Trying to instal a new HD in a Dell Optiplex GX260 Mini tower and the it wil llet me load the OS on but when it goes to reboot to start the setup it says no HD found.
  • 6 more comments
  • aric_jacobse Mar 10, 2009
    Yes the jumper is set to master on the back of the HD. i have tried 2 differant HD and both do the same as i stated before.
    i was able to instal WIndows XP on the HD but after the system make the room for it and it reboots..when it is sxuposed to be going to the instal screen before i goes to that page like it should it stops and says there it cannot find the HD.
    It formats and goes through the first part of the instaler then the system reboots it is suposed to go to the final setup where it looks like windows and tells general information about windows xp as it is loading the information. sorry i am bad at discribing things. it does all the inital set up including formating when it is done it says windows has to reboot. it reboots and then goes to a dos page and that is where it says no HD found.
  • aric_jacobse Mar 13, 2009
    Thank you all i got it working. the HD didnt like being set as a master adn needed to be set as to Cabel Selecte. Thank you all. for your help.
  • Peter Steiert
    Peter Steiert May 11, 2010
    Ah, now I understand. Yes, your hard-drive isn't dead. For some reason your BIOS doesn't recognize the hard-drive, though. If you have another OS installer disc, have you attempted to install that Operating System just to see if it will boot off the hard-drive?
    There is a possibility your windows installer is corrupt.
  • Peter Steiert
    So if I'm understanding you correctly, you are installing the Operating System and Windows Installer is about to format the hard-drive when the system reboots. Is that correct?
    There is the possibility that this hard drive is DOA (Dead on Arrival) and needs to be replaced.
  • Peter Steiert
    There is a possibility that taking out the jumper and trying to boot will work. I've dealt with some computers which would not accept any, and I mean ANY jumper setting. So try taking out the jumper, inserting the hard-drive back into the computer, then booting the system.
    As yet another question, is there an OS (Operating System) such as Windows installed on that Hard-drive? If not, that might be why there is, "No hard drive found."
  • Peter Steiert
    Did you set the proper jumper for the Hard-Drive?
    Sniper:
  • 60 Answers
You need to be sure that your computer is starting from the CD, not the hard drive.
On boot you should have the option to choose a start up. Try F12, or F2. Then choose your CD/DVD device.
You should be able to run the install from there. If not, you'll have to change the start up device in the BIOS, which is a whole other conversation.
Posted on Mar 10, 2009
I have an Optiplex GX 620 Mini Tower that displays a NIC failure error at boot. The error message reads "NIC failure. Press F1 to reboot or F2 to go in to setup." The PC did not boots
it means your hard disk is not detected by system, check all connections of hard disk, if problem remains check with another working hard disk
Jul 29, 2012 | Dell OptiPlex GX260 PC Desktop
Dell Optiplex GX260 Mini Tower Remove Front Door
Front panels do come off on that computer, I have one sitting at my feet right now
Jul 23, 2012 | Dell OptiPlex GX260 PC Desktop
Optiplex gx820 can i connect 300 watt power supply
You listed GX820 and GX260.
I am assuming you meant the GX260.
There are three varieties of the Gx260.
1) The SFF (Small Form Factor) power supplies can be replaced, but I know of no upgrades for these.
2) For the SDT (Small Desk Top), you can get up to a 270 (best I have seen).
Example of where to get one.
http://www.atxpowersupplies.com/180-watt-dell-power-supply-1n405.php?psu=1N405-GX260SmallDesktop
For the Mini Tower, here is an example of a 400W replacement. There may be others for this model.
http://www.cputopia.com/dell-400w-dell-optiplex-gx260.html
I have a GX280 Mini Tower and recently upgraded my PSU to one very similar to the one above.
Feb 21, 2011 | Dell OptiPlex GX260 PC Desktop
Can new motherboard be installed on gx260 mini tower
Yes, as long as the form factor is thesame
you can check this available motherboard online
click here
it has to be a microATX - 32.3 x 9.5 x 35.6 cm
-Carlo
Sep 14, 2010 | Dell OptiPlex GX260 PC Desktop
Hi!, I'm trying to install a brand new WD 500 Gb HD on a Dell Optiplex GX260. The problem is that even though I can see the HD on the BIOS Setup I can't get pass the Message... Press F1 for help or F2 (For...
boot to BIOS
turn on caps lock, scroll lock and number lock,
Press ALT+E (Should get a Single Beep) Press ALT+F (Another Beep) Press ALT+B (Reboot)
Make sure you have Windows CD in Optical drive and once it reboots it should start the OS load
If you don't have the most current BIOS, you may need to install old HDD, Download and install latest BIOS then repeat steps above.
Sep 02, 2010 | Western Digital 500GB My Book Pro-External...
HOW MUCH AGP CAN SUPPORTED BY DELL OPTIPLEX GX260
As much as you can fit in a agp 4x card. If you have the flat desktop or the skinny tower you need 5to get a low profile card, a little hard to find for a desktop. Laptops mainly use them. Try www.tigerdirect.com see what they have in agp 4x low profile or regular size if you have the mini-tower(fatter).
May 12, 2010 | Dell OptiPlex GX260 PC Desktop
I have dell tower pc n ihave problem sound device
http://support.dell.com/support/downloads/download.aspx?c=us&l=en&s=gen&releaseid=R56339&SystemID=PLX_PNT_P4_GX260&servicetag=&os=WW1&osl=en&deviceid=2430&devlib=0&typecnt=0&vercnt=3&catid=-1&impid=-1&formatcnt=1&libid=3&fileid=67126found this in the other fix it help files here, so i hope it helps you. props to hamzicfor the find.
Jun 11, 2009 | Dell OptiPlex GX260 PC Desktop
Installing a sound card into my Optiplex GX260
Hi
OptiPlex GX260 can be Small Form-Factor, Small Desktop or Small Mini-Tower. Compatibility with PCline 5.1 PCI depends on the profile of the PCI Card and the Profile of your OptiPlex.
GX260 Small Form-Factor is compatible with Low-Profile PCI Cards only. GX260 Small Desktop and Small Mini-Tower are compatible with standard PCI Cards. (Small Mini-Tower however uses a PCI Cage).
Check OptiPlex GX260 Systems User's Guide - http://support.euro.dell.com/support/edocs/systems/opgx260/en/ug/index.htm
From here you visualize the 3 form factors. Also there is info and steps to install PCI cards.
NB:
1. Generally, upmarket PCI cards are standard height. Some manufactures supply a metal piece to allow it to be used in Low-Profile or Standard Profile.
2. Driver software needs to be installed after the hardware is installed.
Mike
Apr 12, 2008 | Dell OptiPlex GX260 PC Desktop
Computers & Internet Logo
61 people viewed this question
David Payne
David Payne
