Question about HP J4680 Office Jet All-In-One Printer
During set-up of my brand new hp officejet j4680 all-in-one, the process has stuck at "please wait, aligning cartridges". I may have hit the "ok" button too soon after fitting the cartridges.----HELP. bigboab
    Scholar:
  • 82 Answers
Try shutting down the printer, disconnect from power and let sit 5 mins, reconnect and power on. If that doesn't work you should check to see that the cartridges are installed properly. Remove, reinstall, and see if that works....
Posted on Mar 10, 2009
I get my ink put in by Costco. I am getting an error message saying that the black ink cartridge is incompatible. But I have used this black printer cartridge before. I do not have the money to buy a new...
Are the cartridges used, genuine HP cartridges? I know that on HP and Canon printers that the brand name cartridges seem to work better than the aftermarket ones.
Dec 08, 2010 | HP Officejet J4680 InkJet Printer
My HP Officejet 4500 keeps telling my to align my printer cartridges and I have done it several times. After I align them and print something it requires me to align them again.
Try removing the cartridges, closing the printer, and disconnect the power. Let sit for at least 10 minutes, then hook up the power, wait until it stops making noises, the reinstall the cartridges, black first, then color, and if the alignment comes up again, press cancel. This should remove the error.
Sep 30, 2010 | HP OfficeJet 6110 All-In-One InkJet...
Put in new cartridges now can't get to scan?
Remove the Cartridges and clean the Electrical contacts ( golden points ) on the cartridges
Power off the Printer
If possible clean the contact inside the printer cartridge slot with cue tip.
Power on the printer and reinsert the cartridges.
It should print the alignment sheet.
Place the alignment sheet face down on the Scanner bed and press OK button on printer front panel.
If this does not work, Press the Setup button ( Ranch like symbol )
Scroll down to TOOLS - Press OK
Choose Align Cartridge/Printer - Press OK
Sep 28, 2010 | HP Officejet J4680 InkJet Printer
Align to align your new print cartridge ? problem ?? hp officejet 4212 All-İn-One .
after the printer has printed the alignment shoot, Place is face up on the document feeder and press OK button,
If this does not work, Disconnect power cord from printer ( while printer has power ) and Press and hold # and 6 button and connect the cord back.
Follow the process to align the printer
2nd Solution Is :
Press Menu ( setup ) button on printer
Scroll to Tools ( press ok )
Choose Align Printer/Cartridge ( press ok)
Jun 18, 2010 | HP OfficeJet 4255 All-In-One InkJet...
Print Cartridge Problem: (Tri-Color) See
Top three solutions to this query at HP support are close to your described problem: (not exact) Try the closest match to your error.
http://h10061.www1.hp.com/ccsearch/search?pname=HP+Officejet+J4680+All-in-One+Printer&qry=print+cartridge+problem+tri-color&submit.x=0&submit.y=0&ctry=us&lc=en&dlc=en&mode=lz&tmv=0&method=prodFinder&pid=3692887&productBigSeriesOid=3645080&spid=3692888&opname=HP+Officejet+J4680+All-in-One+Printer&pname_desc=HP+Officejet+J4680+All-in-One+Print%2FFax%2FScan%2FCopy&ptype=consumer&stype=pn&contextual_lname=&spname=HP+Officejet+J4680+All-in-One+Printer&temp_hql=s-001%2Cs-002%2Cs-004%2Cs-003%2Cs-007%2Cs-005%2Cs-006%2Cs-017%2Cz-001%2Cc-002%2Cc-001&product_line_code=DU&search=0
Nov 28, 2009 | HP Officejet J4680 InkJet Printer
Printer will not print or make copies. Our alignment page got accidently thrown away. Can we align the printer without it? Can we get a new alignment page?
alignment page is done during the installation of new ink cartridges. you could re align the printer.
press setup > tools - ok > align cartridges - ok and then scan the aligned print out
Oct 31, 2009 | HP OfficeJet J4580 All-In-One Laser...
OfficeJet G85xi cartirdges will not align
Could be one of two things....
1 - you may have bad cartridges (usually the color)...when the machine does an alignment it looks for specific marks on the paper...ie..green check marks before each line etc...if the correct marks are not there you will get an alignment failure...if the green check marks are there etc then you have a different problem...first replace color cartridge with a HP Brand cartridge
2- spot sensor on the side of carriage is not working...this is the little blue/green light that comes on during alignment. Its what reads the markings on paper so if the markings are correctly there and you still get this error then the spot sensor needs to be replaced. Simple fix that u can do. We sell the spot sensor for $15
Inkworks
866-381-0541
Aug 22, 2008 | HP OfficeJet G85 All-In-One InkJet Printer
HP Officejet 5510 - Replacing Ink Cartridge
this should work for all 5500 hp printers i hope this helps you out richard from chicago i just noticed you have the wrong cartage you need hp 57 color that will make all the difference :-) HP Officejet 5500 series All-in-One model Black cartridge Color cartridge HP Officejet 5505 HP 56 HP 57 HP Officejet 5508 HP 56 HP 57 HP Officejet 5515 HP 56 HP 57 HP Officejet 5510, HP Officejet 5510xi, HP Officejet 5510v HP 56 HP 57 HP Officejet 5600 series Replacing the print cartridges
  1. Turn on the HP Officejet, and lift open the print-carriage access door. The print carriage will move into the access area. Figure 1: Opening the print-carriage access door c00034766.jpg
  2. After the carriage stops moving, push down on the top of the print cartridge to release it, and then pull it toward you out of the slot. Figure 2: Removing the print cartridge c00034767.jpg NOTE: It is normal to see ink buildup in the print cartridge slots.
  3. Remove the new print cartridge from the packaging and gently remove the plastic tape by using the pink pull tab. CAUTION: Do not touch the copper contacts or ink nozzles. Install the cartridge immediately upon removing the tape to prevent ink from drying in the nozzles. Figure 3: Removing the plastic tape c00034768.jpg
  4. Push the new print cartridge into the appropriate slot at a slight angle, until it clicks into place. CAUTION: Do not attempt to push the cartridge straight into the slot. It must slide in at a slight angle. Figure 4: Inserting the print cartridge c00034769.jpg
  5. Close the print-carriage access door.
Aligning the print cartridges The HP Officejet will prompt you to align the print cartridges every time you install a new print cartridge to assure high-quality output.
  1. When the message displays, press OK . The HP Officejet will print an alignment page.
  2. Place the alignment page face down on the left front corner of the glass with the top of the page facing the left side.
  3. Press OK . The HP Officejet will align the print cartridges and display Alignment Complete .
Mar 18, 2008 | HP Officejet 5510 All-In-One Thermal...
Alignment after new cartridge
Hi I think that you will need to clean the gold dots on the printer carriage or if not done so remove the blue tape from the cartridge or if you are trying to use refills install some originals as this may help.
Hope this helps'
Please rate me
Cheers J
Dec 30, 2007 | Apple HP Officejet G85xi InkJet Printer
HP J4680 Office Jet All-In-One Printer Logo
305 people viewed this question
Seeker5211
Seeker5211
