Question about Mitsubishi VS-50703 50" Rear Projection Television
Blank screen i can only see a picture when the picture in picture is on in the menu otherwise its black and shuts off i have the same problem as mollymgoingl u can only see the picture in picture in picture or the screen is blank. I had a breaker trip turned it back on and this is what happened. is there a solution
  • 6 more comments
  • diehardniner Mar 11, 2009
    I forgot to put i lost inputs to. I only have Ant-A & Ant-B
    i can only see a picture when the picture in picture is on in the menu otherwise its black and shuts offi have the same problem as mollymgoingl u can only see the picture in picture in picture or the screen is blank. I had a breaker trip turned it back on and this is what happened. is there a solution Comment posted on Mar 11, 2009 I forgot to put down i lost inputs to. Iolny have Ant-A & Ant-B
    Mitsubishi VS-50703
    I tryed unpluging for 30 min.it but did not work
    i can only see a picture when the picture in picture is on in the menu otherwise its black and shuts offi have the same problem as mollymgoingl u can only see the picture in picture in picture or the screen is blank. I had a breaker trip turned it back on and this is what happened. is there a solution Comment posted on Mar 11, 2009 I forgot to put down i lost inputs to. Iolny have Ant-A & Ant-B mitsubishi VS-50703
  • diehardniner Mar 12, 2009
    can't find any burnt components or any thing else whats next
  • diehardniner Mar 13, 2009
    i did not get a responce on my last message
  • diehardniner Mar 17, 2009
    I tryed everything u guys told me to do but did not work.I started messing with settings i change something but not sure what and the picture came back. this mite held u guys figue it out and help the other people.
    Sergeant:
  • 300 Answers
As the ic on the main control board is gone weak and needs replacement.the IC368JC controls the picture activity and settings in the tv.if this IC fails nothing gets adjusted.so it needs a replacemt from a professional.
thanks.
Posted on Mar 13, 2009
  • Mitsubishi Master
  • 19,396 Answers
Hi there.
Try going to the TV menu and locate the reset option on the settings menu.
If the problem is not fixed after TV reset, then there is an internal fault , and the TV must be repaired.
Posted on Mar 12, 2009
    Sergeant:
    Champion:
  • 435 Answers
Hi, Open the unit and look for any burnt or defective components.
Replace them if you find anything and try.
Posted on Mar 11, 2009
  • 11,896 Answers
You can leave tv unplugged for at least 4 hours. This is what is called a "master reset".
If this does not correct the problem, that you may have a bad system board which will have to be tested by tech.
Check your menu settings to see if you have a "default" setting to set tv back to origional settings. Also you may want to check the picture settings in the menu, to see if they look familiar or set to your standards.
  • 3 more comments
  • Nate Stansfield
    Nate Stansfield Mar 11, 2009
    you must leave unplugged for AT LEAST 4 HOURS! Better yet overnight.
    30 minutes is just not enough time for the reset. All power must have time to drain from capacitors and power supply.
  • Nate Stansfield
    Nate Stansfield Mar 13, 2009
    if a system electronical board component has burnt out, you would not visually be able to see the bad part. You will have to have your television tested by a tv repairman.
    I do believe the power surge has fried a component.
  • Nate Stansfield
    Nate Stansfield Mar 16, 2009
    Try leaving your TV unplugged OVERNIGHT.
  • Nate Stansfield
    Nate Stansfield Mar 31, 2009
    I would try different settings and see if it improves. I do believe it is some setting that is causing the problem. If the pic in pic is working, that I highly doubt there is anything wrong physicall with the tv and that the problem is just a setting.
  • Nate Stansfield
    Nate Stansfield Apr 23, 2009
    How did this work for you?
  • 10,594 Answers
First attempt is to unplug TV from AC, replug back in check.
Actually main picture of your TV is just disappear and I need to know exact model of TV to check its schematics for further help.
Posted on Mar 10, 2009
    Genius:
  • 1,550 Answers
Try reset .
