Question about Garden
The pump just hums when plugged in - Garden
  • judesman2 Mar 26, 2009
    where can i buy the pump motor?
  • Anonymous Apr 12, 2009
    I have the same problem - just bought 1 of these - sunjet 150, plugged it in for the first time and it just hums, doesn't pump out water, am I doing something wrong???
I have one that did the same thing. You need to take apart the pump end and clean it thoroughly first to see if that solves your problem.
Posted on Apr 01, 2009
  • 6,784 Answers
Hi, the motor has windings that can go bad in time. this hum you are hearing is called a A.C. hum. this will occur when the motor windings are bad. you will need to replace the pump motor. this will fix this issue.
Posted on Mar 10, 2009
We have a little pump to pump water from fruit cellar. It was working, but now just hums and doesn't pump? Any ideas?
try to spin the impeller with a screw driver if it is accessible. if not unplug it and take it apart and spin the impeller to free it up. clean all the gunk out while you are in there. put it back together and plug it in. don't let it hum with out pumping it will burn up.
Dec 09, 2014 | Cars & Trucks
My R520-T7 pump hums but will not turn on
sounds like a jammed or detached impeller, located at the bottom of the pump motor. Repairs are unreliable and replacement is inexpensive ($130 for a comparable pump) recommend replacing the pump.
May 10, 2014 | Water ACE SUBMERSIBLE SUMP PUMP 1/3 HP
Pump is running/humming, but not grinding
The pump may have become plugged again immediately
May 28, 2013 | Star Water Systems PowerFlush Sewage...
Drain pump[ hums
.It is possible that lack of voltage to the pump or fault in the pump can cause the hum. If there is intermittent power to the drain valve/pump then the program controller unit is a suspect.
Cleaning a pump: http://www.youtube.com/watch?v=zKjKi50YBpI&NR=1&feature=fvwp
Replacing the pump on a Bosch machine, please check this link for tips:
http://www.espares.co.uk/advice/washing-machines/a/7/1373/how-to-replace-the-pump-on-a-washing-machine-.html
Feb 11, 2013 | Washing Machines
No fuel to trottle body carberator the car is not getting any fuel from tank
fuel pump is in tank listen to hear it hum when u turn the key on. if its humming then it will be a plugged up filter, if it isnt humming for a few seconds when u turn the key on the test to see if the power is getting to the pump when the key is turned on. it may also be the safety shut down relay if the pump isnt getting any power
Jan 05, 2011 | 1988 Chevrolet Corsica
Toilet will not work. when plugged it it hums even if i dont push the button,
When the unit is humming it could be something stuck on the blade or impeller preventing it from spinning. The drain pipe can be clogged or the capacitor which drives the blade and impeller may have gone bad. Tipically when the capacitor goes bad it will just hum and not pump the waste out.
Aug 21, 2010 | Saniflo & Saniplus& Macerator Pump
Motor hums, but propeller will not turn
I HAVE A ZOELLER PUMP AND THE IMPELLER WONT TURN I TAKE A SCREW DRIVER AND TURN IT AND IT WORKS STOP THE PUMP AND IT HUMS CAN THE IMPELLER COME OFF IF IT DOES HOW DO YOU TAKE IT OFF.
May 06, 2009 | Water ACE SUBMERSIBLE SUMP PUMP 1/3 HP
95 honda civic cranks but eng. dont fire, found gas filter plugged gas not flowing out of gas lines tank has 3gls
check for fuel pump hum by the gas tank with the key on, if no hum check fuses and relays (under the hood and dash) if they are good replace fuel pump. if you hear humming try replacing the fuel filter
Apr 20, 2009 | 1995 Honda Civic
I think that my fuel pump won't work because i can't start the engine anywaymy car is a dodge sprinter diesel 2007 (v6 , 3.0 l )
place key in ignition. turn to acc ,make sure radio is off listen for small hum it last about 15 to30 sec if you hear hum pump good . no hum check fuse if good more than likey bad pump. check if it has a glow plug
Mar 29, 2009 | 2007 Dodge Sprinter
There is a noise (hum) when the spin is set. No spin.
probably pump plugged if that is a front load remove bottom panel pump has a clean out port clean thoroughly and retry is still only hum pump impeller may be jammed or damaged ..removing pump will allow better acess to impeller area
Aug 22, 2008 | Whirlpool Washing Machines
Garden Logo
1,166 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
