Question about Compaq Presario 3045US Notebook
Have a friend that can't boot his computer to windows xp
Starts computer and sees windows logo then nothing. doesn't boot to xp. Doesn't detect the cd drive which he has cd's for recovering.
  • 3 more comments
  • David Koss
    David Koss Mar 10, 2009
    Did that and still wouldn't detect the cd/drive.  Could only get into the bios with another 3-1/2 startup disk from his other laptop.  Even asked him to type other drives that the cd could be in and it would say doesn't exist.
  • David Koss
    If the battery is bad could it cause this problem?
  • David Koss
    David Koss Mar 11, 2009
    he put an external hard drive and then went to the bios and it didn't detect the external harddrive.
  • RescueTechLA
    RescueTechLA May 11, 2010
    Have you changed your boot order in the bios so that it boots cds / dvds first?
  • David Koss
    David Koss Jul 05, 2010
    sorry so late but I found the problem with what you said it was the battery. Thankyou for your help.
    President:
  • 2,653 Answers
Before trying to use any of Dell-net's suggestions, we've got to get you into the bios.
It looks generally like this:
You should see a message displayed when you start the computer that says press "Del or F2 or F10" to enter setup.
Once we get here, we can proceed.
Posted on Mar 10, 2009
  • RescueTechLA
    RescueTechLA Mar 11, 2009
    Not all motherboards will automatically detect an external usb drive, so don't worry about that.
    Can you try pressing F8 during the boot up, then selecting Safe Mode with Command Prompt
    After it's done loading in the dos terminal type:
    chkdsk /r
    press enter
    A message will probably come up saying the disk is locked...
    just press the "Y" key, enter
    then ctrl-alt-delete
    choose the tab that says Shutdown
    Restart the computer
    Let the disk check run
    Hopefully this will get us somewhere.
    Let me know what happens.
  • 477 Answers
Hello.
1. try to boot in safe mode. press F8 key after bios screen flashes.
2. in beginning of start press DEL button or F10 or F2 to go in bios mode look for boot and change the boot order, so the first boot device is your CD
Testimonial: "thanks the problem was solved with a new battery. Appreciated your help. "
  • Filip Eastman Mar 10, 2009
    Seems like the laptops cd drive is broken(its a common problem with laptops.) do you have access to a usb cd drive? then you should be able to restore your computer or run repair mode. one other thing is to download a BART cd and burn it then try to run chkdsk /R in the commando prompt.
    the bart and instructions is here. but then you need a cd drive that works. other way is to put the harddisk in a other PC and run checkdisk. but then you need a adapter like this.
    Think it should be easier to leave it to a professional computer store.
  • Filip Eastman Mar 11, 2009
    Not a usb external harddrive.
    A usb external CD drive. but it possible that your computer is so old that it doesent support usb devices in bios.
Hi everyone, I was installing windows xp sp3 on my compaq desktop computer through my hard drive because my computer doesn't recognise cd roms, So I can't install through cd drives. It installed to...
Hi
Have you tried to go into your cmos settings and enable the settings to detect your cd rom
You should be able to use a external cd rom connected through your USB port to load and re-install windows and your drivers if you have the motherboard cd.
The problem is your limited in your options to work from the hard drive but a disk also gives you the option to repair the filing system and replace missing files.
The problem with installing windows on one pc and it not working on another pc is the motherboards are not compatible, and the configuration has to be similar or the same so the hard drive can boot up and communicate between the hardware and software.
Your options are use a CD rom, change your MB or google your problem and hope someone else was able to resolve this issue.
Cheers
Nov 26, 2012 | Computers & Internet
Help! My Laptop Acer Aspire One stuck at window logo loading Anyone please, help my acer aspire one stuck at window xp logo loading. I try everthing in F8 button, it didn't work, even in safe mod
oh a fun one. Reset your bios to defaults. if that doesn't work then try a windows disk boot up. if that doesn't work you're screwed.
if you want any of your files from the computer first pull out the hdd buy a cord and transfer them to another computer.
Sep 07, 2012 | Acer Aspire One PC Notebook
I can't install windows xp in samsung n110
First - re-seat the hard disk and reboot the computer. If the computer does not boot up then reboot and go into the BIOS configuration to see if the BIOS detects the hard drive. If it doesn't detect the hard drive then it could be faulty.
Then the hard drive needs to be replaced in the computer/laptop, Windows installed and the computer or laptop's device drivers plus your programs etc. to get a functioning computer/laptop again.
Aug 11, 2012 | Samsung N110-12P Notebook
How to recover acer aspire 5738 when screens black
First - re-seat the harddisk and reboot the computer. If the computer does not boot up then reboot andgo into the BIOS configuration to see if the BIOS detects the hard drive. If itdoesn't detect the hard drive then it could be faulty.
Then the hard drive needsto be replaced in the computer/laptop, Windows installed and the computer orlaptop's device drivers plus your programs etc. to get a functioningcomputer/laptop again.
Jul 13, 2012 | Acer Aspire 5738Z-423G32Mn Notebook
ACER 5600 NOT BOOT AND CD DRIVE WILL NOT OPEN
Jul 08, 2012 | Sony VAIO PCG-K25 Notebook
Dell Inspiron 600m: No Boot Device. I'm a computer
Have you tried resetting the BIOS defaults? In doing so, it will force IDE re-detection and often resolve vague boot issues.
Sep 11, 2011 | Dell Inspiron 600M Notebook
How to tackle "missing NTLDR file" error
This happens due to viruses. They delete the NTLDR file.
Do you have the original XP CD? Then insert it and boot from the CD. (If it doesn't boot from the CD, tell us and we will explain how to set it in BIOS).
After a while it will ask you whether to Setup XP (Enter) or Repair an existing Windows installation (R). Press Enter here (Don't worry, I know what I am talking about).
Press F8 to accept the Licence Agreement.
(*** In the following screen you have to press 'R'. IF YOU DON'T SEE A TEXT SCREEN BUT THE SETUP STARTS TO RUN, TAKE OUT THE CD IMMEDIATELY AND RESTART THE COMPUTER. ***) It will tell you you have an existing Windows installation in <C:> drive. It will ask whether to install a fresh copy (Esc, as I remember) or Repair (R). Press R.
Let the setup run. After a while you may need to enter the key.
After few minutes, your computer will be ready, with all your files, fonts and software intact!
Sep 11, 2011 | Microsoft Windows XP Professional
Unistall
In order to uninstall Windows XP, you will need another Operating system to replace it (such as linux or an updated version of windows) - a computer is useless without some form of operating system.
Once you have that CD or DVD, you will need to boot the computer from that disc. From there, the installation process will complete the uninstall of Windows XP.
To boot from a CD or DVD if it doesn't happen automatically when the disc is in the drive as the computer is turning on, press F12 from the first screen when prompted for 'boot options'.
Jul 20, 2011 | Microsoft Windows XP Professional for PC
My Hp Pavilion dv4000 screen stays blank
have you got a bootable cd or recovery cd , boot from it and do a fresh installation, i think your windows has got corrupt
Nov 05, 2008 | HP Pavilion dv4000 Notebook
Only getting EMachines/Windows XP Logo when boot up T3882
you have not set the cdrom as first boot device in the bios (press F2 or Del on boot up to get in bios), choose cd as first boot device, save settings and restart the pc with your cd in the drive and then when prompted press enter
Aug 18, 2008 | E-Machines eMachines Desktop PC
Compaq Presario 3045US Notebook Logo
187 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
