Question about Samsung 2220WM-HAS Monitor
Ghost images My 18 month old Samsung SyncMaster 2220WM has ghost images (images spread to the right). Is my monitor shot?
  • nike1234 Mar 10, 2009
    By "Ghost images (images spread to the right)" I DO NOT MEAN a fixed image burned to the screen. I mean that ALL IMAGES (on all pages that come up) have a slight ghost image to the right of them.
    President:
  • 1,188 Answers
Remove VGA cable from back of the monitor (if detachable), also remove from PC's VGA card.
With a dry toothbrush or similar brush remove any dust from the pins and blow away excess dirt.
Reconnect wires making sure connections are tight but not too tight.
If the problem remains then try checking if VGA card is loose or the connector.
There might be a problem with your display card if its old.
LCD monitors frequently come with a 3 year warranty. In the unlikely event your monitor is damaged then consider sending under warranty.
Posted on Jul 28, 2009
  • 76 Answers
Yes the images where left on the screen for a long period of time which burnt the images you see into the screen
Posted on Mar 10, 2009
I have my syncmaster 2220wm hooked up to my laptop. How can I get the monitor sound? It is only using the speakers on my laptop...??
Hello a 2250wm is actually a Viewsonic monitor not a Samsung monitor. To get the built in speakers to work you will need to connect the audio cable from your laptop to the monitor audio jack. This cable should have come with your monitor, it will have a headphone 3.5mm plug on both ends of the cable. If you do not have this cable yo will need to get one before you can make the speakers work right. Here is a link so you can get the cable if you need one.
http://www.ccl-la.com/catalog/product_info.php?cPath=83_86&products_id=176
Dec 05, 2012 | Samsung SyncMaster 2220WM 22" LCD Monitor
SyncMaster2220wm LCD, 3 years old, and 3 weeks. Display flashes on, then goes to black screen.
The problem is in the power supply inverter board caused by bad capacitors and poor solder connections, an attempt can be made to repair or replace the board, If a professional gets involved it will be pricey.
Apr 26, 2011 | Samsung SyncMaster 2220WM 22" LCD Monitor
Samsung Syncmaster 2220wm. All of sudden, the monitor went black. It does not show any light at all on the screen. The power light is on (light comes on green). I connected a different monitor, it worked...
Power capacitors on the power board most likely gone. You could get a qualified technician to investigate and repair by replacing the blown capacitiors ( you may notice a charring smell from the back of the monitor if they have gone). Cost of replacement is however likely to be more than the monitor replacement is worth. unlike CRT monitors, these are not designed to be easily repaired
Mar 27, 2011 | Samsung SyncMaster 2220WM 22" LCD Monitor
My Samsung syncmaster 2220WM will not stay on. It
The picture board on your monitor has been malfunctioning for quite the period but you did not notice it, since the screen goes blank, it means the picture board of your monitor has developed fault and will need to be replaced.
The best thing for you to do now is to take the monitor to a local repairer within your vicinity to help with the replacement of the picture board because the fault is not something you can fix yourself, in order not to complicate issues.
Take care.
Apr 25, 2010 | Samsung SyncMaster 2220WM 22" LCD Monitor
The Samsung Syncmaster 2220WM I have started to
blueangel617, If unit covered by warranty, use it first! It's free! Your next option is a possible ??? cash+dead unit swap-out for a same model refurbished unit from Samsung, if they have a program like that??? It depends on the AGE of unit! If you are not planning on doing DIY repair to your unit, or contracting out the work to local technician your next option for you as a consumer/user will possibly be trade-in for new! But, if you buy a new unit, the sales guy might drop the 2220WM on the computer tech's bench in the back room and say to the technician "here's another one to look at! See if you can do anything with it." Well, with a little bit of luck, (50/50 chance) the tech will open and inspect your unit and evaluate the condition of unit's "switch-mode-power-supply" and "CCFL inverter supply" make a decision to repair or not to repair. If the tech see's the "classic" common LCD problem, he just might invest less than $10 in parts and end up with a working 2220WM to give to his kid to use for another 1 to 3 years. Blueangel617, you and only you will determine what to do about your "black" or "black and blank" screen CCFL back-lit LCD monitor. I just hope I haven't confused you as to what to do!!! If you can access my fixya profile and those of other lcd monitor fixya tech's and do some reading, you might find out more options that will be a better solution for your 2220WM. Good luck and best wishes. 12fixlouie north of Windy City.
Feb 11, 2010 | Samsung SyncMaster 2220WM 22" LCD Monitor
Samsung Syncmaster 2220WM Smells and Does Not Stay On
I would leave it unplug, look inside first and report back what you see, post the pictyres will help, see where I post the pictures here: http://s807.photobucket.com/home/budm/allalbums
Jan 27, 2010 | Samsung SyncMaster 2220WM 22" LCD Monitor
My monitor is a SyncMaster 2220WM... the othe day
Your INVERTER has crapped out. Look on ebay.
Jun 26, 2009 | Computers & Internet
Grey Band and Ghosts on monitor
check the playback and other chips inside.. or try to change the setting menu the setting in your remote or manuall change
Jun 25, 2009 | Samsung SyncMaster 203B LCD Monitor
Ghosting
Does the monitor do this on all resolutions?
Try changing the refresh rate on the monitor's properties page and see if the effect changes at all.
Feb 12, 2008 | Samsung SyncMaster 204B 20.1" LCD Monitor
Samsung 2220WM-HAS Monitor Logo
305 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
