Question about Seagate (ST380011A) 80 GB IDE Hard Drive
I have a seagate 80GB Harddisk, it was working fine but few days before I installed Dreamweaver from Net. after restarting me PC the Hrddisk show lots problems some time it does not formate, sometime window become corrupt and some time it sounds unusual and some time it take very much long time to become refresh so if any one help?
Download tiny xp and burn it on a cd and run spinrite located in recovery tools on the tiny xp. and that should fix the problem. hr29223
Posted on Mar 10, 2009
My harddisk , seagates replica single PC unable to detect all of the sudden.... it shows that the window unable to install the driver.. hope to find a solution cause all my backup data inside..
Hi t_c_low2005 ,
First of all , please do not panic,
Nothing would happen to your data unless you deleted it intentionally or your hard disk has suffered a hardware damage.
I would recommend you to check if you have an extension wires for USB connected , if yes then remove them and connect the hard disk directly to the USB slots on your motherboard.
This should work fine...:) Hope it helps.
May 09, 2011 | Seagate Replica 250 GB USB 2.0 Complete...
MSI RC410 - cannot detect Sata HDD
i think the problem is with ur SATA HDD. To confirm, try another SATA HDD on ur mother board and see if the problem persists
Sep 20, 2009 | ASUS P5RD1-VM Motherboard
Disk manager for seagate 160 gb sata barracuda hard disk
windows xp setup not creat the partation.
and not show the tha harddisk,but harddisk are showing the bios setup.
my system is ACER ASPIRE tower Casing.
Jan 10, 2009 | Seagate (ST3160827AS) 160 GB Hard Drive
Install window on a portable ide harddisk
i dont think so dat window could b installed on usb.
Dec 31, 2008 | Computers & Internet
Problem related Seagate Hard Disk
i also encountered that problem about using seagate. first make sure that theres no loose connection between the MotherB and HardDisk. Or maybe it has a virus or a bad sector.,Try this, if you have another hard disk, try to make the 80gb a slave drive. then format it using windows base process (Right click the drive then FORMAT). or try DEFRAGMENTATION and scandisk for that drive.
Dec 01, 2008 | Seagate 500GB Maxtor Diamondmax21 SATA2...
Adobe dreamweaver does not start
Try to disabled unwanted started items & services from msconfig.
Try to launch it in a new account.
Oct 30, 2008 | Adobe Dreamweaver CS3 ( Windows ) for PC...
Sata drive not detected
just no other solution except upgrading BIOS properly
Sep 24, 2008 | Seagate Barracuda 7200.10 500 GB SATA Hard...
Barracuda hard disk 80gb
the first boot sector of the hard drive is corrupt so fdisk wont work
please use software to repair the boot sectors zero and 63.
usually the softwares are superfdisk which is free on net.
also if you fail use seagate disk manager bootable version. it will be very quick and handy in long term too to format seagate hard drives
Sep 17, 2008 | Seagate Barracuda 7200.7 ST380011A 80 GB...
More than likely, since you say you did a DOS install of the OS, you did not set the FDISK parameters to set your primary drive. Insert the DOS CD you used to format the system. Boot to a DOS prompt and run the FDISK command. It should have an option, I believe it is number 2 or 3 to "Set primary drive". Select your hard disk 0 as this drive and you should be fine at rhat point.
Seagate harddrive diskread error
go to bios and see there whether it is showing showing your hard disk or not if it is showing then re-install your XP again format your hard disk with the slow formating option,while re-installing it.
Nov 23, 2007 | Asrock GE PRO-M2 Motherboard
Seagate (ST380011A) 80 GB IDE Hard Drive Logo
182 people viewed this question
Top Seagate Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Computer Links
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
