Question about Acer TravelMate 2480 Notebook
The pin that the power cord goes into has broken off
I currently have the power cord set in place by some strong rubber bands going around the underneath of the screen around to the side where the power plug goes in and fits over the male pin that has come off, to keep the connection going. I would like to have it fixed but not sure exactly what needs to be done. I have seen two different pieces to replace that part with, one is just the housing of the pin w/the pin attached and another is the housing with parts of a mother board.
Thanks for your assistance.
    Sergeant:
  • 329 Answers
Is the cord broken in the computer, or the monitor or the pin broken and stuck in the machine? If it is in a desktop it goes into the power supply. Which you can change the whole power supply fairly cheap. that is if it in a desk top computer. 4 screws, 4 or 5 connectors and ta da new power supply, All you need is readings off power supply such as wattage. Good luck
Posted on Apr 23, 2009
I have a porter cable rn 175a, barely used, driver will push 1 nail, and then has to be manually reset, any suggestions or solutions please
Driver not retracting is caused by check band around cylinder is not in place or broken. Easy to check. Remove the head and pull out the cylinder. There should be a black rubber band around series of pin-holes in cylinder. If the band is broken use any rubber that fits snuggly around cylinder and covers holes. Good luck
Mar 21, 2014 | Air Tools & Compressors
Drive pin does not retract
Easy to fix. Remove the head and pull out the cylinder. Look for black band around lower part of cylinder. This band (check band)should be placed around series of small holes. Replace if broken with any rubber that will hold up in oil or use a bunch of orings to fill space. Good luck.
Dec 14, 2013 | Porter Cable Air Tools & Compressors
FN250A finish nailer will only shoot one nail then has to be manually reset
Could be caused by bent driver, piston oring too tight or too loose cylinder split or check band broken or slipped out of place. Easy to check. Remove the head and pull out the cylinder. Check band fits around series of very small holes on mid-lower part if cylinder. Check band looks like rubber band, should fit snugly around cylinder and cover the small holes (any band will do if broken, even many orings side by side). Driver should not be bent, if bent, try of adjust but use caution because it could break easily. The driver should fit into cylinder so that it does not fall thru cylinder under it's own weight. The driver should stay in place and moved with little effort. Good luck
Feb 07, 2013 | Porter Cable Air Tools & Compressors
The piston in my ridgid roofing nailer comes out and wont go back by its self
This problem occurs when check band is not in place. Remove the head and pull out the cylinder. There should be a rubber band around a series of holes on the cylinder. Replace if broken or just put back in place. Good luck
Jan 20, 2013 | Ridgid 21168 212" Angled Finish Nailer
How can replace the speaker the bass sound is broken
Dear Rob,
Really Thankful for the detailed description for the Speaker Repair.
It really helped me a lot. I have a unusual situation here with me. I have dissected the whole console and found the outer band of the speaker has just come off....have attached photos to make it clear. does the outer speaker cone will make a difference or i will have to replace the speakers itself.....when i checked pressing the speaker down and played the distortion had gone....but while playing without holding the distortion would come back....Hope you can help me in this situation....Thanks in Advance..... 714812a0-935e-4f95-922e-50c6ba281b9c.jpg 36e62701-6370-491a-a317-a11c69cc9525.jpg
Jan 13, 2013 | Harman Kardon Go + Play Portable Speaker...
Porter cable roofing nailer piston won't retract
Could be the check-band around the cylinder. Easy to check. Remove the head and pull out the cylinder. There should be a rubber band covering a series of pin-holes drilled into the cylinder. Usually the band will fall out of place or break. Use any rubber that will stay in place to cover the holes. Good luck.
Oct 16, 2012 | Porter Cable RN175 Roofing Coil Nailer
The electric cord plastic jacket melted and burned through wire on one spot. Can the cord be replaced
I am currently attempting to do that myself. You need to separate the liner from the outside part. Using a pair of pliers, loosen the round nuts (found on the bottom) holding the unit together & separate. You'll find that the unit won't come completely apart because of the wiring. There is a heating band, held together by a spring, around the inner liner. Remove the spring to release the band. This should allow you to remove the inner liner & give you access to the wiring. At this point, you'll need to clip the appliance cord by the little wire nuts. The hardest part will be getting the cord out; there is a strain relief grommet that holds the cord in place and prevents it from being cut by the sheet metal where the cord goes through. I broke this strain relief on my crockpot and am currently looking for a replacement. Once I find a cord relief, I should be able to reconnect the wiring, the heating band and assemble the unit. Be careful not to cut yourself on the sheet metal!
Nov 23, 2011 | GE 106661 4.5-Quart
Sony icf sw100 broken battery case (the tooth on which the battery lid hinges)
Re Sony ICF-SW100 battery case lid.Ive had same problem with battery case lids on this these units, I used a strong rubber band around the length of the whole battery case to keep lid in place as no parts available in Australia. Love the radio, have had 4 over many years.
Nov 11, 2010 | Sony ICF-SW100S Radio
A part came off and dont know where it belongs
You will need to lift felt on the platter section exposing the platter. Next you will need to pull upwards on the platter itself. The rubber band goes around the inside of the platter and onto the spindle motor. To replace, simply lift platter section of the unit, place the belt around the inside of the platter and replace the platter. Move the platter around till you see the motor and use some tweesers to pull the belt over the motor. Hope this helps
Apr 17, 2010 | Sony PS-LX250H Turntable
Digital camera screen broken
A cracked screen will cost you, but maybe not as much as you think. Instead of replacing the whole , you can spend about $300 and replace the screen yourself. All you need is a small screwdriver.
1)Turn off the power to your screen and unplug all cables connected to it.
2)Remove the battery, if one is installed.
3)Locate the covered screws around the cracked screen. Remove the rubber/plastic covers, then unscrew the screws.
4)Gently remove the plastic frame around the cracked screen and set it aside.
5)Disconnect any power cords or cables going into the LCD screen.
6)Remove the cracked screen and slide the new screen into place. Replace any tape or plastic fasteners that hold it in place.
7)Reconnect all internal cords to the screen.
8)Screw in the frame and replace all the screw covers.
9)Reconnect the power supply and all external cables to the LCD screen and switch it on.
Aug 31, 2009 | Sony Cyber-Shot DSC-P150 Digital Camera
Acer TravelMate 2480 Notebook Logo
96 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
