Question about Daewoo DTQ-27U4SC 27" TV
TV Turns Off, Color is Turning Technicolor Blue-Green
My TV has been shutting off periodically, at least once or twice a week. When I turn it back on, it's fine again. Last night I noticed the color was becoming a weird blue green-ish technicolor. I turned it back off and on and it was fine. Is my TV dying or do I need a new part?
  • 59 Answers
Sounds like the tube is going on the set best thing to do is consider buying a new tv or take to your local tv repair shop and they should be able to sort it for ya :D
Posted on Mar 10, 2009
Sharp CL32SB21U TV shutting off by itself and won't come back on.
searching for a therminal defect on an active or passive electronic (smd) component
A canister coldspray can sometimes be helpfull when its come on when turns green spray and look if there is difference in time and a hair dryer for searching an therminal defect somewhere. resistor or active component.
Apr 25, 2018 | Sharp Televison & Video
Picture turns green ,usually within 10 minutes of turning it on.It will sometimes go back to normal color but generally returns to green.This happened when the set was much newer and Sony replaced all...
Green Tube maybe trying to short out or you can try adjusting screen drive to the Green Tube by turning control down a notch, Sony had a bad run on these with alot of Bad Tubes.
Dec 08, 2009 | Sony KP-57HW40 57" Rear Projection...
Green Screen
Hi, how is the cable box hooked up to the TV? Is it HDMI cable or componet (red/green/blue) ? When you say totally green, do you mean the the picture is only green with the other colors missing or every color looks green ?
Mar 14, 2009 | Protron PLTV-37 37 in. LCD Television
Turns green and shuts off
I had an electrician come over. He pulled out the bulb that was dead (for me it was the color that was flashing before it would turn off) and now I have a blue and green TV with no red. He said that the only way to fix it is to replace the red lamp with a new one.
Jan 16, 2009 | Sony KP-65WS500 65" Rear Projection...
Philips 42PF9956/37 Plasma TV - Looking for y sustain board
it isnt the Y-SUS board, it is the Power supply, iv fixed this exact problem twice in the last month, try turning the tv on, and when it turns green, unplug it real fast, while light is still green, after 15 seconds plug it back in, then hit the power button, if it dont come on, hit the power button again, this time, as soon as it turns off, hit the power button again to turn back on, sometimes you can trick the tv and it will turn on, at least i was able to do it, and once it comes on, it should work fine, untill you turn it off again.
Jan 10, 2009 | Philips 42PF9431D/37 TV
Screen Turns Pink-Mitsubishi 57'' Wd-Y57
since dlps use a color wheel to make the color the color wheel may be going out. get it serviced
Nov 15, 2008 | Mitsubishi WD-Y57 57" Projection HDTV
No pic
alright guys...blew a bulb....fixed that. still didint work...found out it was ballast...replaced that. tv worked for a month..all the sudden hdmi input didint work id plug in my playstation and screen would turn green and say "hdmi color has been corrupted" im thinking wtf? so a week later it works fine then just turns off in middle of watching espn... comes back on an hour later...only to turn off again...it just turns black for ten seconds then just turns off and the red and green lights blink at intervals of one second....replaced a bulb..not that, same problems.......when the tv comes on for the ten minutes before it quits working the pic and sound are great i just dnt get it...is it shorting out? color wheel bad? a fan?
May 24, 2008 | Toshiba 52HM95 52" HDTV Projection...
KP51ws500 turns green and shuts itslelf off
There may be several causes but, one is that when any color gun is being over driven, the Sony shuts down the gun to protect it. Try this. Remove the front of the set by removing the two screws from each lower corner. Next remove the black panel held on by 5 or 6 screws. Now you should see a panel with 6 potentiometers on it. Turning the ones on the bottom row CCW reduces the drive. Turn the color down and if all the guns stay lit, SLOWLY turn them up until you get the color balance that you like.
May 02, 2008 | Sony KP-51WS500 51" Rear Projection...
Daewoo DTQ-27U4SC 27" TV Logo
230 people viewed this question
Top Daewoo Televison & Video Experts
 Grubhead
Grubhead
Are you a Daewoo Televison and Video Expert? Answer questions, earn points and help others
