Question about Maytag LSE7806A Top Load Stacked Washer/Dryer
Maytag washer filled with water then stopped working.
I have a Maytag Stacker Washer/Dryer model LSG 7804. It filled with water then stopped working. The fuse in front is fine. Through my research I have found that the problem might be the Lid Switch. I thank you for any help.
  • Anonymous Mar 18, 2009
    Fuses are fine, water fills up, but nothing happens after that. The washer doesn't spin or drain the water.
  • 686 Answers
Check your belts there are two of them one for the pump and the other the transmission
Posted on Apr 06, 2009
    New Friend:
You can check the lid switches (they are paired) the following way:
1) take off the front and top washer housing panels.
2) look for the wire bundle coming off the lid switch and find the plastic pull apart connector.
3) undo the connector.
4) take an Ohm meter and check the resistance when the lid is closed: a) orange and black wires should complete a circuit, orange and pink should also complete a cicruit, all other pairs shold be "open".
5) check the resistance when the lid is open: orange and white should make a circuit, but no other pairs.
6) replace the defective switch, or replace the complete unit.
7) check the 250V 1A fuse in the left front, replace it if it has blown.
Good luck.
Posted on Dec 15, 2009
SOURCE:
I have may tag wash model nu mav5920eww i just hooked it up tried reg wash it filled with water then would not continue to wash went to pause mode
Maytag & Whirlpool washer diagnostic - Fills with water then ...
? 3:03
https://www.youtube.com/watch?v=71zySSScDPE
Jul 11, 2013 - Uploaded by ApplianceVideo.com
Troubleshoot your trusty Maytag Washer that has some of the ...washer diagnostic - Fills with water then cycle stops - LAT8014AAE .... Not agitating Maytag 2 belts top load washers - Duration: 26:55. by theapplianceman 23,820 views. 26:55.Washing Machine Keeps Filling With Water and Will Not Agitate ...
Maytag top loading washing machine stopped working & filled with
Dec 02, 2015 | Maytag MAV5920E Top Load Washer
How to fix a Maytag LS 7804 leaking water into the tub
One of your water inlet valves are not closing all the way and needs to be replaced.
I’m happy to assist further over the phone at https://www.6ya.com/expert/donald_a8261495ff0777e2
Apr 27, 2014 | Maytag LSE7806A Top Load Stacked...
Burning rubber smell from my maytag stacker washer and the water wont drain
Most likely the water pump belt is slipping or the water pump could be locked up.
Sep 03, 2010 | Maytag LSE7806A Top Load Stacked...
Won't run
sounds like your lidswitch.when you close lid you should hear or feel it click on and off.located on back side of lid in center.
Mar 10, 2009 | Maytag LSE7806A Top Load Stacked...
Washer stopped working??
change the pressure switch its the switch that you select the water level with
Mar 18, 2008 | Maytag LSE7806A Top Load Stacked...
Maytag Washer/Dryer stackable
well i am having about the same problem, but mine won't even fill, the dryer works but the washer won't fill or turn on at all. my husband had it all apart, too the control assembly to parts place and they said that hardly ever goes bad so it is still sitting unusable with no answer or money to spend on it in site.
Jan 15, 2008 | Maytag LSE7806A Top Load Stacked...
Maytag stacked washer/dryer Model LS7804
OK it may be one of 2 things. I would check the lid switch first. On some maytags the have a lid switch that if it is not working properly it will not let the washer fill. If it will not fill the washer will not wash because the pressure switch did not activate the timer to wash. If the switch checks good you might have a bad timer. If you open the control panel you will find a tech sheet with the wiring diagram. I would follow the fill cycle and check the components. You might also check the water valve to make sure its ok too. But its very rear that both the hot and cold would go at the same time. Good luck!
Jul 11, 2007 | Maytag LSE7806A Top Load Stacked...
Maytag LSE7806A Top Load Stacked Washer/Dryer Logo
879 people viewed this question
Top Maytag Washing Machines Experts
jimorris77
Sheldon Dedek
Bill Long
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
