony is bad at docky station(not affending ps) or you can do is take it where you got it and bring the ios deviece and get it checked if it works congrauts if it doesn`t BUY IHOME.
Aug 23, 2011 | Sony HD Radio and Dock Docking Station,...
Ihome ip87 it wont turn on it only charge my itouch?
If unit is plugged in and doesn't respond, try resetting the unit by
following these steps:
a) remove iPhone/iPod from dock
b) unplug unit from power source
c) remove back up batteries
d) wait 1 hour, then resume use
Jun 03, 2011 | SDI iHome2Go (IH80B) (Black) Docking...
My ihome want charge my iphone 4
Your iHome may be an older model with an the wrong charge type. Different iPhone / iPod generations use different charge voltage with iPhone requiring a higher voltage than your iHome gives. My suggestion would be to get an adapter that should fix the problem.
Jun 02, 2011 | iHome iP90SK Dual Alarm Clock Radio for...
My iTouch is fully charged but wont turn on
hold don the top and bottom button and the sam time and keep it held down till the apple logo shows
Oct 15, 2009 | Apple iPod touch
I accidently washed my ipod...when i looked it up on the internet, a considerable amount of websites say to let it sit. I let it sit but it still won't work. I can get my songs to play on my ihome, but it...
Put it in sunlight for 10 minutes, then try again. You can also try using a hairdryer. The moisture trapped inside needs to dry up before it can work properly. If this does not work then take it to the apple store or continue playing it thru iHome.
Jul 27, 2009 | Apple iPod nano
Problem with ihome and ipod nano.
yes, unfortunately the ihome iH9 is not compatible with previous models of the ipod nano.
if you want a similar device, there are many other docking stations for the ipod that are ip0 that ARE compatible with the ipod nano 2G
iH85B is another ihome dock which is compatible with all ipods after the ipod mini (including the ipod nano 2G)
http://www.ihomeaudio.com/products.asp?product_id=10186
Dec 25, 2008 | Apple iPod nano
Ihome won't play ipod, even after resetting ipod
When I first got my ipod touch and my ihome I had no problems and then all of a sudden everything worked except for the ihome wouldn't play music. It charged properly and the alarm and clock worked fine just the music wouldn't play. So I assumed it was the ihome and took it back and exchanged it only to get home and have the exact same problem. So I reset my Ipod and it worked. To do it you have to hold the sleep button until the red slider appears. Slide your finger across it to turn off. Press and hold the sleep button until the apple comes on. Next I sync'ed and looke dfor an update. After all this I docked it and it worked.
Jun 30, 2008 | Audio Players & Recorders
IPOD Video 30gm
Hold down on the center button while hold down on the menu button. The apple logo will appear. Your Ipod is now rebooted.
Is the new battery fully charged? Usually it takes 6 hours on a new battery.
Jun 08, 2008 | Apple iPod MA446LL/A MP3 Player
Apple iPod nano Logo
85 people viewed this question
Top Apple Audio Players & Recorders Experts
TO Lady
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
