Question about Lenovo IdeaPad Y510 Notebook
System shutting down
I have a lenovo Y500 laptop and the system gets powered off all of a sudden. I scanned for virus with Norton 2009 it does not have any virus. Please help me in resolving the issue. OS - Windows XP.
I also have one more question, do i need to format and break partition to increase the space in the C Drive?
  • shravankpand Mar 10, 2009
    No ... the computer is not getting hot and i use the Windows XP
  • RescueTechLA
    RescueTechLA May 11, 2010
    Does the computer feel hot?
    Which operating system are you using?
    New Friend:
  • 84 Answers
Hi friend i adivice you to change you antivirus to avira antivir
and scan it again
if the unsolved
format you pc
Posted on Sep 01, 2009
    Scholar:
  • 103 Answers
you can try to connect it direclty to the power outlet without using the battery,if its still the same,theres a possiblity that the problem is with the power supply or the motherboard itself
Yes,for you to be able to increase the space in drive C,you need to format and break partition specially if you have two or more of it
Posted on Jul 18, 2010
    President:
  • 511 Answers
Jst format the os nd install a fresh copy xp u will surely get a good result ....
I forget my lenovo 3000 y500 bios password, how do i bios open without open the cmos
Normally, you can just move a jumper or unplug the CMOS battery to clear the password. But, I found the following in the Ideapad Y500 repair manual:
"A supervisor password (SVP) protects the system information stored in the BIOS Setup Utility. The user must enter the SVP in order to get access to the BIOS Setup Utility and change the system configuration.
Attention: If the SVP has been forgotten and cannot be made available to the servicer, there is no service procedure to reset the password. The system board must be replaced for a scheduled fee."
http://download.lenovo.com/consumer/mobiles_pub/ideapad_y400y500_hmm_1st_edition_sep_2012_english.pdf
Oct 31, 2014 | Amstron Lenovo 3000 Y500 Laptop AC Power...
My lenovo G460 shuts down unexpectedly
http://ct.download.com/clicks?t=1141982088-ce770fd4fbc57664a08aea1a8f03b80d-bf&brand=DOWNLOAD&s=5
avg free 2012
http://www.majorgeeks.com/Microsoft_Security_Essentials_for_Windows_d6242.html
microsoft security essentials your operating system must be registered
Win7/Vista/XP 64 bit
http://majorgeeks.com/downloadget.php?id=4281&file=1&evp=dbb3b0aebe6a6a4ff18089a6489a5e62 anti malware free edition Win XP/2003/Vista/Windows7
http://windows.microsoft.com/en-US/windows/products/security-essentials/product-information
malware protection
http://100-downloads.com/download.php?p=615
windows xp microsoft security essentials
http://100-downloads.com/download.php?p=614
windows 7 microsoft security essentials
If you believe a virus may be the cause of your laptop's shutdown problem, run a virus scan on the system to find out if any exist.
if your laptop keeps shutting off
If your laptop suddenly shuts itself off for no apparent reason, there are several factors that can contribute to the problem.
When you troubleshoot the laptop, remember that it is also possible for a combination of causes to be at work.
Excessive Heat
Keep Cool
All newer laptops have built-in heat sensors that shut the computer off when it exceeds a pre-set temperature threshold. Install and run a temperature monitoring utility to determine whether the laptop is overheating.
might be getting hot
check you CPU make sure its securely seated and has thermal grease
http://www.hardwaresecrets.com/article/Thermal-Compound-Roundup-February-2012/1490
Hardware Issues
If you replaced or installed new hardware in your laptop, use the device management utility to review if there are any resource conflict or failure reports. You can also remove unnecessary hardware and run the laptop to see if the problem persists. If it doesn't, reinstall each hardware component and re-test until the laptop fails.
Operating System Issues
The operating system start-up controls can affect how the laptop performs.
Follow the operating system developer's instructions for entering the start-up program, and confirm that the settings are what your laptop requires.
Power Supply
If your laptop is not getting the correct power it requires, it will shut down completely. Test the current of any outlets you use with your computer, employ a surge protector to ensure steady current, and confirm that the power supply itself is not defective.