Unplug the unit from power chord for 30 minutes and plug back the power chord to the unit .
This will reset your unit .
It seems that the back light is malfunctioning or needs to be replaced the fact that it turns off after a few seconds indicates that is getting over heated.
Carefully remove the back and check all of the connectors where ribbon cables are attached to the various boards.
Try resetting them.
  • SAM ANDERSON Mar 12, 2009
    Just go to settings in your tv and restore to factory settings .
    Factory settings will delete your current settings .
When turned on screen is black but you can view menu and stored pictures
Since you can see the menus, did you try to go to the setup menu, and adjust the brightness of the screen?
It is in the setup menu, the line under Sound settings. Try to make the display brighter and don't forget to ok that one, because otherwise nothing will be changed. OK with the ok / Func button.
Jan 14, 2014 | Olympus FE-340 Digital Camera
Blank screen
If you can play back captured images without any problem then your camera has a faulty CCD sensor. If you can get hold of a new CCD sensor block for this model somehow then you can install it yourself. Otherwise camera has to go to your Nikon agent.
Sep 14, 2007 | Nikon COOLPIX P4 Digital Camera
LCD Display is Black
the image in the LCD monitor will darken in strong sunlight or bright light. This is normal occurrrence in device CCDs and does not contitute a malfunction. This image will not be recoded when shooting still photos, but it will be recorded wihen shooting movies.Read you owner manual and adjust the MENU, according with your o. manual.Otherwise you must go the repair shop
God bless you
Jul 31, 2012 | Canon Cameras
Screen is blank but still takes pictures fine
Try removing the battery or reseting the unit if there is a reset button. Otherwise it sounds like the screen died.
Dec 08, 2009 | Canon PowerShot SD750 / IXUS 75 Digital...
Black box on top of picture
This sounds like the text function is turned on in the closed captioning part of the menu. If the remote has a separate captioning button press that until captioning and text are off. Otherwise the caption/text settings are in the customer menu. Go into the menu to the captioning options & shut captioning/text off and see if this corrects your problem.
Nov 09, 2009 | JVC AV-27D201 27" TV
Our camera when you turn it on has a blank screen and you cannot take pictures. You can review pictures and see the different menu modes, but the screen is otherwise black.
This sounds like it might be a defective CCD imager. If so, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check the following two links for more info:
http://camerarepair.blogspot.com/2007/11/canon-digital-cameras-showing-black.html
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=225&modelid=13390&keycode=2112&id=29819
Applicable cameras include:
A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110, IXUS V2/300/400/430/500, IXY Digital 200a/300a/400/450/500
Jul 03, 2009 | Canon PowerShot S1 IS Digital Camera
Same problem. screen is black when turned on. where can i repair?
Jun 21, 2009 | Canon PowerShot S1 IS Digital Camera
Canon Powershot A70: LCD screen went blank - I can still access all menu functions (timer, resolution etc), but the screen is completely black otherwise. If i take a picture using the manual view finder,...
I had a A70 that would still take pictures, but the screen did not show a picture. I did some research and found that this is somewhat a common problems with some of the Canon Powershots to include the A70 where the LCD screens expire. I believe that if the camera gets too hot, such as being left in a vehicle the LCD seperates. I sent my camera to Canon and they fixed it for free. It took about 4-6 weeks to receive my camera back, and now it works perfectly. They did a great job on communicating with me, and fixing the issue. I think that alone is worth buying a Canon. The link below should help you.
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&keycode=2112&fcategoryid=221&modelid=8776
Sep 27, 2008 | Cameras
Black square on one channel
that's a picture inside a picture option, and it sounds like the inside picture is set for a blank channel...just go to the menu, and shut off the picture in a picture option..should do the trick..
and keep the kids away from the machine
May 24, 2008 | Insignia IS-LCDTV32 32 in. Television
Lcd screen is black
you have to disamled your camera and reconnect the LCD it happens when the cable of the LCD is half out
Nov 28, 2007 | Olympus FE-170 Digital Camera
Televison & Video Logo
117 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
