Question about Sony PlayStation® 3 (80GB) Console
No power system started then just died no power
  • kingofdacity Mar 28, 2009
    having the same problem and i just got it on Valentine day :(
    President:
  • 2,653 Answers
If you don't even get the red led light then it's likely the main power supply took a dive.
If it's still under warranty by all means get it repaired by Sony.
Otherwise, you'll have to open the PS3 to determine which power supply you have.
Then just match it up with one on ebay and swap it, should bring your machine back to life.
Let me know if you have any other questions or problems.
Posted on Mar 10, 2009
  • 6,784 Answers
Hi, this is a power board failure. the power supply will need to be replaced. there are many sites that have repair parts that you can purchase for do it yourself but, i recommend authentic Sony parts.
  • Michael Masters
    Michael Masters Mar 10, 2009
    i would send to Sony for this repair if the warranty is good.
Saturn vue will start but will only stay runnuing about twenty minutes then stalls wont start
Does the car loose power before stalling or does it simply die without warning? If it loses power first, you're likely looking at a fuel pump or fuel system problem. If it just dies, you probably have an ignition problem. Does the check engine light come on before it dies?
Jan 07, 2015 | 2003 Saturn VUE
Engine die
system too lean at idle suggests that you have a vacuum leak in system. Check vacuum hoses, under dash controls and the vacuum hose to the transmission. check brake booster for leaks.
Dec 30, 2014 | 2006 Hyundai Santa Fe
99 gmc engine starts idles rough then boggs and dies when you give it gas
What engine ? 4.3 , 4.8 , 5.3 or 6.0 l What fuel injection system ? What is the fuel pressure ? Do you know what fuel trims are ? The fuel pressure regulator's are prone to leaking to leaking on thses SPI injection system./
How to identify and repair leaking fuel pressure regulator GM CPI system...
Jun 12, 2017 | 1999 GMC Sierra
Cranks then dies
yes this unit will run for only a second or two then dies. the fuel pump is pumping well
Apr 24, 2012 | Generac Power Systems Generac 5734 15000...
1987 subaru gl-10 died while driving, then starts back up
Check the power going to the electrical ignition system
Oct 15, 2017 | Subaru GL Cars & Trucks
While riding my 2001 vstar 1100 it died dead!!!! No power anywhere battery is new and dont know alot about yamaha charging system...HELP
sounds like a problem i had with my v star if u can charge it and it starts and runs for a bit then dies again check the rectifier which charges the bike
Jun 01, 2011 | 2001 Yamaha V Star 1100 Classic
2002 F-150 regular cab. Idling seems like it wanted to die. While driving would rev up and down wanting to die. Finally died at a red light and had to be towed home. In the driveway it acts like a dead...
From what you describe, it sounds like your alternator died. The battery's main function is to provide power to start the vehicle. Once started, the alternator takes over and provides the main source of power to the truck, and also recharges the battery.
When the alternator stops working, the car starts to run solely off the battery. It will work for a little while, but as the battery starts to lose power, strange things will happen with the electronics. The computers and other electronics that control the vehicle are very dependent on a constant, steady flow of voltage. When that voltage dips below 11 or 10 volts, the car may start to run badly or strange things may happen with electrical system.
When there was finally not enough power to keep the car running, it shut off. Of course, once this happens, there will not be enough power left to start the truck back up.
Feb 24, 2010 | 2002 Ford F150 Regular Cab
Stalling
If it starts up fine and then dies (2 SEC) it is the PASSLOCK security system, those cars are fairly notorious for that problem.
The passlock system will cut power to the fuel injectors after 2 sec. Use a test light and see if the injector power is being shut off.
Sep 11, 2009 | Computers & Internet
Running problem
It takes electrical power to run the ignition system on your bike. If your alternator is not providing that power it must come from the battery. When the battery is out of power, the bike dies. You have a problem in your bikes electrical system. MOST likely is a faulty battery, but could also be alternator or other piece in the system.
Jan 18, 2009 | 1995 Yamaha FZR 600
Sony PlayStation® 3 (80GB) Console Logo
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
