Question about Maytag Neptune MAH5500B Front Load Washer
Maytag top load washer won't pump water out=intermittent problem
Our Maytag top load washer rinses then starts spinning, but the pump doesn't turn on. It finishes the cycle to "off". but if you turn the knob to spin again or open the lid and shut it, the pump comes on. I'm not sure if it's the lid switch because it starts spinning which it wouldn't do if the lid wasn't shut, so I am wondering how the timer starts the pump at the right time while it is spinning.
  • rennrob Mar 10, 2009
    It's a maytag MAV5000AWW
  • steve
    steve May 11, 2010
    This machine sounds like a Whirlpool not a Maytag.
    What is the model number?
    Guru:
  • 462 Answers
If your lid switch was the problem I dont think (and I might be wrong) that it would spin in the first place.
Your pump may have a separate belt and it could be loose or worn out but this is on older models. The pump may not be turning or turning and not pumping. The pulley may be turning on the shaft and its not pumping. Give it a spin and see if you see it turning inside. If not replace it.
The motor and timmer sounds good because of the "spin" you discribed. So we are left with the pump or a filter if it has one.
Look in the lower section find the pump front right hand corner I believe. Trace the hose back up to the tub above nothing in between and you have eliminated the filter. I filter could be any shape but will either attach with 2 hoses or 1 hose and attached to the side or bottom of the outer tub.
I think your pump is probably stopped up, strings and lint especially if you have some older rugs, towels, and rags that are shedding or coming apart. You can try and clean it pretty easily Unplug. Then remove it and look inside it. Catch all the water you can and keep another towel close by. Examine the water. Looking for lint and the like. If its pretty clean looking and not turning freely look for signs of something wrapped up inside it.
Hope this helps. Please rate me accordingly and good luck.
Posted on Mar 10, 2009
  • Maytag Master
  • 3,361 Answers
You have a belt driven pump on this machine.
Maytag redesigned the lid switch for this machine because of this problem.
Try a new lid switch first.
It is possible that the problem could originate from the timer. Which would mean a new timer.
I believe the lid switch will correct your problem.
Maytag Washer won't agitate after filling
Believe you are on right track would try door lock switch first easier to replace and most likely cause.
Aug 04, 2017 | Maytag Centennial 3.2 cu. ft. SuperSize...
Tip
Washing Machines will not rinse or spin
If the water won't drain out of your washing machine, either something is stuck in the drain hose or pump, or the pump is broken. Both fixes are simple if you're even just a little bit handy with tools. We're showing the repair on a Maytag washing machine.
What is wrong with a washer that does not spin?
If your washer fills with water but doesn't agitate, the problem is likely to be a faulty lid switch, a broken belt, or a problem with the motor. (Note: Direct-drivewashing machines do not have belts.) To diagnose the problem, do the following: 1Check the washing machine's spin cycle.
How to Drain Washing Machine That Won Drain Family Handyman
Washer Doesnt Agitate or Spin
Error codes in front load washers
Washing Machine Not Rinsing How To Fix
My washing machine stops at Rinse Does not DRAIN or SPIN
What causes a washing machine not to drain and spin?
If the washer won't drain there might be a clogged pump or hose. It's common for small socks or other small clothing items to get into the water drain system and clog the hose leading to the pump or the pump itself. Remove the hoses from the pump in order to remove the article of clothing.
SOLVED Why won my washer spin or drain Kenmore 110 Series Washing Machine
Maytag Washing Machines will not rinse or spin Google Search
on Dec 12, 2017 | Washing Machines
Maytag Epic Z won't Drain after rinse cycle.
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Aug 13, 2011 | Maytag EPIC MFW9700S Front Load Washer
Washer wont pump water unless in spin cycle
it is not supposed to pump water unless it is in the spin cycle. On most topload washers the motor turns one way for the agitate cycle and then the motor reverses during the spin/rinse cycle which in turn reverses the pump and causes it to pump the water out.
Oct 28, 2010 | Maytag PAV5157A Top Load Washer
Maytag top loading washer 1994 does not spin during rinse cycle
The problem will be the spinning coil is cut off or short circuited kindly replace the motor and check it
May 17, 2010 | Washing Machines
My 3 year old Maytag SAV5710AWW top-load washer
It is your water pump. If you don't know what you are doing it could be tough.
Nov 20, 2009 | Maytag SAV5710 Top Load Washer
Shreiking spin in rinse cycle
Your pump is probably what's causing the noise . Usually the bearing starting to go out , causing the pump to freeze up , begins with this noise .
Oct 11, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Maytag performa mod#pav2200aww leaking between rinse and spin cyc
My Performa started leaking from the Drain Pump rubber gasket. It had dryrotted. However, Maytag doesn't make a replacement O-ring gasket. You have to buy the whole new pump! Thanks Maytag.
Jul 05, 2009 | Maytag PAV2300 Top Load Washer
Maytag atlantis washer
Start by checking the belt by tilting the machine back and examining for wear, glazing and cracks, next pull the belt to make sure everything turns. Post back if this looks fine.
Jul 26, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Maytag Neptune MAH5500B Front Load Washer Logo
402 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
