Question about Thermador 37 in. SGSX365 Gas Cooktop
I need a replacement magnetron for my thermador cmt21 oven.
Is there a possibility of finding a replacement magnetron either new or used? the magnetron removed is a hatachi 2m53a
I think I have the part. It was replaced in our oven about 2 years ago. We are getting a new oven. The body of the oven is in our driveway. Someone already came and took the doors, lower elements and molding. You are welcome to the magnetron - if that is what is there.
email me at socialworkathome@gmail.ocm
Posted on Dec 12, 2009
How to replace spark module?
How to replace spark module Todd, Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://forum.appliancepartspros.com/oven-repair-including-ranges-cooktops/42129-thermador-spark-module-replacement.html
Thermador Stove Burner Won Light
Burner on Thermador cooktop won light
Mar 22, 2016 | Thermador Cooktops
I too am looking for part for my Thermador oven. Apparently 486945 is no longer available and a substitution part 622568 is also difficult to find. I never would have spent this kind of money on an...
I really need to have a bit more information so I can give you a best answer. Please give me the model number of your appliance. Thank you, I did find on the net that someone on Ebay does have your part numbers, but did not go there to see if it is new or not.
Jan 02, 2018 | Thermador 37 in. SGSX365 Gas Cooktop
I need a Thermador griddle control/ignitor & a light switch knob
We are Thermador factory authorized service and parts suppliers. Just contact us at:
http://www.fixya.com/repair/d499389-accurate_appliance_repair_service
and we can get your ignitor and light switch out to you asap.
We look forward to working you. Thanks, Ella
Nov 10, 2009 | Thermador 37 in. SGSX365 Gas Cooktop
Thermador Gas Range - Griddle ignition will not spark
I have a Thermador Gas Range PG364GDBS - Oven, 4 burners, and center griddle. All are gas. The four burners and gas oven work fine. The griddle just stopped working, no spark. Turning on the griddle control, the gas valve opens(hear it), gas flows (smell it), but the ignitor will not spark (no loud or faint spark that I can hear). I got a replacement ignition device (mount at the burner) thinking it might be the problem, but still no spark. I checked the AC voltage at the terminal and measured 39 VAC between the terminal and ground. Not sure if that is the correct voltage. Any insights or advice would be great.
Dec 07, 2008 | Thermador SGS36GS Gas Cooktop
Gas range with stricker burners and oven burner
Most likely the oven will not work because the striker is not coming on. I am not very familiar with this stove but most thermador gas oven uses a electronic igniter. the switch controls both the igniter(striker) and safety solenoid so if neither the striker or solenoid is not powered up the switch may be the problem
Regards
Nov 07, 2008 | Thermador SGS36GS Gas Cooktop
Part 415191 Connection Tail Membrane
We are having the exact same problem with this part! Our oven is a S301T, but it still has the same part number for the tail membrane (touch control).
In FINALLY contacting someone at Thermador we were able to find the following information which might aid you. The part is manufactured by Bosch and according to Appliance Pros.com, the numbers:
Part Number 415191 Manufacturer's number (Bosch) Part number AP2832583 which replaces the part number originally numbered 14-38-680.
Don't know if this will help....it hasn't helped me so far. Thermador suggested that we go to a site named OBSOLETEAPPLIANCEPARTS.com. This site seems to be really messed up because you have to call and leave a message as the site is under construction!
I'm so darn frustrated that I'll never buy a Thermador product again (even thought they are great when they work) Good luck!!
Oct 22, 2008 | Thermador 37 in. SGSX365 Gas Cooktop
Thermador PCS364GDUS griddle needs cleaning.
Wear gloves, put all items in a garbage bag. Put outside and spray a can of easy-off oven cleaner on all parts. Seal bag and let sit for 24 hrs. They should come out looking new after you rinse them off. After you wash them off, put them in a 300* preheated oven for about 30 min to ensure they are dry.
Oct 22, 2008 | Thermador PC366BS Stainless Steel Gas...
Obsolete Thermador
Hi Iniro
It is true that thermador has permanently discontinued some of its models - alternative supplier have not beeen identified
Regards
Sep 09, 2008 | Thermador SGS36GS Gas Cooktop
Obsolete Thermador
I am looking for Thermador part # 414-564 and Bosch part # AP2831995. Anyone ???
Sep 09, 2007 | Thermador 37 in. SGSX365 Gas Cooktop
Thermador 37 in. SGSX365 Gas Cooktop Logo
426 people viewed this question
Top Thermador Cooktops Experts
Dan Webster
Dan Webster
Justin Duby
Justin Duby
jasbo
jasbo
Are you a Thermador Cooktop Expert? Answer questions, earn points and help others
