Question about Lexmark Wheelwriter 3 Typewriter
Wheelwriter II characters above the numbers print incorrect.
When you shift to print the characters above the numbers some of them work and some don't and that is all that prints incorrectly.
  • Lexmark Master
  • 3,594 Answers
You may have an unusual printwheel that has special char. on the P/W, or you may be in the language mode hold code and press "L" key.
DickyO
Posted on Mar 13, 2009
IBM Wheelwriter 30 Series II is showing an error code of 215 with a box with a slash through it and am unable to type on it
215 is a Print Wheel error. Remove the print wheel, look for debris in the P/W area, if you have a compressed air source blow the P/W area out. If these don't work the P/W sensor is probably bad.
DickyO
Sep 07, 2011 | IBM Wheelwriter 30 Typewriter
I am trying to revive an IBM selectric 6746 wheelwriter to complete some statutory Govt forms that do not have softcopy. It worked perfectly for a while then suddenly stopped printing. All motors seem to...
You probably have a broken plastic print solenoid cap. We sellthem for 20.00 includes shipping and instructions.
DickyO
Cleveland Business Machines
216=241-0027
Jun 16, 2010 | Lexmark Wheelwriter 15 Series II...
When typing, all of the letters do not print,
There are two possibilities, Most likely the print solenoid cap is broken but the solenoid may just be gummy. The sol. is just inside the L. printer side frame just L of the selection motor, just in front of and directly below the small blue rubber damper. Spray some WD40 on the rear of the solenoid. If that dosen't help we sell the solenoid cap with shipping and instructions for 20.00.
DickyO
216-241-0027
Apr 29, 2010 | Lexmark Wheelwriter 10 Series II...
IBM wheel writer 5
If it is printing just the tops the platen may not be fully seated in the side frames, press down firmly on both ends of the platen.
If it is just printing poorly the print solenoid cap is cracked or the ribbon may not be feeding properly.
DickyO
Dec 10, 2009 | Lexmark Wheelwriter 6 Series II Typewriter
Typing characters that are not intended
Try these troubleshooting suggestions for your problem:
Wrong Characters Print or Characters Space Incorrectly:
1. Turn the typewriter off, wait 30 seconds, then turn the typewriter
on again and try typing again.
2. Make sure the LANG indicator is off.
3. Try a new printwheel.
4. Look for objects In the path of the carrier.
5. Make sure the printwheel is changed when there is a language
change.
6. If you are playing back, make sure you use the same pitch
printwheel you used when you typed the text.
You can download the Operator's Guide for your typewriter from here (it takes a little while for the download to begin):
Wheelwriter Typewriter 30 Series II (6787) Operator's Guide
Aug 20, 2009 | IBM Wheelwriter 30 Typewriter
Not Printing some characters
You can get the cap from us, however try getting some lube on the front or the solenoil plunger they do gum up.
DickyO
Dec 01, 2008 | IBM Wheelwriter 30 Typewriter
IBM Wheelwriter 3 typing incorrect characters
If you have another printwheel try that, if you still have the trouble try blowing out the area where it is in stalled. If that fails turn the machine off then back on, after it completes the POR mark the printwheel with some white out, repeat the POR see if the mark is in the same place, if it isin't you probably have a selection plate problem.
DickyO
Nov 11, 2008 | Lexmark Wheelwriter 3 Typewriter
Lexmark Wheelwriter 3 Typewriter Logo
80 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
