Question about HP Pavilion dv9000z Notebook
I have an hp pavilion dv9350ea. Over a couple of years the battery became defective and I installed a new one. It showed 30% charge. I disconnected the charger to discharge the battery before re-charging it. After a while the computer went off, and I re-inserted the charge lead. The icon says "0%, plugged in, charging", but the icon does not show the battery level being charged (although removing the lead for a second and replacing it runs the icon through four (increase charge" cycles - around 8 seconds before the charge motion stops), and the battery is not charging at all - even when left overnight! When the power lead is removed, the battery powers the computer for around 1 minute before it dies out. Please help!
    Novelist:
  • 113 Answers
Sounds like you bought a bunk battery
Posted on Mar 10, 2009
Charging led blinking
If your battery will not charge, you need to run a test on some components on the laptop. The battery, the charger and the laptop itself. Once you detect the faulty conponent then you replace it
with a new one.
To test the battery:
1.Power off the laptop,
2.Take out the battery,
3.Insert it in another laptop,
4.Check of it will charge,
If the battery holds a charge there, then it means the problem is not from the battery, but if it does not hold a charge, then it means the battery is defective and need to be replaced with a new one.
To test the laptop:
1.Turn off the laptop,
2.Disconnect your present charger,
3.Remove your present battery pack,
4.Insert a well tested battery into the laptop,
5.Connect a well tested charger to the laptop.
Dec 02, 2012 | HP Pavilion dv9000z Notebook
My laptop is not charging. it says 0% available (plugged in, not charging) plz help i have a stock hp pavilion dv5
Ifthe laptop battery is more than 3 - 4 years old then the battery could be wornout. Rechargeable batteries have a finite number of charge and discharge cyclesand will lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up atall. ORThe battery shows a 100% charge but when the adapter is disconnected thebattery drops off to zero capacity in a very short time. Ifthe battery drops to an unacceptable charge level then the battery needs to bereplaced.
Jun 25, 2011 | HP Pavilion dv5-1138nr Notebook
I bought a replacement hp battery for my HP Pavillion zv5000 a year ago. It was working fine for about 6-8 months. Then, it seemed to stopped storing energy even when the charging light stopped and...
Feb 08, 2011 | HP Pavilion ZV5000, ZV6000, ZX5000 Series...
My HP dv4030us is about six years old. I use it, primarily as a desk top, so it is always plugged in to AC. I perodically used the battery, but after 6 years, it would not hold a charge. I bought a...
I had a similar problem with my Acer Aspire after I got a replacement battery about 6 months ago.
I was told to disconnect the laptop, turn it off, disconnect the battery, then press the power button for 30 seconds to reset the charging circuit.
I did this, but it didn't work any better. I thought that since my charger seems to run the computer, but it says 0% Available (plugged in, charging) that there was something wrong with the battery.
So, I contacted the manufacturer of the battery and they said they would refund my money within 7 days after receipt, and they gave me an RMA number for the return on the address label.
I, also, got the battery from Ebay.
Since your problem is that the battery icon with a red X over it says 0%, I would say that maybe the battery is bad, or maybe the battery is not connected very well at the contacts. Maybe blow the contacts off with compressed air in order to clean any dust which may be on it.
I would maybe try another battery to try to see if the charging circuit is bad on the laptop.
If another battery doesn't work, then the charging circuit between the laptop and the battery may be faulty.
Good luck on this repair.
Jan 12, 2011 | HP Pavilion dv4000 Notebook
My hp DV6000 stays charging at 86% and will not complete the charge.
If the laptop battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all.
OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time.
If the battery drops to an unacceptable charge level then the battery needs to be replaced.
Jun 30, 2010 | HP Pavilion dv6000z Notebook
Laptop battery wont charge
If you want to make sure of its state, be patient and give it enough time to charge. It might take 3-to 4 hours withe the computer is turned off, and a dozen hours if the computer is beig used. If after a significant number of hours, it is still at 0mAh then either the charging circuitry is defective or it is the battery that is defective (cannot hold the charge).
Hope it helps.
Aug 29, 2009 | HP Pavilion ZV5000, ZV6000, ZX5000 Series...
I have an hp pavilion dv9350ea. Over a couple of years the battery became defective and I installed a new one. It showed 30% charge. I disconnected the charger to discharge the battery before re-charging...
I have to agree that the battery is defective or maybe it is NOT the correct one for your system, although it may be similar.
Did you buy the battery direct from HP a third party?
The AC adapter charger could be defective as well, maybe the defective battery ruined the charger.
I hope this helps.
Good Luck.
Mar 10, 2009 | HP Pavilion dv9000z Notebook
Laptop battery working
Battery led is blinking, this usually means your battery is faulty. Try replacing the battery with a new or tested second hand one.
Hope this helps
cheers
Feb 14, 2008 | HP Pavilion dv9000z Notebook
HP Pavilion dv9000z Notebook Logo
198 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
