I disconnected the fuel line from the engine to the petrol tank and blew air down the line, the back pressure bought up what smelt like turpentine and some gunk. Is there an easier way to clean the tank out and the fuel line?
Dude lot of work but drop the tank clean it out don't forget to clean the fuel pump out and new filters new fuel and keek it jumped to another car until she starts ,just did same for hj holden but I had too replace take as it is a metal tank and it rusted out, if you have time let water soak in tank once out for about 12hours then rinse and dry completely by standing for 12hours all holes open good luck
SOURCE: car doesn't seem to get enough gas to engine
Have you done a tune lately on the car?
I would also suspect a fuel pump problem is you've done a tune up recently.
SOURCE: 2007 hyundai elantra windshield washer tank removal
maybe its the fuse thats lodged inside the pump
SOURCE: Eratic idling and misfiring under pressure
confirm that the fuel pump delivers the proper pressure to the injectors
SOURCE: EF FORD FALCON NO FUEL GETTING TO CARBI
I think the word carburetor and ford falcon was mentioned which used a mechanical fuel supplied system. check for a cracked fuel supply line from the fuel tank to the steel body supply line.
SOURCE: I have a 88 Fiero GT V6 that has sat for over a
Change The Fuel Pump & Strainer As The Strainer Is Pluged With Varnish.
