Question about Linksys Wireless-G WRT54GS Router (e125894)
Constant loss of wireless signal
Hi I am currently using a linksys WET54GS router and have problems with losing the signal all the time. I just switch everything off and on again but have to go to the admin set up page everytime and rest everything which is very frustrating. I am thinking of buying a new router, but wanted to check that i've set it up ok. Maybe there is something i need to do that i'm not aware of. Also i have no WPA or WEP set up as i have no idea how to do this, do i need to contact my service provider for password or do i do this myself? Thanks in advance for your help!
Jen
  • jennefer_lin Mar 10, 2009
    HI meant to type wrt54GS router!
    its version 7 but i'm not at home just now so not sure which one
  • 43 Answers
You router may be going bad. These routers are pretty plug and play so there is minimal setup to get you started.
I went through a few cheap routers myself before I found a reliable one. It cost me a bit more but was well worth it.
You can try to default the router to factory settings and also look at downloading a firmware upgrade from the Linksys website. This is covered in the documentation that was supplied withthe router. Sometimes the help files are also built into the router.
"Also i have no WPA or WEP set up as i have no idea how to do this, do i need to contact my service provider for password or do i do this myself?"
You can set it up yourself via the router. Basically you choose which one your're going to use and setup an encrypted password. Then add this password to the connection profile for your router when it ask for it upon connection.
Posted on Mar 10, 2009
  • 170 Answers
Sounds like you need to download a firmware update for your router, go to http://downloads.linksysbycisco.com/downloads/wet54gs5_v492,0.zip
and download the firmware to somewhere like your desktop, then browse to 192.168.1.1 and loginto your router and look for the update firmware link, browse to your downloaded file and update your firmaware, make sure you dont cut the router off or unplug it while it is updating.
Hope this helps,
David
I need to modify the settings on my router so that I can get a better signal on my internet radio. The current signal is low and I keep losing my wireless internet connection.
You can follow the step by step procedure to correct this intermittent wireless connection on your router by following the steps from my TIPS , just click HERE.
Aug 28, 2011 | Linksys Wireless-G WRT54G Router
I have a Linksys router since 7/09 but keep losing
LOSING WIRELESS CONNECTION ?
Make sure the latest wireless card driver is installed in the computer.
Locate the wireless router higher and away from concrete and brick walls, foil insulated walls.
Locate the wireless router away from cordless phones and microwave ovens these can cause interference.
You could be getting interference from other wireless access points or wireless routers in your area. Check the wireless broadcast channels in your area, and select one that is unused or one that has the weakest signal strength.
Jan 22, 2010 | Computers & Internet
WRT54GS - freq signal loss!
Sounds like you need to download a firmware update for your router, download the firmware to somewhere like your desktop, then browse to 192.168.1.1 and loginto your router and look for the update firmware link, browse to your downloaded file and update your firmaware, make sure you dont cut the router off or unplug it while it is updating.
Hope this helps,
David
7.2 http://downloads.linksysbycisco.com/downloads/WRT54GS-v7.2_fw,0.bin
7.0 http://downloads.linksysbycisco.com/downloads/WRT54GSv7_7.50.5_fw_US_code,0.bin
Mar 10, 2009 | Linksys Wireless-G WRT54GS Router...
Occasional signal loss
Go to www.linksys.com and see if there is a firmware update for your model
Aug 23, 2008 | Linksys Wireless-G WRT54G Router
Wireless Network
You can get a Wireless Range Expander to repeat the signal of the router and Linksys also has that the model is WRE54G it will solve you signal problem...
Hope that helps........
Jun 27, 2008 | Linksys (WMP54GS) 802.11g/b Wireless...
Linksys enternet wireless bridge wet54gs
Try setting the wireless channel to 11 and by the way how far is that place that the wireless connection wont connect?
May 08, 2008 | Linksys Wireless-G Broadband Router
Lose the internet signal frequently. Vonage now set on and I can't afford to having to reset the router constantly. I have a t54g and wonder if I need to change my router. I only have a main computer,...
Do you have cable TV also? If so, how many TVs are hooked up. Sounds like you have signal loss. I had the same problem. Also, if you have another coax cable lying around, try changing it out (from the wall to the cable modem, cables can be a big issue with this).
Apr 26, 2008 | Linksys Wireless-G WRT54G Router
Loss of Connectivity
Libog1 - did you install any additional wireless software to connect to the router (Linksys software) or are you just allowing Vista to connect directly using Windows' built-in wireless management?
Ben
Mar 03, 2008 | Linksys Wireless-G WRT54G Router
Lose signal
While some loss is expected. You can change channels. 1-6-11 are the best for cutting signal loss because they do not overlap.. 2.4GHz device in operation, like a cordless phone or microwave oven can cause signal loss. Metal in walls, electrical devices and wires can also cause loss.
Jan 03, 2008 | Linksys WPC54G Wireless-G Notebook Adapter...
Linksys Wireless-G WRT54GS Router (e125894) Logo
115 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
