Question about Maytag Washing Machines
Our 1986 top load Maytag washing machine will not start the cycle. When we turn on the dial, no water comes out. There's no sound to indicate that any power is reaching the machine. We checked the power cord and it seems to be fine.
  • 1 more comment
  • jenny_feick Mar 10, 2009
    No, nothing else is plugged into that outlet other than the dryer, which has always been plugged into that outlet. The dryer still functions fine.
    Thanks. We will try this when we get home from work later today. Someone else suggested that this type of machine has an out of balance switch that shuts off the machine when it senses it is not level. Or, there could be a problem with the drum.
  • StanStihl May 11, 2010
    did you plug something else into the outlet to make sure the breaker hasn't tripped?
    Novelist:
  • 108 Answers
If you have a volt meter, you can test the valve inside the machine to see if there is power getting to the valve. If you listen very carefully to the back of the machine when it turns on, you might be able to hear a slight "buzz" coming from where the hoses plug in. If you hear a buzz, then the valve has gone bad, and needs replacement. If you don't hear anything, it might still be the valve, but you will have to test it with a meter to make sure.
If the valve proves to be fine, then chances are the dial timer has gone kaput.
Posted on Mar 10, 2009
No water is coming on at the start of the cycle
check hot & cold hose , take off hose from washer . Put in bucket open water coming or not .
Apr 18, 2017 | Amana ALW895 Top Load Washer
MAV4755A Top Load Washer: When I turn the dial to start wash cycle, nothing ...
if press button selection, make sure that no 2 buttons are pressed
Jan 27, 2018 | Maytag MAV4755A Top Load Washer
Maytag MAV6000AWW washer will not run thru cycles consistently
yes it would be the timer but they also stop if it gets off balance if its just off balance u should be able to lift the lid rearrange then start it again if that doesnt work it is the timer
May 21, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Maytag washer won't fill or agitate; only spins on cycle
sounds like you have a blown fuse. I dont have a schematic so I dont kno where you have to look to find it
Dec 30, 2008 | Maytag Atlantis MAV6451 Top Load Washer
I have a maytag top load washer model number MAV7757AWQ. It will not spin out ( water just sits ), until I manually move the timer to the spin cycle and restart. Is my timer bad ?
based on your description..the motor for the timer sounds like it is bad or one of the wires powering it came free of the motor terminal.. Does the dial spin after you start any wash setting? If not then I'd say your timer needs replacing.. Hope that helps
Aug 30, 2008 | Maytag MAV7600 Top Load Washer
Maytag Atlantis -won't spin
Find out where your filter is & clean it out thoroughly, refit.
May 10, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Washing Machines Logo
43 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
