Question about Bose Acoustimass 10 III System
My sound in cable was missplase and can i make it my self and pls any body can send me the cable structre. pls...........
  • 10 Answers
Here's a diagram of the 15-pin serial input cable that came with my Acoustimass 10 IV system. You just need a 15-pin female d-type connector, one RCA connector and a lot of speaker wire. Here's my diagram:
Posted on Mar 22, 2010
My pa system recieves signal but wont send any sound out
Check cables to speakers from amp if any. Possible crossover or channel failure.
Apr 08, 2014 | Audio Players & Recorders
My subwoofer keeps shorting
Voice coil shorts with its body. It cannot be repaired. Replace the speaker with an other one, similar with all respect, including impedence.
Gopakumar Gopalan Google
Feb 26, 2014 | Bush Audio Players & Recorders
It states the power is on due to the front panel green light. I can move the sound bars up and down but there is no sound from the unit. I checked the cable etc but still no sound. I love this sub....
I wrote to Kef support about an identical issue. Their replay is below.
By the description you have given, it sounds like the power amplifier
board in the subwoofer has failed.
Unfortunately your subwoofer is no longer covered under warranty as the
electronics inside comes with a one year warranty as with all KEF
electronics, and the warranty card would have been supplied inside the
box.
However, you can return the amplifier section to us by removing the
screws on the very outer edge of the back of the unit and disconnecting
the cables inside. Once removed, carefully package the amplifier and
then contact the Service department on 01622 672261 with the serial
number to hand, they will then give you a returns number. Once you have
a returns number, you can send it to the following address with a
covering letter. When sending the parcel, please make sure that you send
it recorded delivery or get a tracking number if sending by courier.
PLEASE NOTE THAT ITEMS NOT BOOKED IN WITH THE SERVICE DEPARTMENT BEFORE
DESPATCH, MAY INCUR FURTHER DELAY.
The address is as follows:
F.A.O. SERVICE
GP Acoustics
Eccleston Road
Tovil
Maidstone
Kent
ME15 6QP
Mar 21, 2011 | KEF Audio PSW 4000 Subwoofer
Buzzing/hum website say it's a ground loop or amp issue. Whats the difference and how can I easily fix it?
Hello,the most common solution is to simply replace the subwoofer cable itself. the ground on this cable is the outside of the connector and not the pin in the center and they do fail. You can use any rca cable as a quick test to confirm if the cable is at fault.
Sep 13, 2010 | Energry Speakers Energy Speakers S8.3...
Subwoofer turns on but no sound
put an RCA cable to the inputs and while touching the end of the RCA, increase the volume gradually to hear a 60HZ humming sound...check also with the settings or mode. What particular subwoofer model is this? do you have a picture of the panel plate? pls send to jhunn06 at gmail dot com
Aug 10, 2009 | Audio Players & Recorders
How to make a 15 pin female sound in cable
Ya, here is a diagram I made of my Acoustimass 10 IV input cable. All you need is a female 15-pin d-type connector and a bunch of speaker cable (also one RCA connector for sub connection). Here's my diagram:
Mar 10, 2009 | Bose Acoustimass 10 III System
My computer sound system
Most likely the sub has the crossover in it, most likely the 2 input cables from whatever device you want to play through the system will plug into the sub then the 2 speaker cables will come out of the sub and go to the speakers, just be sure to have everything connected into and out of the sub and make sure the power cords for the speakers and sub are plugged in, I am assuming this is a self powered system wich means the amplifiers are built into the speakers and sub.
Aug 07, 2008 | Yamaha 5.1-Ch. Surround Sound Home Theater...
P200 Subwoofer all quiet
Try taking tha cable out of the amplifier and touching it, this should create a low hum, as your body is sending throug a small current. if this works then you may have accidently switched the sub woffer on in the amplefier. if however you get nothing through the sub then you may have a dry joint in the solder, or the board may be dead. Other option, try an other cable. they also use lead based solder so they do get old.
Dec 12, 2007 | Cambridge Soundworks P200 Subwoofer
Bose Acoustimass 10 III System Logo
849 people viewed this question
Top Bose Audio Players & Recorders Experts
Electro Med Services...
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
