Question about Lexmark X4270 All-In-One InkJet Printer
Fax won't send
I am trying to send a fax with my Dell 926 all in one printer. It is stuck on preparing and won't send the fax. I have tried to reboot the computer and I reinstalled the software. I checked the phone line and it is operating just fine. Any suggestions
  • goodemoot Mar 12, 2009
    same problem. dell 926. spent 3 hours on phone with dell. no luck. :(
Hallejuia!!! Someone from the Dell community forum posted this....it worked!!!
Yes. It has something to do with the time change. I had to go into the time in my pc and manually adjust (take off automatic daylight savings) the time. Once you do this you need to restart your system. That should take care of the issue.
Posted on Mar 12, 2009
All In one Dell printer 926 can't get it to send a fax. There's no place for a phone line to be hooked into it and it tells me there's no phone line but I have dsl and the phone line for home phone and dsl...
You can find information on your product here:
http://support.dell.com/support/topics/global.aspx/support/kcs/document?docid=266274#Issue0_3
I recommend you check to make sure you have the most current drivers for your PC modem and that you also download the User Guide for your printer for the guidance on using your printer to send and receive faxes.
You need to setup your system to use the modem in your PC.
Here is how your system should be setup:
http://img144.imageshack.us/img144/6615/nonstandaloneprinterdiaab7.jpg
Note that you will need a DSL filter on the phone line to your computer.
Feb 11, 2011 | Dell Photo 926 All-in-One Printer
All-in-one926 printer fax won't work
get all phone lines and connections checked or replaced also usb connections
Oct 03, 2009 | Dell 926 All-In-One InkJet Printer
I can print from my Dell 926 all in one, but it wont scan
Try removing your 926 icon in Printers and Faxes, disconnect the USB cable, restart your computer, reconnect the USB cable, see the 926 and install the driver again. If scan has never worked, you probably need a different driver.
Hope this helps.
Aug 06, 2009 | Dell 926 All-In-One InkJet Printer
Dell 926 won't recognize new color cartridge
Try this...shut down the printer. Insert new cartridge, let the printer cycle out with new cartridge. then reboot the computer. This should solve the problem. The cache in the printer will not cycle out. It wants to see the printer as a new entity
Jun 17, 2009 | Dell 926 All-In-One InkJet Printer
Since the time changed my All In One 926 sends the fax exactly one hour after I click send
I would go into the setup on the fax machine itself and look at the configuration. If you cannot fin anything set it back to its default settings.
Mar 12, 2009 | Dell 926 All-In-One InkJet Printer
Printer busy
Your printer has a pending jobs to print. Go to printers and faxes. Double click your printer delete all pending jobs.
Mar 03, 2009 | Dell 926 All-In-One InkJet Printer
Fax
Faxing from the 926 is a pretty straight forward process.
Put your document into the document feeder (or if is only one page, put it in the scanner area)
In the menu arrow down to FAX in the menu, enter the number you want to fax to, and push START.
That will scan the document, dial the number and send the fax.
There are additional options for faxing (like delayed fax, and a number of other options which can be found in the owners manual)
Jul 17, 2008 | Dell 926 All-In-One InkJet Printer
Lexmark X4270 All-In-One InkJet Printer Logo
471 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
