Question about Shure Audio Players & Recorders
We have a five pin microphone on a P.A. system which was originally installed in 1976. When the microphone is powered up we get a loud buzz, but only in one of the four available plugs. The other three plugs work fine. Any ideas what may be causing this?
    Problem Solver:
  • 7 Answers
I play in a band and we had he same problem. No matter where we plugged the mic it would buzz. We bought a shieled cord and that took care of the problem. That may work. What type of PA head are you using. ?
Posted on Mar 10, 2009
Mxl 993 false contact
Most likely a bad or improperly wired cable assembly. Pin 1 is always ground. Depending on manufacturer Pins 2 and 3 are Audio High and Audio Low.
Mar 21, 2014 | MXL 993 Professional Microphone
Peavey Ecort is working fine but has a loud buzzing that slowly gets
This is often caused by the failure of the large capacitor(s) in the power supply. The noise being the 50/60hz mains hum getting in. They will be the biggest Capacitors in the system with a value around 4700UF or greater, so you can't fail to see them.
Jun 14, 2013 | Peavey Audio Players & Recorders
How much price value
The Escort's integrated design allows for ease of transportation, while its user-friendly controls offer ease of operation, making it the perfect choice for schools, churches, civic organizations and small musical groups. The Escort features dual two-way speakers driven by a five-channel, 300 Watt stereo powered mixer, making it ideal for both vocal and musical applications. The system also includes a PV®i unidirectional (cardioid pattern) dynamic microphone, two folding speaker stands and all necessary connecting cables. Among many professional features, the mixer includes 60mm faders, a five-band graphic equalizer with FLS® (Feedback Locating System) and digital reverb. The carrying case provides storage for all the system componets with ample room for additional mics and cables. This clever design incorporates the speakers into the package, allowing the unit to be easily carried or pulled along on its luggage-style wheels.
Specification
  • Convenient package with luggage-style wheels
  • Two-way speaker system with 10" woofer and piezoelectric horn
  • Five-channel powered mixer
  • Four XLR mic inputs with 15 V phantom power
  • Two stereo line inputs
  • 60 mm faders
  • High quality digital reverb
  • 300 Watts output power (150 Watts per channel) with DDT™
  • Five-band graphic equalizer with FLS
  • Two folding speaker stands
  • One PV®i cardioid dynamic microphone with cable
  • Two 25' speaker cables
  • Storage compartments for microphones, cables and accessories
  • Weight Packed: 64.00 lb(29.029 kg)
  • Width Packed: 16.62 x Depth Packed: 39.75 x Height Packed: 17.62
£499.00.
$649.99
$649.99
May 05, 2011 | Peavey Escort 2000 Microphone
My woofer is giving a loud 'buzzing' sound when it is switched on.
Make sure your amp's power cord does NOT have a pin cut off. If it was designed to have a 3 pin plug and one was cut off, than u would have this kind of problem
Oct 31, 2010 | Altec Lansing ® Multimedia 3pc...
When the the Fender Passport 250 is plugged into the computer through the stereo out, there is feedback/buzz in addition to the sounds the microphones pick up, even when the mikes are off.
If there is a 120hz buzz then there is a ground loop between the computer and the passport. You need to get a ground isolator to go between the two. If the buzz is deeper the may be a audio ground off or the hum is comming from the power supply
Dec 27, 2009 | Lectrosonics FENDER PD-250 PASSPORT SYSTEM...
A buzzing sound
The cables always a usual suspect, but if you are using a tube mic, wich have their own power supply, you don't use phantom power and it can damage the mics power supply, so take phantom power off that mic and if that doesn't cure the buzz then I would change the cable next.
Jul 18, 2008 | Electro-Harmonix EH-TM Microphone
Shure buzz
check the lead connecting the receiver to system by replacing it out. Check that the correct power supply is still being used.
Dec 12, 2007 | Shure Beta 58 Microphone
Mwave made loud buzzing noise then didn't heat up anymore
When there's a loud buzz like that, it does not heat, and does not blow the fuse, it is usually a defective magnetron. Did it sound something like someone making a "gurgling" sound into a coffee cup? I think this has a a one-year warranty, with n five-year warranty covering the magnetron. You can find a local Amana-authorized servicer here: http://amana.com/amana/jsp/portalhttp.do?cs=0&BV_UseBVCookie=Yes&NextPage=7
Mar 03, 2007 | Amana AMV1162 Microwave Oven
Buzzing noize
Have you tried using a different power adaptor? I have noticed with mine that the as the original failed there was a noticeable hum, a new power supply (of reasonable quality) solved the problem.
Feb 15, 2007 | ElectroVoice RE-1 UHF Wireless Handheld...
108 people viewed this question
Top Shure Audio Players & Recorders Experts
Michial Gueffroy
Ben Armstrong
Vito Vacirca Jr.
Are you a Shure Audio Player and Recorder Expert? Answer questions, earn points and help others
