Question about JVC MX-KB30 CD Shelf System
How to diable demo mode on mx-kb30
Can't get off demo mode can any one help?
Turn the stereo on, wait two minutes for the demo to start running then press the "demo/cancel" button located under the "sound mode" selector.
Posted on Sep 20, 2011
    Scholar:
  • 84 Answers
The "DEMO" mode initializes when power is initiated in the unit for the first tiThe me.You cancel it by turning turning the power on by using the button the unit or the remote.If you unplug the unit from the power outlet between uses, and plug it in again...it will go back to the demo mode.this can be avoided by leaving the unit plugged in between uses and/or install 3 AA batteries in the battery compartment in the lower rear behind the main battery compartment .these batteries are memory storage.it is not necessary to instal the 9 size D batteries for portable use unless you use it as a portable...I hope this was helpful...
Posted on Dec 13, 2011
Jvc home component mx-kb30 protect mode on
First check that the speaker wires are not shorting, if okay! the problem is in the audio output stage of the receiver, the protect mode comes on if a load is detected.
Apr 25, 2012 | JVC MX-KB30 300W Mini Home Audio System...
How to disable demo mode on JVC MX-c220
Make sure the unit is on. Press the FM Mode /Mute -Demo button (right next to the power) press it untill you get to either mono or auto (-for stereo). That will take the unit out of the demo mode. next turn the music jog dial (located just above the preset buttons) untill you get to which ever setting you choose. Hope that helps. ( I can't find the manual on line either- not even from JVC! )
Mar 09, 2009 | Audio Players & Recorders
Protecked mode?!
when i had this problem my wires were touching the case. other times the wires were touching eachother
Mar 23, 2008 | JVC MX-KB30 CD Shelf System
JVC Stereo won't open cd tray
Maybe something's jamming it, try fixing the drive, so it comes out.
Mar 16, 2008 | JVC MX-KB30 CD Shelf System
Display panel
Take the display panel out, and then look at it to fix it. If you cant fix it, then its time to get a replacement.
Nov 17, 2007 | JVC MX-KB30 CD Shelf System
CDs won't play
Maybe you should fix the cds or clean them or try to fix the disc reader in the radio.
Nov 09, 2007 | JVC MX-KB30 CD Shelf System
Tray will not open!
press &hold stop then press the eject button.
Nov 04, 2007 | JVC MX-KB30 CD Shelf System
JVC MX-KB30
Have it first cleaned by a cd disc cleaner or if you are familiar with cleaning the lens manually im sure that will work...or try inserting an original cd's,if it works with that find the solution to the settings of your device...
Sep 22, 2007 | JVC MX-KB30 CD Shelf System
JVC mx-kb30 Stereo comes on then goes right back off.
A desperate longshot but the only i have to offer: It might be a problem with the electricity. if possible try and install it at another location in your house, using other electricity sockets. If the problem is solved by relocating the system, you might be looking at wiring problems (audio equipment can be very sensitive to that), if changing anything in the installation process solved the problem then the problem was probably due to bad grounding and "loose" electricity. Try making the installation as "clean" as possible, avoid tangled wires and stressing a single socket with too many electric appliances. If the problem persists, and you are still under warranty, I suggest contacting your local JVC dealer. If you're out of warranty I suggest locating a professional repair person. Good luck
Jan 24, 2006 | JVC MX-KB30 CD Shelf System
JVC MX-KB30 CD Shelf System Logo
473 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
