My compaq sr2011wm will not advance during the pc recovery. It just hangs when it gets to the screen requiring the supplemental recovery disc. I wait hours and still nothing happens. I have tried swapping out the hard drive and the cd rom in case it was not reading it but still nothing happns
    Sergeant:
    Champion:
  • 224 Answers
Please check the recovery CD's for scratches. It could be that the cdrom is trying to read the CD's but unable to due tot he scratches. Are you able to read the same CD's on another computer?
If you can and you're sure the media is good, then try and clear all partitions on the hard driive before attemting to restore your laptop. Usually, if a parttion exists, the recovery finds it hard to re-partition.
Please do let me know if this works...
Posted on Mar 10, 2009
  • 10,515 Answers
The exact procedure of pc recovery would be
http://h10025.www1.hp.com/ewfrf/wc/fastFaqLiteDocument?lc=en&cc=uk&dlc=en&docname=bph08097
Make sure you are following right steps. Still if issue persists, Buzz me.
Do rate this solution.
Thanks for using Fixya.
    Genius:
  • 1,550 Answers
Just restart your computer and try using pc recovery .
    Brigadier General:
  • 5,158 Answers
Do you have the other disc ?
  • Roberta Smith
    Roberta Smith Mar 10, 2009
    also examine the disc(s) for scratches or smudges... and ensure also that if it is a dvd that you are using a dvd rom
Trying to fix an older pc presario SR2001WM it loads up to a black screen with the error: reboot and select proper boot device or insert boot media in selected boot device and press a key could you...
Most PC's built in this time frame no longer shipped with a separate set of recovery CD's. Instead, the manufacturer provided a separate partition on the hard drive that contained the recovery program. To access this program, you would first shut off the system and disconnect all peripherals other than your keyboard and mouse. Then start the computer, pressing the F10 key on your keyboard repeatedly as the HP/Compaq logo appears. A recovery menu would appear, giving you the option to perform either a standard recovery or, under the Advanced options, a destructive recovery. The standard recovery will attempt to repair the system, leaving any of your data files intact. The destructive recovery option erases everything, then restored the computer to its original, out of box configuration.
Unfortunately, the recovery partition is on the hard drive itself, so if your problem is due to a hardware failure rather than simply a software crash, the above steps will not work. If this is the case, you will need to contact HP/Compaq and request a restore CD. The following link will take you to their website, and walk you through the process of determining if a set of recovery discs are available for your PC. Select your operating system from the drop down menu and then follow the link labeled Recovery Media.
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?os=228&lc=en&cc=us&dlc=en&sw_lang=&product=3292424#N364
I hope this helps!
Mar 02, 2011 | HP Compaq Presario SR2011WM PC Desktop
My pc is lock .my dauther try to many password
Some times the CAPS Lock key may be on, so please make sure that the CAPS Lock key is off.
If the issue still exists, I request you to perform the full system recovery using the recovery disks. To perform this full system recovery, you can use the recovery disks that you have created using the recovery partition.
Use the recovery discs to restore the PC by following the steps below:
1. Insert the recovery disc in the optical disc drive and start the computer.
If the computer is running, insert the recovery disc and immediately click Start and select Restart to force the computer to start from the recovery disc.
2. When prompted, Press any key to boot from CD or DVD, press any key on the keyboard.
3. Allow the recovery disc to start and load the required files while the Microsoft loading screen is displayed. It may take several minutes to load the required files.
4. When the HP Recovery Manager window displays, click Advanced options , System recovery , and then click Next to open the Recovery Manager.
5. Follow the on-screen instructions and perform the required actions.
NOTE: Do not interrupt the recovery process even though the computer may restart and the Windows desktop may display at various times.
· When prompted, follow the on-screen instructions to Backup the user files.
After performing the backup, when prompted, re-insert the recovery disc, and then click Next to continue the recovery process.
· A status box is displayed to indicate the status of the recovery and the estimated time remaining.
· If you used multiple discs when you created the personalized recovery discs, follow the prompts to remove the first disc and insert any requested discs.
6. When prompted to Insert the Supplemental driver disc , take one of the following actions:
· If you purchased a replacement recovery disc from HP, and it included a Supplemental driver disc, insert the disc and click OK or Next . The recovery program checks the supplemental disc and installs the specific needed files.
