Question about Fuji Photography
I want to know how to rewind a film reel or reverse an Elmo FP-A movie projector. I have an old Elmo FP-A movie projector that works fine. I do not have the instruction manual that would explain how to rewind the movie reel. I would appreciate any help. Thank you, ...jj
There are 3 round knobs and 1 Autostart switch on the control panel. The key to rewinding this machine is by pushing the gray button down, while turning the Motor Knob to the "Run" position. Of course you'll need to start the original film back on its reel, directly. (Do not thread the film as you would normally.) BTW, you can show your films in reverse by using the Reverse button on the motor switch while its running. Hope this helps. Now, if I can find someone who can guide me in re-assembling my Elmo projector's lens, which I dis-assembled in order to clean the crud off the multi-lenses in the main lens unit itiself.
Posted on Apr 21, 2009
    New Friend:
    Problem Solver:
  • 5 Answers
I have a minolta autodual 8 film projector but the front reel is turning backwards in the wrong direction. How do I change the direction to turn in the same direction as the back reel.
I assume you haven't put a reel of film onto the projector and looped it through to the back spool. The front spool usually 'freewheels' whilst the film is pulled through the projector and taken up by the motor driven rear spool.
It is possible that the friction drive and/or drive belt have deteriorated with age, as the mentioned projector is a rather elderly 'classic' of the dual 8mm series.
If in doubt, don't risk your family pictures. Try the unit with an old piece of film on small spools.
Dec 26, 2014 | Eumig Imperial P8 Movie Projector For 8mm...
Where I can find a service manual and maintenance for a projector Elmo FP-C?
I "Googled" the projector name & found service documents for it at: www.photobooksonline.com I hope this helps!! Jim
Feb 18, 2013 | Office Equipment & Supplies
THREADING FILM IN A ELMO FP-C PROJECTOR
Is your film super 8mm? If yes, then the red sprocket above the lens should be pushed in, and the bottom black sprocket will stick out. If you have regular 8mm, then the black bottom sprocket should be pushed in. If the sprockets are not in the correct position, push the green lever forward (towards the screen) then open the two orange tabs, then push in the correct sprocket. Once you have the correct sprockets aligned, close the orange tabs. How to tell if you have 8mm or super 8mm film: Look carefully at the film image. If the sprocket hole is next to the middle of the image, it's super 8mm. If the sprocket hole is between images, it's 8mm.
Jan 10, 2013 | Sewing Machines
HAVING TROUBLE THREADING FILM - ELMO FP-C
Is your film super 8mm? If yes, then the red sprocket above the lens should be pushed in, and the bottom black sprocket will stick out. If you have regular 8mm, then the black bottom sprocket should be pushed in. If the sprockets are not in the correct position, push the green lever forward (towards the screen) then open the two orange tabs, then push in the correct sprocket. Once you have the correct sprockets aligned, close the orange tabs. How to tell if you have 8mm or super 8mm film: Look carefully at the film image. If the sprocket hole is next to the middle of the image, it's super 8mm. If the sprocket hole is between images, it's 8mm. If your green lever is stuck in the forward position, that's because the film is not threaded. Once your film threads correctly, the green lever will spring back.
MX33 Bell & Howell collection reel does not turn
As this problem is not relevant to "Motherboards" you might like to post it in the right category. But, you might like to check for wear on the drive wheel (rubber) they become shiny over time and this will decrease the friction needed to move the film stock. Rubber is and organic compound and as such it deteriorates, my Akai reel to reel did a similar thing a few years ago and the part was no longer available, so I made one( re-engineered the old one actually). good luck
Jan 28, 2012 | Computers & Internet
I can not turn the light on my super eight projector. I have changed the projector bulb with no success. All other features of the projector function properly. The projector is made by elmo moder FP-A
I would use a volt/ohm meter to test the bulbs, If they are known to be good, open up the projector and look for a fuse.
BTW- Elmo was purchased by Canon many years ago.
Jan 02, 2010 | Cameras
Eumig 610D Super 8 projector take-up reel not engaging at hub so will not rotate. Hub will rotate, not the reel. Perhaps worn key?
I think the Eumg 610D was a dual guage projector, capable of showing both Standard 8 and Super 8 films. (I'm basing my comments on the S810D I have in front of me, its sound "big brother").
To move between formats, there were two cogs internally that had to be changed, a film gate (two parts), and two adaptors/liners inserted into the centre of the film reels that transformed the centre from "a fat one" to "a thin one".
If the take up driver cog is rotating, but the reel is not, check whether the adaptor is in place.
You can see what they look like on eBay....
http://cgi.ebay.com/NEW-Super-8-Movie-Projector-Reel-Adapter-Film-8mm_W0QQitemZ170450331975QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item27afa1a947
If the rear driver cog is not rotating, then it might be a worn/defective drive belt, in which case leave a further comment and we'll explore that.
Hope this helps
I have a Bell and Howell Model 456 Autoload Super8/Regular 8mm Projector bought in 1969. During projection, when the very end of the advancing film is no longer engaged by the rotating teeth, the film...
The Bell and Howell Model 456 Autoload was made that way ON PURPOSE. The last foot or so must be manually pulled from the projector. As described in the manual, "this safeguard has been designed to prevent the end of your film from flapping against the projector after your movie is completed."
If the entire film was going into the take up reel at the end automatically, then THAT was a defective occurence. It is not supposed to do that.
Apr 04, 2009 | BenQ (200NSH-LAMP) Projector Lamp for...
Faulty TRV-35H
general cleaning start with forward and rev button with good contact cleaner and then go inside use air blower or compresed air(radio shack)check:lever which make the movement of forward and backward confirm it is clean-check of selonid and it is return spring has a good tension change it if it is weak or broken.apply a light grease over all moving parts.
best wishes
Dec 11, 2007 | Elmo Projectors TRV-35H Slide Projector
Photography Logo
695 people viewed this question
Top Fuji Photography Experts
TC CAMERA REPAIR.Com...
pontelemon
pontelemon
Jax Planet
Jax Planet
Are you a Fuji Photography Expert? Answer questions, earn points and help others
