Question about Mitsubishi WS-65513 65" Rear Projection HDTV
Cant reset blue convergence on rear projection WS-73905 73 in
PICTURE HAS BLUE / YELLOW OUTLINE ON EVERYTHING. BLUE + WILL NOT MOVE VERTICALLY UP OR DOWN, CURRENTLY STUCK BELOW ABOUT ONE EIGHTH OF AN INCH . In order to get my question accepted I had to put the wrong model # in the product braket,would not accept the right one? My model # is WS-73905 73 in Diamond Series Rear Projection HD1080
  • taggart63 Mar 11, 2009
    Thanks for the info,I have not looked inside yet,(didn't know what to look for?), Now that I have an idea what to look for I will give it a shot...........Thanks.............Sam
    HI ramone49, thanks for your help. I just discovered that I can not purchase any parts from matelectronics like you suggested.(say's you have to be a dealer) Do you have any other suggestions on where one might be able to buy parts? Thanks.......Sam
  • 111 Answers
Please rate!
First the yellow tinge is due to the blue STK convergence IC possibly being burned. Usually on the right lower side,sccessed from the back, is a module with 3 black stk's on it. If you see the stk's then replace all 3. Not one as the others will blowreally soon. Also check to see if green coils are burned if, so replace them. Get parts from matelectronics.com. Good source and inexpensive, about 40 bucks for the parts...Give a good visual and then proceed. be careful! high volts still in there, but don't worry...
Posted on Mar 11, 2009
  • ramon49
    ramon49 Mar 11, 2009
    Which ones do you need should be like this 'STK 130-xxx or 120-xx.
    I have a few left over...you can google the part, you can buy from local repair shop...
    email: ramondocostico@hotmail.com
  • ramon49
    ramon49 Mar 13, 2009
    Try MCM electronics.com
The Color On My Mitsubishi Rear Projection Tv model- WS-55908 looks to be off, picture looks blue and Yellow.
its sounds like the convergence on your TV needs to be adjusted. (this adjusts all of the color guns in the back of the tv to line them up again, when they get off, you start to get yellow blue or red halos around objects in the picture. In the setup menu on your TV under picture or Display there will be an item that says "convergence" follow the instructions in there so all the crosses on the screen no longer have colored halos anymore.
Mar 10, 2011 | Mitsubishi WS-55908 55" Rear Projection...
There is a arch across the top and bottom of the screen , and everything has a blue outline.
Either the convergence alignment, wich can be repair by the owner...with the remote (tough not a simple task), or you have to change the convergence hybrid IC (STK chip)...if any or the convergence board itself.
Aug 11, 2010 | Mitsubishi WS-65869 65" Rear Projection...
Yelloiw & blue lines outline characters causing a doubling affect
You have a bad convergence board. You will need to replace two convergence ICs and a few low ohm resistors.
Apr 11, 2010 | Hitachi 43UWX10B 43" Rear Projection...
How to reset convergence? on mitsubishi ws 55511, has a shadow colored blue or yellow
There is an option in the user menu on the tv. Using either the remote or control panel on the front of the tv, press MENU then select SETUP. After you choose SETUP go to the 3rd column with the 3 icons. Here you can adjust the red or blue color or reset the convergence back to factory default.
After a few years the set will begin to show increasing problems with the convergence settings. When you can no longer adjust either red or blue horizontally or vertically an IC replacement will be needed. Your set uses (1) SANYO stk393-110 and you want to make sure it's SANYO and not a knock off brand as those usually fail prematurely.
Jan 23, 2010 | Mitsubishi WS-55511 55" Rear Projection...
Blue convergence wont move to the center with the yellow plus sign my picture is yellow and blue can I fix this myself
no you will need to send it to a shop to have it fixed.it will be something to do with the convergence controls .you have 3 tubes red green and blue there is no yellow tube...have a shop fix it
Dec 28, 2008 | Mitsubishi WS-55809 55" Rear Projection...
Mitsubishi WS-65807 problems
You need the two convergence IC's replaced part# STK392-570. About a $300-$400 repair.
Aug 23, 2007 | Mitsubishi WS-65807 65" Rear Projection...
Mitsubishi WS-65513 65" Rear Projection HDTV Logo
132 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
