Question about Panasonic Televison & Video
DMR-EZ475V DVD Recorder DVD in Play mode is stuck and will not Eject Have tried : Unplug, Reset Button, holding down stop button and up button at the same time. Please help.
  • rgreg1 Mar 10, 2009
    Thanks, after repeated holding down both the STOP button and UP ARROW at the same time it finally released/ejected the DVD.
    My next step is to test it with a "junk" DVD.
  • 59 Answers
Ive had this in the work shop befor the cogs can come lose inside the machine if your handy with a screw driver unplug from the mains and take the top of the machine and see if anything has come lose, 50% of the time you can fix this yourself if not you would have to contact panasonic and get them to send a engineer out to you.
Posted on Mar 10, 2009
Cannot ejuect disc even when holding square button and channel button
unplug the DVD player for 10 - 15 mins... when you plug it back in the wall, press the stop/eject button quickly ( or else the player will try to load disc again.. you will have to repeat this again)
Jun 26, 2011 | Panasonic DMR-E55 DVD Recorder
Tip
Force Eject
If a disc gets stuck in the recorder, there a few steps to try before the problem becomes service-related:
1. Power the unit off (so it shows the clock), then simply press the Open/Close button. The unit should power on and attempt to eject the disc.
2. If the above doesn't work - power it off again, then press and hold the STOP and CH UP button on the recorder itself together and hold them down until the unit powers up. This is called a force eject. If this doesn't work (usually if it's not going to work the recorder will simply come on momentarily then loop back into "bye" and go back to the clock), there is one last method to try.
3. Unplug the unit for 30 seconds. Press and hold the same buttons as above as you plug it in. After it performs the self-check "ooooo" across the screen it should do the force eject. If not, the unit requires service to be repaired and possibly the drive replaced.
on Apr 11, 2008 | Panasonic DMR-EZ47V DVD Recorder/VCR
My panasonic dmr-ez475v has a dvd stock inside and will not open or eject the cd. what to do?
I had the same problem. It would not release the DVD because it was not ready. What worked for me, was to insert a VHS Movie and play it for a few seconds, than stop it using the remote, then Eject with the remote, and then after removing the Tape, I pressed the Open/DVD button on the unit and now it worked, it released the DVD
Jul 31, 2010 | Panasonic DMRES30V DVD Recorder/VCR Combo
F60 ERROR CODE ON PANASONIC DMR-ES40V
Unplug the unit for 24-hours. I know, it should not take that long, but in this case I tried shorter periods WITHOUT success!
Just before plugging in unit depress and hold POWER button. You are supposed to hold it for 30-seconds after plugging in, but in my case I did it for 60-seconds. This results in a MASTER RESET that clears all errors, resets interlocks, etc. I could not get past a DVD failure problem, but when I discovered this process everything worked fine!!
Good luck! Hope it works for you too.
Jul 17, 2010 | Panasonic DMR-E85H DVD Recorder
I have a Sony RDR-GX360. Some how I have changed the command mode from DVD1 to DVD 3. Now my remote has frozen and I can't do anything with the DVR player. Is there a reset button or please help.
To fix the Sony remote dvd-1 dvd-2 dvd-3 issue is to take the remote for that recoreder into another room or unplug the dvd recorder a moment. Then hold down the enter key and the number of the mode its stuck in ie if its stuck in dvd-1 mode hold down the enter key and then the 1 key. hold both buttons together for 3 seconds. After this go back into the room and try it or if you unpluged tthe player replug it back in. The remote has to be away from the player to work. again example
get away from player different room so it can not sence remote. Hold down enter and 1 button for 3 seconds and then try it
if its stuck in dvd-2 mode dold down enter and the number 2 button together for 3 secondsd and try it. The idea is you have to be far away from the recorder so it dosent recieve any inputs from the remote while doing this.bigsmile.gifclap.gifagreed.gifpuh2.gifbowdown.gifeek.gif To fix the Sony remote dvd-1 dvd-2 dvd-3 issue is to take the remote for that recoreder into another room or unplug the dvd recorder a moment. Then hold down the enter key and the number of the mode its stuck in ie if its stuck in dvd-1 mode hold down the enter key and then the 1 key. hold both buttons together for 3 seconds. After this go back into the room and try it or if you unpluged tthe player replug it back in. The remote has to be away from the player to work. again example
Mar 08, 2010 | Sony RDR-GX360 DVD Recorder
VCR Stuck
Your machine probably "locked up". Use a toothpick, or some similar item to press and hold the "reset" button on the front panel ( behind the drop down door ) and the unit should reset. Then you should be able to remove the disk.
Apr 20, 2008 | Panasonic DMR-EZ47V DVD Recorder/VCR
Stuck dvd disc.
Hi there
Page 80 in the instruction manual tells you how to do this.
In case you don't have a manual, do the following:
While the unit is off, press and hold the stop key (shown on the unit as a button with a small black square on it) for about 5 seconds. It may take longer to eject depending on the disc.
Hope this helps
Feb 24, 2008 | Panasonic DMR-EZ47V DVD Recorder/VCR
Transfering from VHS to DVD
Press and hold the copy button on the right hand side of the Recorder for 3 seconds and follow promp.
Feb 16, 2008 | Panasonic DMR-EZ47V DVD Recorder/VCR
Panasonic dmr-e50 remote control
The aswer is in the manual that can be had on line, page 45. You have 3 different remote types, 1,2,3, All you have to do is hold down the ENTER button and the number 1 or 2 or 3 on the remote for a few seconds and it will change the setting.
Jan 13, 2008 | Panasonic DMR-E50 DVD Recorder
Dvd will not eject
Try holding down the stop button (black square logo) and the channel change button (upward pointing logo) at the same time for 5+ seconds. If this dos'nt work also press open/close button at the same time as above
Nov 21, 2007 | Panasonic DMR-E55 DVD Recorder
Televison & Video Logo
222 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