After the Supplemental files are installed, a prompt is displayed to remove the Supplemental disc and insert the original recovery disc.
· If you purchased a replacement recovery disc from HP, and it did not include a Supplemental driver disc, click Skip or Cancel . The recovery program will ignore the request and install the next file on the recovery disc.
· If you created a personal recovery disc, press Next to continue.
7. Continue following the on-screen instructions to complete the recovery process.
NOTE: If you have not created a personal recovery disc, or the recovery disc fails or become corrupted, see HP Notebook PCs - Order Recovery Discs for Vista as your notebook is preinstalled with Genuine Windows Vista Home Premium with Service Pack 1.
For detailed steps you can refer the provided web link:
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&dlc=en&cc=us&docname=c00809678&product=18703
NOTE: Clicking the above link may give an error indicating that it is invalid. If this occurs, copy the link and paste it on the address bar in your browser until the complete address is displayed in the Address box.
If you do not have the recovery disks you can order these recovery disks from the local HP phone support. Please use the provided phone number to contact the local HP phone support.
Phone number: 800-474-6836
May 29, 2010 | HP Pavilion dv6000z Notebook
On my friends Compaq: running xp media ctr. He
If he has a product key for the computer he can borrow an XP disc from a friend and reload it using his keyand it should be fine.
He should then create a restore disc and keep it.
Jan 05, 2010 | HP Compaq Presario SR2011WM PC Desktop
In the device manager, Device manager unknown acpi
You would have to install the ATI chipset drivers , the same can be downloaded from the site below
http://h10025.www1.hp.com/ewfrf/wc/softwareList?os=228&lc=en&dlc=en&cc=us&lang=en&product=3292424
Thanks
Proton
Jul 04, 2009 | HP Compaq Presario SR2011WM PC Desktop
Reset my computer
Recovering during startup Use the following steps to perform a recovery from the hard drive :
  1. Backup files from the My Documents folder and from other folders you may have created.
  2. Disconnect all connected devices (such as the Personal Media Drive, USB drives, printer, and fax), remove media from drives, and remove any recently added internal hardware. Do not disconnect the monitor, keyboard, mouse, and power cord.
  3. Turn on the computer.
  4. Just after the first screen appears (the logo screen), press the F10 key repeatedly until a recovery menu appears.
  5. Select one of the following procedures, depending on which recovery type you want to perform:
    • To perform a standard system recovery, click Next , and then click Yes .
    • To perform a destructive recovery, click Advanced , (select Destructive Recovery ) and then click Next . CAUTION: A destructive recovery will format the hard drive. This will delete all the information on the hard drive and reinstall Windows XP and the original software that came with the computer .
  6. Read and respond to each window and screen that appears.
  7. After the System Recovery is complete, the computer restarts and continues into Windows setup. Complete the setup screens and wait until the computer finishes the setup. NOTE: It may take a long time to complete Windows setup. This time varies and may take over several hours, depending on the amount of files that were stored in the user account folders (for example, My Documents and the Desktop).
  8. Before using your computer, update and protect your computer. For more information, refer to Things To Do After Performing a System Recovery in Windows XP .
  9. Reinstall applications that you added after purchasing the PC, and any files you need from backup.
Apr 05, 2009 | HP Compaq Presario SR2011WM PC Desktop
Computer hangs during pc recovery process
you may need to swap the disc from one cd-rom to another.
Mar 10, 2009 | HP Compaq Presario SR2011WM PC Desktop
I'm having problems with WindowsXP loading at start-up
I don't think you have a virus, Norton 360 is a very good antivirus program and would have caught it. Try disabling all of the Norton 360 features then load the Windows XP disc. Sometimes anti-virus programs interfere with the processs. I am assuming you have the Windows XP original disc. This should work.
Dec 28, 2008 | HP Compaq Presario SR2011WM PC Desktop
Doing a recovery
vista is junk... not user friendly.. there's more to it than that.. like 4 more steps.... good luck figuring it out..
Jun 18, 2008 | HP Compaq Presario SR2150NX PC Desktop
Computers & Internet Logo
19 people viewed this question
David Payne
David Payne