Battery
Failing batteries can produce unexpected laptop shutdowns.
Use a battery monitoring utility to determine whether or not the battery is healthy and replace it if it isn't.
Malware
Unfortunately, rootkits and viruses can cause your laptop to shut down without warning.
You will probably have to take the hard drive out of the laptop to be able to scan it fully and remove any malware that is installed, or the laptop will shut down before the scan and repair can finish.
http://www.malwarebytes.org/mbam.php
Malwarebytes is as the name says, a Malware Remover!
Download the Free Version from the link above.
Download, install, update and scan once a fortnight.
http://www.spybot.info/en/index.html
Spybot Search & Destroy 1.6.2 is a very good, FREE Anti-Spyware Program.
Download, install and update it.
Then SCAN with it.
Update it, and scan your System once a fortnight.
Hope this helps
Oct 29, 2012 | Lenovo G460 Laptop Computer - 06777TU...
The laptop does n my laptop does not shut down.it shows the screen"windows is shutting down" but does not shut down completely.pls suggest.
this problem shows that the operating system may attacked with virus or gone corrupt by any other mean, following actions are suggested:-
1. Scan computer with latest anti virus 2. Re-installation of operating system is recommended if the 1st option not worked
good luck
Do rate the solution if got help
Dec 06, 2010 | Lenovo ThinkPad R61i Laptop
How do I program Norton ver 16.7.2.11 to shut off computer following compete scan
The Norton program having the issue with the system shutdown and system scan
to fix the issue
please uncheck the shout down option in System scan
Oct 07, 2009 | Symantec Norton Antivirus 2009 1-User -...
I am using a Lenovo Y500 laptop. My laptop is shutting down suddenly for last couple of weeks. When i searched for a solution in online, i got a message from Lenovo that, their is some problem with my...
Hi I suggest you update your display driver first and then update others as well. Wrong drivers and incompatible bios versions can cause many problems....
The link is directly to your lenovo website for the Lenovo 3000 Y500 laptop. Incase your model is different let me know the exact model. It will be listed underneath your laptop on a sticker with bar code.
Sep 23, 2009 | IBM Computers & Internet
Turn off problem
Check device manager for any driver update. Also perform sfc /scan now using run command.
Jul 25, 2009 | Lenovo 3000 Y410 Notebook
IBM thinkpad G41 won't run any programs
remove the norton anti-virus and reboot the pc and install the anti-malwarebytes and scan....it will detect more virus..if it detects malware,remove some trojan viruses and restart,your system will run smoothly and install new anti-virus named kaspersky 2009...
Jan 03, 2009 | IBM ThinkPad G41 Notebook
In built Tv tuner in a laptop Lenovo y500
right click my computer->properties->hardware->device manager->
check for device with ! mark
click plus sign next sound video and game controller
check if u have any any tv tuner card listed mark
.if TV tune card is not listed ,
turn off laptop
remove battery , remove power supplay
press and hold power button for 1 min
plug power cable back and turn on laptp with out battery and check.
Feb 22, 2008 | Computers & Internet
HELP!!! Computer stopped working when anit-virus was installed?????
Assuming you are using windows xp. 1. Boot up into windows safe mode by pressing the "F8" key during boot process. 2. Choose "Safe Mode without networking" on the menu and after entering your desktop a pop-up will appear telling you that you are using windows safe mode, just press "OK" then uninstall Norton Anti-Virus. 3. Shut-down and/or reboot computer. Another alternative would be to boot into safe mode and perform a system restore. If you choose to do this, you still need to uninstall Norton Anti-Virus because a system restore will only fix just system files not programs that were installed. In other words, you will have a partial installation of Norton Anti-Virus in your computer. As to why this happened, could be a compatability issue with the use of Norton and some other program. Good luck.
Jun 07, 2007 | Sony VAIO Z1VAP1 (PCGZ1VAP1) PC Notebook
Lenovo IdeaPad Y510 Notebook Logo
157 people viewed this question
Top Lenovo Computers & Internet Experts
Michael Vincent Cruz
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
