Question about Samsung SpinPoint P120 SP2014N 125 GB Hard Drive
Flash drive not detecting even after inserting flash drive again
Inserted flash drive, again asking to insert flash drive, why like this what happened to my flash there are somany files, in that. How can I get recover that data successfully, what is the solution.
Thanks
SOURCE: my samsung says insert sim card...
u should have to check your sim card nd insert a sim car in right way
Posted on Mar 03, 2009
SOURCE: Samsung G600 - phone asks for sim card but doesnt work when inser
when phones get wet they start to rust from the inside, unfourtunaly this is a long prosses and can take a few months but usually if the phone has got very wet they will not work propley again. they may work temperally but eventually it will probably be completly usless. in future if u wet a phone try drying it immediatly with a hairdryer, inside the battery bit too, this may help the water inside the phone not to cause rusting. sorry about your phone.
Posted on May 19, 2009
  • 79 Answers
SOURCE: my samsung u600 wont accept my memory card?
sorry for the bad news mate but go here and read on ,, the largest memory card your phone can take is 2 gb ,,
http://www.mymemory.co.uk/compatible-memory/Mobile_Phones/Samsung/Samsung+U600_Memory_Cards
Posted on May 23, 2009
SOURCE: Is the Samsung Zirez Pleomax
Yes, the portable harddrive is compatible with a MAC Product Features
  • Quick & easy to install Features USB 2.0 &1.1 interface connections allowingit to freely switch roles as local storage device
  • 2.5-inch External HDD
  • Fast & Small 480 Mbps for high-speed performance and smooth data transfer Ultra-slim attractive design everybody wants to have
  • Compatible with PC, Mac & Linux
  • Portable Carry & use either at your desk or on the go Simple & convenient plug & play automatic recognition
http://www.amazon.com/Samsung-Pleomax-Zirex-Portable-UHD2-5-80G/dp/tech-data/B000BB69AS/ref=de_a_smtd/179-8912138-6919333 This error is probably caused by a bad shortcut. The ".Ink" you refer to is really ".lnk" (the first character of the extension is a lower-case "L," as in link, not an "I"). Shortcuts use "lnk" as their file extension.
This kind of thing can happen if you install software from a networked drive and then later detach from that network, which is a common situation if you use a laptop computer that you disconnect from your office network and take home. To find the shortcut, follow these steps: Open Windows Explorer and press Ctrl-F (hold down the control key and press F) to bring up the Find dialog. Select "Local Hard Drives" in the Look in dropdown, and enter ".lnk" (or whatever the error message reported for the name of the bad shortcut) in the Named field. When you click the Find Now button, Windows will search your hard drives for the shortcut and display what it found.
Posted on Jan 09, 2010
Alex93Serbia
  • 209 Answers
SOURCE: My floppy drive does not seem to recognise that a
Hello there!
Well, you 1st should check is your floppy drive properly insterted into your pc mb. Open your hardware check the joins on your FD(floppy drive) if thats ok, assemble the box. Next move is to check is your FD even enabled in ps BIOS. Open your bios acess general settings, and you should find setting flopy disc 1,28~ enable/disable.
After that if you still experience problems you should thinking about usage of usb pen drives, since floppy drive systems are really outdated, as I know there never been any drivers for that system , so those steps should solve your problem.
Sincerely
Aleksandar Adzic
Posted on Apr 16, 2010
Testimonial: "Thanks for your help Alex93Serbia, i'll give it a try..."
Every tym i insert my pendrive it says insert disk into the drive...???removable disk appears..but it doesnt opns...is there any solution...plz do help me
Assumption 1
Flash drive is damaged, the normal operating system.
Solution
If the flash drive is detected (eg; detected the flash drive in drive G), but it says "insert the disk into the drive ..."
1. Download software JetFlash Online Recovery (open link - select type software - select OS Windows - select language English - select product JetFlash All Series - Download).
2. Insert the flash drive
3. Open file OnLineRecovery.exe - Select the volume of the device - Repair the drive & keep data existed - START. If it fails, select Repair the drive & erase all data - START.
If the flash drive is not detected (not detected as drive G),
the above solution can not be used.
Assumption 2
Normal flash drive, the operating sytem is corrupt
Solution
Flash drives do not require drivers (plug and play). Because flash drives plug and play, it should be, when the flash drive inserted detects the operating system without installing drivers. But, if the operating system does not detect, the possibility of operating systems corupt. The cause is a virus corrupt your operating system.
1. Download and install anti-virus Avira or AVG (free).
2. Update anti-virus
3. Scan your computer.
4. Repair the operating system.
5. If no virus is detected, the possibility of operating system is corrupt.
I hope this information helps.
Oct 07, 2011 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
My potevio sd card tells that " insert a disc into drive " even on right click the format option is not shown what will be the possible problem & solve it quickly please thanque
HELLO, HAVE YOU TRIED INSERTING IT ON ANOTHER LAPTOP? AND SEE WHAT HAPPENS.IT IS EITHER YOUR SD CARD IS NOT FUNCTIONING OR THE LAPTOP YOU INSERTED IT HAS PROBLEM
Nov 19, 2010 | SanDisk 1GB microSD Memory Card
Showing an error ''insert a disk in removable media''
Its happened for my Transcend 4 Gb pendrive. I format dat using ONLINE RECOVERY TOOL from Transcend. Now its workin :-) :-) :-)
Dec 16, 2009 | Electronics - Others
Malfunction
This can occur if the pen drive was inserted into a HUB rather than direct into a proper usb 2.0 port on the compuer.
It can also happen if the dmive has been mistreated in any way.
You may want to try re-format it from the computer mangement console
rather than my computer or windows explorer
Aug 23, 2009 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
My phone is not detecting the memory stick micro
Format the memory card in pc or any other phone then insert in your phone it will work.
Aug 11, 2009 | SanDisk 2GB Memory Stick Micro M2 Memory...
When a floppy disc is inserted it flashes disk
The floppy driver has an internal switch that detects when the floppy disk is protected or not.
It is likely such switch is damaged.
It is necessary to open the camera and the floppy drive to fix it.
If you have experience and skills in fixing electronic devices, or want to try it, then you can try its repair.
The alternative is to pay to have repaired, but is more likely that the quote you will receive is to replace the whole floppy drive, which costs around $40.00 plus the repair labor.
Regards,
Jul 08, 2009 | Sony Mavica MVC-FD100 Digital Camera
Says insert sim card when there is one in it
"Insert SIM" message is normally displayed on phones when a SIM card is not inserted on power-on or it does not detect the SIM card inserted.
Likely Causes:
  1. No SIM card inserted or inserted SIM card is damaged
  2. Inserted SIM card not positioned well in such a way as to make contact with the corresponding contact bridges on phone.
  3. Phone locked to a specific network and can only work on other networks when the firmware version is "flashed", that is completely changed to an unlocked version.
  4. The phone might be faulty (try with another good SIM, if you still get thesame message and its not one of the above reasons... it might be a transciever problem or the phone's SIM card slot's pins might be defective).
cheers.
Apr 30, 2009 | Sony Ericsson Walkman® W880i Cellular...
W200i memory card
hi there,
go to the sony erricson website and download the update :) it should fix this for you :)
Feb 16, 2009 | SanDisk 1GB Memory Stick M2 Memory Card
Memory stick cannot be detected
STICK LIGHT COMES ON AND STAYS ON COMPUTER SAID ITS DEFECETED. I had just used it
Jul 08, 2008 | Sony Micro Vault Classic 4GB USB 2.0 Flash...
Samsung SpinPoint P120 SP2014N 125 GB Hard Drive Logo
27 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
