Question about GE WJSR2070B Top Load Washer
Bearing is shot
My washer bearing is shot. The washer is 3 1/2 years old. Is this covered under warranty?
  • Valerie Moeller
    Valerie Moeller May 06, 2009
    Thanks, I already bought a new washer. The repairman said it too expensive to fix and what was wrong with it was that it was a GE. Ha, ha. Got a Whirlpool.
    Problem Solver:
  • 7 Answers
Probley not but check manuel. Transmission bearing did have longer warrenty 3 to 5 year ago.So have alok in maneul.
Posted on May 05, 2009
When it spins out it makes a really loud noise
It's more than likely the lower drum bearings. The sad news is they used to be covered by a ten year warranty that Sears took away because they were going broke changing the drum out. So if your washer is less than 10 years old the warranty will not save you and it will cost you between 2 and 3 hundred dollars. High efficiency washers, no matter the brand are pure junk. I've paid for mine twice in repairs. Grrrrrrrrrrrrr Good luck and maybe it's just something stuck under the disk at the bottom.
Feb 10, 2015 | Kenmore Elite Oasis 27052 Top Load Washer
Drum does not spin centered, it is rubbing the seal
This isn't good. it's normally related to the tub bearing or spider brace on the inner/ outer tub. Both parts tend to be very costly. If its under a year old you will be covered in warranty.. if not it maybe time for a new machine. I have seen this on washer's as little as 14 month old. I'm not a front load washer fan because of this problem.
Jan 19, 2014 | Maytag MAH8700A Front Load Washer
Just bought new pump. My old one lasted for 12 years. New one is 4 months old and recently started to make a loud whine or screeching noise when operating. It works fine but is very loud. I have trouble...
Most likely the bearings on the motor are going out. 4 months is way too soon, but it is possible you got a lemon. Unfortunately I wouldn't expect the new one to last 12 years. It's possible but unlikely. You should however get at least a few years. If the shaft seal on the motor shaft between the impeller and seal plate failed then water can drip back along shaft and get into motor bearings. This will cause motor bearings to fail. Even if this is not the case the motor bearings can fail even though it is rare to do so within first year. I would contact the place you bought the pump from, or whoever installed it. It should have at least a one year warranty. If for whatever reason this motor is not covered under warranty and you have to replace it, I would consider rebuilding it. Normally I don't care for rebuilds, but if the motor is truly only 4 months old then rebuilding it would be a good option.
Sep 23, 2010 | Polaris Pb4 - 60 Booster Pump
Our Kenmore Elite Oasis that we purchased over 3 years ago started to make incredible noise during the spin cycle, so loud you can barely hear yourself think. We had a repairman from a Service Company...
Yes, Sears repair just ordered one for mine. Entire tub due to bearings gone. Also just over 3 years old and ext warranty ran out in June. Final inspection before warranty was scheduled in June 2010. July the bearings are gone. Hmm wonder how they missed that? Anyway if you call for service, ask about the maintenence plan. Its way cheaper than labor and tub and u have another year for more issues with this piece of junk washer.
Dec 01, 2009 | Washing Machines
Where can i get a new pump for my viva,,3 years
Try this..
Clcik on the link..
http://www.aquadist.com/Decision1.htm
Hope this helps !!
Please rate me good ;o)
Jul 10, 2009 | Aquabot Robotic Pool Cleaner
Tub bearing is making grining noise
yes when the washer sounds like an airplane taking off during the spin cycle, it is a worn rear bearing.
it does happen from the wrong type of soap being used. the suds from regular soap will destroy the seal and allow water to get into the rear bearings causing the bearing to fail and become noisy.
HE type soaps have been recommended by the manufacturer for about 6-7 years now and you MUST use them to prevent this from happening. it can also happen with HE is you just use too much.
now the good news... the inner tub has a lifetime warranty but the outertub, comes with seals and bearings, may only have a 5 year part only warranty.
what you can do is to call frigidaire at the 800# and ask if they can check the warranty for you. a 3 year old and a 5 year old unit might be covered by a part warranty. if so then the labor to replace the tubs will be about 200-300 bucks. i know its a pricey repair but is certainly cheaper then buying a new washer.
by the way, all front load washers will do this if you use the wrong soap.
Dec 30, 2008 | Frigidaire GLTR1670A Front Load Washer
Grinding during the spin cycle
To check for a bad bearing, open the door, pull back the door seal then grab the plastic outer tub with one hand and the inner basket with the other hand. If you can lift on the basket and wiggle up and down, the tub bearing is bad. If OK, the noise may be coming from the pump. The pump impeller may have come loose and is rubbing on the pump housing.
To check impeller, remove the bottom access panel. There you will find a pump filter that you can unscrew and remove debris. UNSCREW AND DRAIN SLOWLY as there will be lots of water to catch..
Look inside the small hole of the pump and check impeller, it should be set back against the motor.
If bearing, check limited warranty.. bearing may still be covered...
Regards,
Richard
Jun 13, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Sony cyber shot s650
I think it is still under warranty because you told its not a year old. Ask Sony about its warranty cover.
http://esupport.sony.com/US
May 30, 2008 | Sony Cyber-shot DSC-S700 Digital Camera
Our Neptune Maytag Washer is making a very loud noise during the spin clycle. I think It may be a bearing but its only a little over 4 years old. Have Maytag had a lot of problems with this kind of noise
Yes Maytag has had seal and bearing issues. Check your original warranty paperwork it still maybe covered?
Call the store where you bought it, they may cover it under warranty.
Did you buy an extended warranty?
May 04, 2008 | Washing Machines
Drum bearings,
if your machine is under 5 years old ...the machine is under warranty for parts only and is covered by hotpoint they will charge you for callout/ labour charge only..you need your date of purchase proof or go by the manufacturing date code inside the door the first two digits of eight.... this month is 73 so deduct the first two digits from that number eg if the digits were say 43 take that from 73 hence 30 months old from production my guess is the machine is pehaps 2 years old typicall failing for that model... .for you to buy the parts and do it yourself major stripdown! will cost you the same as their (hotpoints charge) so i would call them hope this helps
Jan 26, 2008 | Hotpoint First Edition FEW12 Front Load...
GE WJSR2070B Top Load Washer Logo
91 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
