Question about Mitsubishi WD-52525 52" Rear Projection HDTV
The screen seems dark and blurry
Model WD 52528 rear projection mitsubishi tv
  • 111 Answers
Take off the front panel carefully, usually 2 screws around the controls. Next, stick your head in and look at the red green and blue tubes. see if they are dirty? if, not look further into the tube using aflaslight and see if there is a white pasty looking substance inside. IF so, you need to clean as you have bacteria growing in the cooling fluid. A big job and you need the gaskets, can order from Mitsubishi tech support..good luck be careful.
Posted on Mar 11, 2009
The picture quality on our WD 52528 is horrible - dark, blurry, and hard to see picture at all if not looking at the tv straight on.
Your satellit receiver should have the capability to hook to your TV either by using HDMI cable out from sat unit to HDMI in on TV. This sgould give you sound and audio, or it should have component output which is a series of three cables red, blue and green.The component cablesdon't provide audio so you have to use digital optical or composite cables for sound. Whos satellite box are you using?You should be able to press your menu and get into "system set up" and, there should be an option for HDTV. Go for the highest resoulution(1080 And a ratio of 16 x 9. You tv manual should tell you about screen set up. Let me know
Apr 04, 2011 | Mitsubishi WD-52528 52" Television
The image projected by the tv is extremely dark and hard to see with daylight
Your lamp is going out. it will dim for a time before it dies. check online for a replacement lamp
Mar 12, 2011 | Mitsubishi WD-52528 52" Television
Blurry picture
convergence problem...very common. An excellent TV, well worth repairing!
Jun 03, 2010 | Mitsubishi WD-52525 52" Rear Projection...
4 year old Mitsubishi wd 52528 has had flashing timer light then turns itself off since power outage. After turns itself off, can't get it back on, even with reset.
Need to unplug for computer to power down then plug back in, light will blink for a few then go out and you should be able to power on!
Feb 12, 2010 | Mitsubishi WD-52525 52" Rear Projection...
I have a mits tv 52 inch and the timer light keeps blinking. I tried unplugging it and hitting the reset button and it is still blinking and no picture will come on any other troubleshooting ideas?
your problem is in the dm module
there are caps in the supplys on this module that vent and cause the blink of death symptoms
if you have the tools and feel capable you can get a kit at www.
tv world .com
Oct 23, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Our Mitsubishi WD 52525 goes to blue screen and shuts off.
It sounds like you TV is overheating and the video is suffering and the lamp is overheating as well. Also, if your TV is over 2-3 years old, the mirrors (behind and below the big front screen) desperately need to be cleaned. Clean all filters and fans as well. (Look on side and behind the unit). Is the TV in a "hot" environment and/or dirty environment? DLP TV's are NOT sealed units. They need to be cleaned every few years to work well to have a good, clear, bright picture.
Jun 24, 2009 | Mitsubishi WD-52525 52" Rear Projection...
If the tv looks now dark this is the first symptom of a lamp replacement (refer to the user's manual to do this job) and get a Mitsubishi original replacement.
the best picture setting (when the lamp is back of course) depends in the light of the room.
Now if after replacing de lamp and playing with the settings and the screen still pale, dimm, not enought color. a cleanning in the reflexion area is needed. (technican job)
Apr 12, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
195 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
