Question about RCA Televison & Video
Locating the ''flyback transformer '' on a rca mod #R52WH74
I am trying to find the FLYBACK TRANSFORMER on a RCA mod # R52WH74 tv
    Scholar:
  • 41 Answers
It is usually large and black. Its the one with the rather thick red wire coming out of it. The other end of that wire either connects directly to the picture tube or into a distribution block which distributes the high voltage to the 3 picture tubes (guns) in projection TV's. Be aware that this transformer produces high voltage and can store voltage even when the set is unplugged. I hope this helps.
Posted on Mar 10, 2009
Where is the flybac located in a rca hd52w59
Hello
Flyback transformer other wise called Line output transformer {LOT} is actually a step up transformer, which supplies extra high tension voltages to the guns. It can be locatee on the main printed circuit board. 2_7_2012_5_19_59_pm.jpgJust see the different views of the main board of your RCA TV. You can see the flyback transformer at the left top corner, look like a large black componen; with a ferrite "U" type core goes though it. It is the LOT. Line Output Transformer, otheriwse called as Flyback Transofrmer. OK.
Feb 07, 2012 | RCA Televison & Video
My tv. proscan mod. ps50700 won`t turn on
The PS50700 uses the 195 series chassis. The most common cause of the set not starting up is a shorted flyback (high voltage) transformer. Sometimes a shorted flyback will also cause the horizontal output transistor to short too. These parts need to be tested and/or replaced by a tech familiar with the RCA 195 chassis.
Aug 17, 2007 | Proscan PS65000 65" Rear Projection...
Having similar power problems with my RCA R52WH74, shuts of and turns on by itself and no picture. Replaced the CP150, CP114 & CP120; still the same. What next??
Try resoldering the flyback transformer, If that doesnt solve the issue then the small signal board is most likely the culprit.
Jul 24, 2011 | RCA R52WH73 Projection Television
Is rca r52wh74 and rca d52w14 flyback interchangeable??
No you will need the 270125 Flyback for the R52WH74 as thats a ITC222A chassis. The D52W14 is the ITC222 and uses the 259296 flyback.they are not interchangeable
Jan 22, 2010 | Televison & Video
Can't figure out to find auto convergence on remote or tv
Go to menu then setup look for convergence if you do not see it listed you have a open fuse FL231 it is located on right side of FBT flyback transfomer there is 3 in a Roll small brown rectrangler looking caps but they are fuses it will be the one in the Middle.
Aug 22, 2009 | RCA R52WH73 Projection Television
RCA R52WH74 turns off 3 times
Hello Kira-chan,
You are going to have to take those capacitors out of the Tv and check them on a capacitance tester. Some digital multi-meters have them, but I would suggest using the LC102 by Sencore That way you can check the ESR, and the dielectric absorption of the capacitor. It is my suspicion that these caps are bad, but should be checked before replacing them.
In addition check the BLUE and RED CRTs for cracks around the neck oy the tube, BE CAREFUL.
I hope this helps,
Thank you,
Shuttle83
http://www.electron-age-technologies-llc.com
Jul 27, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Concave screen colors in 3d
I have the same tv and just had mine repaired for the same problem just got it back yesterday turned out to be the fl231 fuse blown and the flyback transformer solder points have rings in them. It cost me $211.00 to get it fixed and they said it's common problem and most repair shops should have the part in stock and fix it in a couple of days.
Dec 14, 2008 | RCA R52WM24 52" HDTV Projection Television
Rca projection tv serv#p56938yx mod#p56938 serial#c135c50tx chassis#ptk195s16p cant id
Here are some numbers to call for Flyback Replacement
Electronica 1-800-772-5578
Asti 1-800-221-1828
you will need RCA chassis# PTK195s16p - flyback number1541938b.
ThankYou for using FixYa. Have a Nice Day.
Feb 07, 2008 | Televison & Video
Rca r52wh74 - no auto convergance
you need to replace chemical type fuse marked FL231 part number 259213, it`s located next to the flyback transformer, theres 3 of them there but 231 is the only one I`ve seen cause your problem, replace it and you`ll be all set.Happy Holidays !
Nov 29, 2007 | Televison & Video
RCA P52937 Flyback Transformer question
The lead going from the flyback to that other device is a voltage divider or splitter as they're incorrectly referred to... To remove the leads press down firmly, twist and then pull up...
Bill
Nov 21, 2007 | RCA P52937 52" Rear Projection Television
Televison & Video Logo
644 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
