Question about Maytag Washing Machines
Doesn't always go into spin cycle - Maytag Washing Machines
  • 3 more comments
  • dfrank02 Mar 10, 2009
    after looking again it is a whirpool washer with the same probem that sometime it doesn't go to spin cycle then after it does it may work fine 5 or 6 time before it does it again.
  • dfrank02 Mar 11, 2009
    I am a first time user of this site! Thanks for the help and have a great day. You have made mine better.
    so far my problem seems to possibly the spinner basket related. If we center the basket manually and then retry it goes into spin. Is there some sort of sensor that looks at the position of the spin basket that could be the problem????
  • dfrank02 Mar 16, 2009
    I jumpered the lid switch and if I give the basket help to spin it will go and spin. Is there a start capacitor on the motor possibly????
    add to last post i also noted that it doesn't always go into high spin
  • Maytag Master
  • 3,361 Answers
Sounds like a intermittent lid switch problem.
Open the control panel to view the lid switch .
Adjust the mechanism that pushes against the lid switch.
Posted on Mar 10, 2009
  • 1 more comment
  • steve
    steve Mar 10, 2009
    You may still have a bad lid switch not making consistent contact.
    On a Whirlpool it is not adjustable. It must be replaced.
  • steve
    steve Mar 11, 2009
    No basket sensors.
    Raise the control panel to access the lid switch quick connector.
    Make a jumper wire to by-pass the lid switch and run your machine several loads with the jumper.
    If it continues to be a problem your timer would be at fault.
  • steve
    steve Mar 16, 2009
    If you have to help the basket start the clutch on the transmission is bad.
    It is replaceable.
Kenmore Washer Doesn't Agitate
Don't be too sure the drive coupler hasn't failed or is failing
Jun 15, 2013 | Kenmore 24032\24036 Top Load Washer
Washer doesn't spin in spin cycle
What is the model number of your unit?
Oct 31, 2012 | Kenmore Washing Machines
Bosch nexxt essence won't spin
Either a blocked filter or worn carbon brushes
Oct 11, 2017 | Bosch Nexxt Premium WFMC6400UC Front Load...
Spin cycle or agitate doesn't always engage. I
There is likely to be a problem with either the lid solenoid/lock or the 'lid closed' sensor requiring a service engineer's attention I suggest. Sorry ;-0(
If this has assisted and/or clarified the situation for you please consider a 4 thumbs up on our rating.
Thanks and good luck!
John C
Jun 28, 2011 | Kenmore Elite Oasis 27052 Top Load Washer
Spin cycle does not always remove enough water, so...
Take the agatator out and check the drainage it will be bloked clean as required. Hope this helps
May 17, 2010 | Washing Machines
Machine dot draining, not completing cycle.
check pump filter may be blocked . Pump always got water in it even when empty put towels down and if possible lean machine back wards .and always remove plug from wall before doing any repairs .
Feb 11, 2010 | Washing Machines
Spin cycle doesn,t work
Hi. this is a failed timer device. simply replacing the timer control module will eliminate these issues you are having.
May 27, 2009 | Roper RAX7244KQ Top Load Washer
Washing Machines Logo
96 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
