Question about Whirlpool WFW9400S
Whirlpool duet sport HELP!!!
Hi, it;s been about a week since i could get back to you and i'm sorry! my washer started working o.k. but that was only for like 6-7 loads. first like i told you i was getting a f-33 code, but now i am getting a f-21 code? my wife put a load through the wash and it stoped. there is still cloaths in there with water, so it needs to spin/drain. i can not get it to spin. i checked the drain and changed the water hoses but i'm not sure what more to do now by myself. if you could let me know how to open my wahher and try to see whats up or if i can fix this i would be so happy. the mod is- wfw8300sw02 . again you have been so much help so far and i wish there were more helpfull people like you in this world, thanks in advance. have a good day. CODE F21 WASHING MACHINE WILL NOT COMPLETLEY RINSE AND IT DOES NOT SPIN. IT DRAINS SLOW AND LEAVES WATER IN AND DOES NOT SPIN.
IT IS A FRONT LOADER MODEL wfw8300sw02
  • Whirlpool Master
  • 3,361 Answers
Remove and clean your drain pump.
Check the pump motor impellers.
If you have water in there, have a shop vac close by.
Posted on Mar 10, 2009
Washer stops during cycle with an error F20
Hi
Please check this link to get error F 20 resolved:-
http://www.appliancerepairlesson.com/2011/03/12/how-to-fix-whirlpool-duet-sport-error-code-f20-washer-repair-troubleshooting/
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Aug 02, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet Sport Model WFW8300SW0 basket won't
The following list of codes indicates an electronics communication problem with the washer: - Duet HT washer - F01, F03, F06, F11, F23, F24, F27, F28, F29, F30, F31, F32, F35, F42, F61, F62, F63, F64, F65, F70, F71, and F99
If Pause/Cancel does not work:
  1. Unplug washer or disconnect power for one minute.
  2. Plug in washer or reconnect power.
  3. Re-select the cycle and press Start.
NOTE: If the error remains on the display, call for service.
I would first replace the door latch/lock assembly, a number of users have and it fixed the F-11 error code completely. Its the cheapest part for this problem.
Hope helps.
Jun 27, 2011 | Whirlpool Duet Sport HT WFW8400TE Washer
My whirlpool front load washing machine displays F20. Water supply ok. Pls help
The only Whirlpool list I have (generic) has F20 as 'control unit failure'. Sorry ;-0(
If this has assisted and/or clarified the situation for you please consider a 4 thumbs up on our rating.
Thanks and good luck!
John C
Jun 04, 2011 | Whirlpool Duet Sport HT WFW8400TE Washer
My washer will not start it says" F-01" and constantly blinks when I try to press start. HELP!
Hi
Thanks for using FixYa. Error F01 in your whirlpool duet sport indicates EEPROM error which means that a communication error between the Central Control Unit (CCU)
and the EEPROM onboard the CCU occurred. This error also occurs when the pump driver fails to activate and/or one of the main relays is not working. To resolve this issue leave the unit unplugged for 5-10 minutes so that if this was caused due to power surge it is cleared. Also check the CCU (central control unit), if bad you’ll have to replace it.
Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Aug 23, 2010 | Whirlpool Duet Sport HT WFW8400TE Washer
Duet Sport HT WFW8400TE Washer: Whirlpool Duet Sport HT front loader is stopping b...
First check your washer plug to see if the connections are tightly screwed. Next check your filter if you haven't for long.
Remove the 3 screws at the bottom of the front panel under the washer door. Your filter door will be light brown. If you find a hose there it is to drain out excess water (water that could not be drained by your pump) After you hv drained unscrew the cap and remove all the junk inside. Have a large plastic bag to catch junk and water. Refit carefully after cleaning out. If not solved, something shd be blocking your pump, check this out
How abt a nice rating for the free help? Thnks
May 14, 2010 | Whirlpool Duet Sport HT WFW8400TE Washer
Front loader is making funny noises. It was
please contact the service authority because this is beyond your limit. to solve your problem, the back panel has to remove and only the service engineer knows the skill.......................sorry friend!
May 14, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool WFW9400S Logo
305 people viewed this question
Dan Webster
Dan Webster
Mike Cairns
Mike Cairns
prem mathew
