Question about Acer Aspire 5610-4648 Notebook
Acer aspire 5610z
My acer aspire 5610z computer shuts down after 10 mins of using , any know whats the problem ?
  • 1 more comment
  • runea63 Mar 10, 2009
    yes happen when comp is conected to wall outlet, i dont see messege before it shutdown
    no unusual sounds........
    i can only hear the exhaus fan
    yes it feels hot right before it shut down
    its on power addaptor ,
  • Lance Malone
    Lance Malone May 11, 2010
    Thank you for allowing me to answer this question. I need to ask a few more questions to better assist you.
    1. Does this happen when the computer is connected to the wall outlet or only when its on the battery?
    2. Do you see any error message occur before it shuts down?
    3. Do you hear any unusual sounds coming from the laptop?
    4. When you turn on the laptop, feel around for a small breeze of warm air coming from anywhere on the computer. Did you feel any warm air coming from a fan?
    5. Does the laptop seem unusually hotter right before it shuts down?
    By answering these questions I will be able to assist you better. Thank you for your time.
    Problem Solver:
  • 9 Answers
Body { background: #FFFFFF; margin: 0px; padding: 4px; font-family: arial, verdana, sans-serif; font-size: 10pt; } p { margin:0px; padding:0px; } .spwrap { background: transparent url(../wysiwyg_rte/misspell.gif) repeat-x scroll center bottom; } Ok the issue that you are having is an overheating processor. This can be caused by either a fan that has failed or is failing. It could also be a faulty motherboard that is not increasing the fan's RPM when the processor reaches a certain temperature. When the processor overheats the BIOS failsafe will immediately shutdown the computer to keep from any major damage from occuring to the processor.
Another avenue to take is get a can of air and blow out any dust that is built into vents of your computer. Dust can cause alot of heat to build up and cause the processor to overheat. Sometimes this resolves the issue on its own.
Posted on Mar 11, 2009
    Scholar:
  • 82 Answers
Need more info....does it replicate without the battery? If it does, then it may be that the processor is overheating and shutting down the computer. Try to run with just the power adaptor and see if it happens. If it doesn't, then its probably the battery....
Posted on Mar 10, 2009
Acer 5610z infrared receiver disabled in bios
First, what infrared devices are you trying to use? As I'm sure you know altering the BIOS is like taking a stroll in a minefield, one wrog step and........................Well you know.
Nov 17, 2012 | Acer Aspire 5610z Parts Or Reapir
Acer Aspire 5610Z. Upgraded to Win 7. Screen resolution changes
Your laptop was not designed to run windows 7 or be compatible with it. It may run fine with windows 7 but issues might come up sooner or later like the one you're experiencing.
[EXPERIMENTAL]
Download both of these (as I don't know which one of thsese two your laptop needs). Keep mind that doing the following could render your system inoperable and use at own risk. When downloaded, extract ZIP , open desired folder and find SETUP or INSTALL program. Right click and choose properties, then navigate to compatibility mode, then select windows Vista from the menu. Then apply changes, ok and close window and attempt to start.
Acer Aspire 5610Z VGA Intel Driver Vista
Acer Aspire 5610Z VGA NVIDIA Driver Vista
May 27, 2010 | Acer Computers & Internet
My acer orbi cam on aspire 5610z isn't working
you did not say which Operating system you are using which is important as I am going to suggest you install the driver. at any rate I am going to give you the link where you can select your computer model and operating system from the drop down menus. from the horizontal menu choose driver and select your camera make
http://support.acer.com/drivers_download.aspx
Jan 10, 2010 | Acer Aspire 5610-4648 Notebook
Shift key wont depress 5610z
There may be something under the key if there are gaps between the keys. If you make sure the computer is shut down all the way, you can turn it up side down and gently tap it to see if anything moves or comes out. If not, the keybord may have to be taken out this isn't too bad of a process but can be tricky if you do not know what you are doing. I would read up on laptop disection before attempting it.
Nov 11, 2008 | Acer Aspire 5610-4648 Notebook
Acer Aspire 5610z
you can downloads any acer driver from acer.com just download and install all you find for your model... the problem might be if you dont know how... many drivers just uncompress the installing data to a folder usually in a TEMP folder or a ACER folder in this case... just read what you are doing and that will be all.
here is a link for the model you posted here
http://www.acerpanam.com/flex/acerdrivers/bin/drivers.html?CFID=188401&CFTOKEN=30397319
its very easy! Good Luck
Mar 22, 2008 | Acer Aspire 5610-4648 Notebook
Acer aspire 5002wlmi laptop
Use speedfan to see what temps its running at as it sounds like an overheating problem. Is the fan running ok?
Jan 29, 2008 | Acer Aspire 5100 Notebook
Do u have installed sound dirver???Email me at ar_pllana@hotmail.com and i will fix ur problem.OK?
Nov 08, 2007 | Acer Aspire 5100 Notebook
Acer Aspire 5610-4648 Notebook Logo
255 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
