Question about HP (346789-001) CD-RW/DVD-ROM Combo Drive
Lg cd/dvd manufacture-(standard cd-rom driver) wont play dvd
My lg gcc-4520b cd/dvd driver wont play dvds and i dont have the original cd that the driver was on. i put dvd in, it starts to spin, green light blinks, it stops >:( , i get pissed off. please help
I dont have original cd with drivers,only from xp and have update 1.07. How i can update my drivers for lg gcc-4521b?
Hi and welcome zarevg !
You can try an automatic update via the Device Manager where you select CD/DVDrom drives and double click on the drive's name . select driver and update driver , let Windows search the best available driver .
You also can download the driver from here :
Note : It seems there are no drivers beyond XP available .
Best regards ,
Fanaudi
Feb 16, 2011 | LG (GCC-4521BI) CD-RW/DVD-ROM (Combo)...
Will this cd/dvd unit burn dvds? It's an HL-DT-ST RW/DVD GCC-H23N
no you will needa dvd-rw unit to burn dvd's cd-rw/dvd-rom will not burn a dvd being a dvd-rom
Jan 13, 2011 | LG (GCC-H23NB) CD-RW/DVD-ROM Combo Drive
I can play CDs but not DVDs
Often problems such as this can be solved by updating firmware . without knowing anything about the model might i suggest visiting lg.com and searching for instructions on updating firmware.
Dec 19, 2010 | LG (GCC-H23NB) CD-RW/DVD-ROM Combo Drive
LG GCC-4521B play DVD without sound
Check for the sound drivers, if the drive reads cd/dvd's its absolutely working fine.
Jul 27, 2010 | LG (GCC-4521BI) CD-RW/DVD-ROM (Combo)...
HL-DT-ST RW/DVD GCC-4243N wont burn dvds
Try uninstalling the Driver in Device Manager: in XP or earlier: Start/Control Panel/System/Hardware Tab/Device Manager, or in Vista & 7: Start/Control Panel/Device Manager.
Once in Device Manager click on the + sign that is in front of 'DVD/CD ROM drives' to open it up, then right click on the model of the Optical Drive in question.
Click Properties/Driver Tab/Uninstall (Advanced) & this will remove the driver if it is corrupt. Restart your system & the Hardware Manager will recognise the Optical Drive & install the necessary Driver.
If this doesn't solve your dillema then I hope that you have a warranty. Good luck in trying.
Kindest regards,
Ste
Apr 02, 2010 | LG (GCC4243N) CD-RW/DVD-ROM (Combo) Burner
I installed a LG gcc-4320b on my mom's dell and this cd-rw/dvd rom came out of an old gateway, it finds it and says it's working but it wont do anything wont autoplay or my burning software (roxio) says...
dells r very funny, most hardware won't work with dells. your better off getting a clone or a no name brand from small computer place so u can add and modifiy your computer as new products comeout. try newegg.com or fryeselectronic.com great prices and can build your own computer
Feb 28, 2010 | LG GCC 4320B CD-RW/DVD-ROM Burner
Dont have drivers for model gcc-4320b cd-rw / dvd-rom drive where to download from
Check with the vendor/dealer who supplied the product. Also check and download drivers from hte vendor site.
Hope this gives you the information you need
Dec 16, 2009 | LG GCC 4320B CD-RW/DVD-ROM Burner
When I try to play DVD, nothing happens.
change the lens of DVD. its a common problem. due to over use.
May 31, 2009 | LG GCC 4520B CD-RW/DVD-ROM Burner
Playing PC DVD roms problem
Dvd drives can read from both DVD and CD however due to technological limitations most DVD-ROM or RAM read up to slightly higher speeds for CDs than DVDs.
When burning DVDs professional companies that make prerecorded disks burn their disk at low speeds in an effort to achieve both compatibility and low errors, that is the reason their DVDs play on most DVD-ROMs. However DVDs me and you burn at home and work at high speeds are prone to errors and incompatibility with low reading speed drives.
As a result if your DVD-ROM has a low maximum reading speed then it can only read those prerecorded DVDs and only DVDs recorded at low speeds provided thre are not scratched.
I believe you managed to read those DVD movies if they were pre recorded.
Nov 29, 2007 | LG (GCC-4522BI) CD-RW/DVD-ROM (Combo)...
HP (346789-001) CD-RW/DVD-ROM Combo Drive Logo
225 people viewed this question
Top HP Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
